Error: Bootmgr is missing Press Ctrl+Alt+Del to restart when starting Windows
2012-01-11T19:00:07+00:00
I receive the error “Bootmgr is missing Press Ctrl+Alt+Del to restart” when I start Windows. I have found the issue but I don’t see a good solution. What’s the best way to fix this issue?
LD
2012-01-11T19:03:00+00:00
Hello LD,
This message usually indicates that the boot sector is damaged or missing. The boot sector is a region of your hard disk that contains information that is used to load your operating system. If a boot failure is detected when your PC is starting, you may receive this error message.
To resolve this issue, use the steps in the following KB article:
You receive Error message: “Bootmgr is missing Press Ctrl+Alt+Del to restart” when starting Windows
Hope this helps,
Bobby
47 additional answers
    2012-06-25T20:09:46+00:00
    hi there,
    i did step 4 and thats how i got to where i am now. bootmsg missing. so what do i do now?
    2012-06-26T01:38:36+00:00
    it is next to imposible to offer help when the  pc make ,model ,ram ,and win ? bit ? are not known .
    2012-06-27T21:19:48+00:00
    I ususally find a way to messup  MS in bizaare ways. Probably my history as their birth caused us to get off a mainframe onto 8" floppies. In one case, on an Asus 18.9" 64 bit Windows Home Premium, with (past tense) 4 partitions, I can get to the Bios but it is stuck on a setting called "Don't Boot" or the equivalent. I suppose they have their reasoins. There are no other options, even if I could get away from that one, which I can't. The ethernet connection won't work of course. I know this response is late.
    It's past warranty I'm sure so maybe I'll give Geeksquad or J&R a try.  I won't use Staples anymore after, and you really can't believe this, I went in a week after I'm fairly sure I left something I bought there (I know. A week) and one of the two new people there said he was going into another room (Where?) to look at the Surveillance footage from that day a week before! I thought I was in a casino, and waited at least a hald an hour! I talked later to someone who, and it's obvious anyway, said no way. On a roll here. I also did something brilliant with a Toshiba Qosimo same specs, except one partition only, and tried pluugin the power into a USB mutli port adapter when it was in and on. Zap. Nothing. The Motherboard maybe? I'll get to that soon as well! I've tris almost every book disk I can find or make. Even the reliable English ones were of no use. They were on 1.44 mb but floppies saved my day more than once.
    I wasn't sure how all this worked here on this Thread and haven't been in my Hotmail for a while. Excuse me and thank you.
    2012-07-26T20:22:17+00:00
    Hello LD,
    Hope this helps,
    Bobby
    That link requires a disc i bought this 2nd hand with no discs what can i do also any advice on why online games won't work properly on  my comp for instance ball games like pool the balls will keep stopping and starting going super slow this has been happening on all games for last month before that they all worked fine that is the reason i wanted to go back to factory settings how can do it with no discs
    ps sorry for the bad grammar it's not my strongpoint i don't know where the marks are supposed to and when
