Problem installing .Net Framework 4 (HRESULT 0xc8000222)
2012-10-04T16:57:45+00:00
I have a problem to install the .Net Framework 4 ... this problem is:
HRESULT 0xc8000222
anyome can help me please?
My System OS is Windows 7
2012-10-05T07:23:56+00:00
  1. Does the issue persist only with .netframework?
  2. How are you  installing it? Is it through windows update or manually?
a: Click Start > Run.
b: Type cmd and press Enter.
Please run the following command in the opened window.
net stop WuAuServ
c: Click Start > Run Type %windir% and press Enter.
d: In the opened folder, rename the folder SoftwareDistribution to SDold.
e: Click Start> Run type cmd and press Enter.
net start WuAuServ
Hope this information helps.
1400+ people found this answer helpful.
159 additional answers
    2012-11-01T22:25:06+00:00
    Harsh Jaiswal and Jessen P ... Thank you very much ... I can't could install the Net Framework 4
    2012-10-28T09:40:06+00:00
    Right click on cmd.exe and run it as administrator...
    It should solve the problem...
    2012-10-06T05:39:33+00:00
    net stop WuAuServ
    net start WuAuServ
    Hello ...
    1. Yes.
    2. I'm Installing Manually ... The Windows Update does not work
    And the "net stop WuAuServ" console tells me:
    System error 5.
    Access denied.
    PD: The Windows Search does not work ... tells me:
    The Internet security settings prevented the opening of one or more files
