Problem installing .Net Framework 4 (HRESULT 0xc8000222)
2012-10-04T16:57:45+00:00
I have a problem to install the .Net Framework 4 ... this problem is:
HRESULT 0xc8000222
anyome can help me please?
My System OS is Windows 7
2012-10-05T07:23:56+00:00
  1. Does the issue persist only with .netframework?
  2. How are you  installing it? Is it through windows update or manually?
a: Click Start > Run.
b: Type cmd and press Enter.
Please run the following command in the opened window.
net stop WuAuServ
c: Click Start > Run Type %windir% and press Enter.
d: In the opened folder, rename the folder SoftwareDistribution to SDold.
e: Click Start> Run type cmd and press Enter.
net start WuAuServ
Hope this information helps.
1400+ people found this answer helpful.
159 additional answers
    2014-08-16T20:07:45+00:00
    Can I remove these strange folders after the success installation of .NET FRAMEWORK 4/4.5?
    2014-08-18T23:40:20+00:00
    Hi Shubh,
    Thank you for providing the screenshot.
    1.Were there any changes (hardware or software) made to the computer prior to the issue?
    1. What happens when you try to delete the folders? If you have tried deleting it.
    Did you try the steps from the link mentioned below?
    **http://windows.microsoft.com/en-us/windows7/how-do-i-open-a-file-if-i-get-an-access-denied-message**
    If you need any further assistance with Windows Operating System, please post your query on Microsoft Community Forums and we’ll be glad to assist you with it.
    2014-08-27T14:46:37+00:00
    Hi
    it prevents me from renaming it to SDold.
    is there a way to go around that ?
    2014-08-29T11:04:00+00:00
    I just read the comments i found what i was not having to solve this problem is that i need to do
     start > type cmd in search > run it as admin > then do all as it goes
    net stop WuAuServ
    a. Click Start > Run Type %windir% and press Enter.
    b.  In the opened folder, rename the folder SoftwareDistribution to SDold.
    c. Click Start> Run type cmd and press Enter.
    net start WuAuServ
