Error: Bootmgr is missing Press Ctrl+Alt+Del to restart when starting Windows
2012-01-11T19:00:07+00:00
I receive the error “Bootmgr is missing Press Ctrl+Alt+Del to restart” when I start Windows. I have found the issue but I don’t see a good solution. What’s the best way to fix this issue?
LD
2012-01-11T19:03:00+00:00
Hello LD,
This message usually indicates that the boot sector is damaged or missing. The boot sector is a region of your hard disk that contains information that is used to load your operating system. If a boot failure is detected when your PC is starting, you may receive this error message.
To resolve this issue, use the steps in the following KB article:
You receive Error message: “Bootmgr is missing Press Ctrl+Alt+Del to restart” when starting Windows
Hope this helps,
Bobby
47 additional answers
    2012-11-05T21:09:12+00:00
    OK you can remove this file just now by the “Duplicate Files Deleter” from. Try it now http://DuplicateFilesDeleter.com. It may be able to be removed/ delete this file from your hard drive.
    2012-12-14T19:49:17+00:00
    Im attempting a fix on a hp pavillion g7-1329wm notebook pc that has avg, all updates etc. This machines error was caused by attempting a factory reset while an av boot cd was still in the drive, bios set to boot from cd/dvd etc. just sayin
    2013-02-11T00:50:43+00:00
    Okay, I am encountering this problem, but in a somewhat unique situation. I got my hands on an older Dell machine with no HDD. I put one that I know works, which was completely formatted and empty, in, connected everything and whatnot, and went to the BIOS to make the boot priority CD/DVD drive. The Machine acknowledges the presence of the disk drive but will not display a "Press any key to boot from CD/DVD" message as my other machines do, it simply displays the "BOOTMGR is missing, press Ctrl Alt Del to restart" message, and yes, the disc is in the drive.
    I'm out of ideas.
    2013-03-04T00:58:04+00:00
    Hi Bobby,
    I dont have windows 7 disc as OS came preinstalled in my laptop. Please help
