KB2686509 repeatedly fails with Error code 0x8007F0F4
2012-05-08T19:14:06+00:00
2012-05-15T03:18:54+00:00
This is obsolete
I wrote a VB Script to fix two problems while running microsoft security update KB2686509
HKLM\SYSTEM\CurrentControlSet\Control\Keyboard LayoutandHKLM\SYSTEM\CurrentControlSet\Control\Keyboard Layouts
for those who are no registry freaks.
*Here you can download my little hotfix as ZIP-file.*
What does it do? Nothing magic!
1. Makes a registry backup
2. delete entries in Keyboard Layout
3. checks every keyentry in Keyboard Layouts against existing file in %SystemRoot%\System32
Hope I help someone with this script.
Regards
Christian from Germany
Update 2012/06/03
I have written a batch file too. So you can use this instead the vbs solution.
It's a little bit harder, because the batch file exports the two keys, deletes them, creates blank entries. Then you have to run the KB2686509 again! After doing this do not reboot, press continue in the command window (restoring old entries) and then reboot.
If one of the (bad) keys does not exists, the batch file creates a blank entry, so KB2686509 should work.
Here you can download the batch file http://www.vivus.net/dl/
2012-05-08T22:52:59+00:00
New instructions OF 6/19/2012
The FIX-IT’s for this KB have been released today for this Security update. They are available for download at : http://support.microsoft.com/kb/2686509
Since we’ve figured it out, can you see if any of these solutions fixes you up?
Edit on Sunday 5/13 - I figured out the problem.  I had remapped a keyboard key.
If you are hitting this error and do NOT have a faultykeyboard.log file see if you can follow this post and get the patch installed:
KB2686509 - Failure - due to remapping of a key - TechNet Articles - United States (English) - TechNet Wiki:
http://social.technet.microsoft.com/wiki/contents/articles/10829.kb2686509-failure-due-to-remapping-of-a-key.aspx
If you upgraded from Windows ME or 98 to XP (you see nothing but .kbd files listed in your faultykeyboard.log file) -- follow this post:
KB2686509 - Failure - due to upgrade from Windows ME or 98 to Windows XP - TechNet Articles - United States (English) - TechNet Wiki:
http://social.technet.microsoft.com/wiki/contents/articles/10876.kb2686509-failure-due-to-upgrade-from-windows-me-or-98-to-windows-xp.aspx
If you have DLLs noted in the faultykeyboard.log file but can't find them on your PC follow this post:
KB2686509 - Failure due to missing DLL files - TechNet Articles - United States (English) - TechNet Wiki:**http://social.technet.microsoft.com/wiki/contents/articles/10880.kb2686509-failure-due-to-missing-dll-files.aspx**
IF NONE OF THESE WORK, email susan-at-msmvps.com and I'll have someone from Microsoft call you back to fix your system.
Freudi always posts great analysis:
2686509 (MS12-034) - Vulnerability in the keyboard layout handling on Windows XP SP3 - 8:05:12 - patch-info.de:
http://translate.googleusercontent.com/translate_c?hl=en&ie=UTF8&prev=_t&rurl=translate.google.com&sl=de&tl=en&u=http://patch-info.de/artikel/2012/05/08/1324&usg=ALkJrhgcu5tcIlkGoRk0XYjsGBlgYvLePw
397 additional answers
    2012-05-22T21:24:02+00:00
    Now run the script in the ANSWER post on Page 1...
    HKLM\SYSTEM\CurrentControlSet\Control\Keyboard Layout\Scancode Map
    and
    2. delete Scancode Map if exists
    Regards
    ...then reboot & test.
    2012-05-23T17:19:20+00:00
    A different solution
    I have trawled through every one of the 27 pages of this forum and tried all the answers none of which worked. I didn't have a faultykeyboard.log nor scancode nor any of the other problems.
    HotFix4KB2686509.vbs asks for admin access because it couldn't find HKLM\SYSTEM\CurrentControlSet\Control\Keyboard Layout
    When I commented out the check for this it ran but found no faults.
    That turned out to be the simple solution!
    I have the following Registry key
    but not
    so I created
    and then the KB2686509 upodate succeeds.
    To summarise:
    If
    doesn't exist then create it, no need to put any entries in it.
    I hope that helps - I don't think anyone else has mentioned this solution but apologies if they have and I've overlooked it.
    2012-05-23T20:02:27+00:00
    Thank you liv101
    Yes, I have the show files on and I can find a lot of *.dll files but not the two indicated in the failureKeyboard.log, which are: kbdjpn.dll and kbdkor.dll.
    Please find following the last pages (last 3 times) of the log:
    8.609: 2012/05/21 18:49:00.609 (local)
    8.609: C:\WINDOWS\SoftwareDistribution\Download\3438087687b5dd8accc81e44f72f02e7\update\update.exe (version 6.3.13.0)
    8.609: DoInstallation: GetProcAddress(InitializeCustomizationDLL) Returned: 0x7f
    8.609: Failed To Enable SE_SHUTDOWN_PRIVILEGE
    8.625: Hotfix started with following command line: -q -z -er /ParentInfo:64573cde20ff4e4eae61574034d31e5a
    8.625: In Function GetReleaseSet, line 1240, RegQueryValueEx failed with error 0x2
    9.062: Return Value From IsMachineSafe = 0
    9.062: IsMachineSafe returned 441092
    9.062: Fist Condition in Prereq.IsMachineSafe.Section Failed
    9.062: Condition Check for Line 1 of PreRequisite returned FALSE
    9.078: ReadStringFromInf: UpdSpGetLineText failed: 0xe0000102
    9.078: KB2686509 Setup encountered an error:  Setup cannot continue because one or more prerequisites required to install KB2686509 failed. For More details check the Log File c:\windows\KB2686509.log
    9.078: Setup cannot continue because one or more prerequisites required to install KB2686509 failed. For More details check the Log File c:\windows\KB2686509.log
    9.078: Update.exe extended error code = 0xf0f4
    11.157: ================================================================================
    11.172: 2012/05/23 10:57:03.265 (local)
    11.172: C:\WINDOWS\SoftwareDistribution\Download\3438087687b5dd8accc81e44f72f02e7\update\update.exe (version 6.3.13.0)
    11.172: DoInstallation: GetProcAddress(InitializeCustomizationDLL) Returned: 0x7f
    11.172: Failed To Enable SE_SHUTDOWN_PRIVILEGE
    11.172: Hotfix started with following command line: -q -z -er /ParentInfo:b81f47147c39c24eab770d7d42e47eef
    11.188: In Function GetReleaseSet, line 1240, RegQueryValueEx failed with error 0x2
    13.188: Return Value From IsMachineSafe = 0
    13.188: IsMachineSafe returned 441092
    13.188: Fist Condition in Prereq.IsMachineSafe.Section Failed
    13.188: Condition Check for Line 1 of PreRequisite returned FALSE
    13.188: ReadStringFromInf: UpdSpGetLineText failed: 0xe0000102
    13.188: KB2686509 Setup encountered an error:  Setup cannot continue because one or more prerequisites required to install KB2686509 failed. For More details check the Log File c:\windows\KB2686509.log
    13.204: ReadStringFromInf: UpdSpGetLineText failed: 0xe0000102
    13.204: Setup cannot continue because one or more prerequisites required to install KB2686509 failed. For More details check the Log File c:\windows\KB2686509.log
    13.204: Update.exe extended error code = 0xf0f4
    58.391: ================================================================================
    58.438: 2012/05/23 22:15:30.203 (local)
    58.438: C:\WINDOWS\SoftwareDistribution\Download\3438087687b5dd8accc81e44f72f02e7\update\update.exe (version 6.3.13.0)
    58.875: DoInstallation: GetProcAddress(InitializeCustomizationDLL) Returned: 0x7f
    58.907: Failed To Enable SE_SHUTDOWN_PRIVILEGE
    58.985: Hotfix started with following command line: -q -z -er /ParentInfo:0bb46ecdb8d51e40a3c60e7c30a41e8f
    59.375: In Function GetReleaseSet, line 1240, RegQueryValueEx failed with error 0x2
    74.125: Return Value From IsMachineSafe = 0
    74.125: IsMachineSafe returned 441092
    74.125: Fist Condition in Prereq.IsMachineSafe.Section Failed
    74.125: Condition Check for Line 1 of PreRequisite returned FALSE
    74.172: ReadStringFromInf: UpdSpGetLineText failed: 0xe0000102
    74.172: KB2686509 Setup encountered an error:  Setup cannot continue because one or more prerequisites required to install KB2686509 failed. For More details check the Log File c:\windows\KB2686509.log
    74.188: KB2686509 Setup canceled.
    74.188: Update.exe extended error code = 0xf00d
    I hope you can get some clue from the log.
    For the moment the KB2686509 update is coming over and over in my PC but I gave up and wait for a "miracle" from Microsoft to fix it automatically. I hope that I do not risk anything by not having it installed.
    Thanks again.
    Statlaz
