Problem installing .Net Framework 4 (HRESULT 0xc8000222)
2012-10-04T16:57:45+00:00
I have a problem to install the .Net Framework 4 ... this problem is:
HRESULT 0xc8000222
anyome can help me please?
My System OS is Windows 7
2012-10-05T07:23:56+00:00
  1. Does the issue persist only with .netframework?
  2. How are you  installing it? Is it through windows update or manually?
a: Click Start > Run.
b: Type cmd and press Enter.
Please run the following command in the opened window.
net stop WuAuServ
c: Click Start > Run Type %windir% and press Enter.
d: In the opened folder, rename the folder SoftwareDistribution to SDold.
e: Click Start> Run type cmd and press Enter.
net start WuAuServ
Hope this information helps.
1400+ people found this answer helpful.
159 additional answers
    2016-01-03T16:00:03+00:00
    restart your pc and try again it will come
    2016-02-26T20:32:52+00:00
    restart ur pc again
    2016-04-02T11:40:16+00:00
    Start  > All Programs >Accessories >Command Prompt ---right click Run as Administrator
    follow  this It should solve the problem..
    2016-04-09T15:34:57+00:00
    Thanks  for help👍👍👍👍
