Problem installing .Net Framework 4 (HRESULT 0xc8000222)
2012-10-04T16:57:45+00:00
I have a problem to install the .Net Framework 4 ... this problem is:
HRESULT 0xc8000222
anyome can help me please?
My System OS is Windows 7
2012-10-05T07:23:56+00:00
  1. Does the issue persist only with .netframework?
  2. How are you  installing it? Is it through windows update or manually?
a: Click Start > Run.
b: Type cmd and press Enter.
Please run the following command in the opened window.
net stop WuAuServ
c: Click Start > Run Type %windir% and press Enter.
d: In the opened folder, rename the folder SoftwareDistribution to SDold.
e: Click Start> Run type cmd and press Enter.
net start WuAuServ
Hope this information helps.
1400+ people found this answer helpful.
159 additional answers
    2012-11-04T08:42:48+00:00
    Glad to know it worked... :)
    2013-02-03T04:40:14+00:00
    Thank you very much! I couldn't install some of my programs, but now i can!
    2013-04-18T11:12:53+00:00
    Thanks i cannot install the dotnet frame work now i can thanks so much
    2013-07-14T17:47:53+00:00
    When i do this, on the cmd says "Access Deny"
