KB2686509 repeatedly fails with Error code 0x8007F0F4
2012-05-08T19:14:06+00:00
2012-05-15T03:18:54+00:00
This is obsolete
I wrote a VB Script to fix two problems while running microsoft security update KB2686509
HKLM\SYSTEM\CurrentControlSet\Control\Keyboard LayoutandHKLM\SYSTEM\CurrentControlSet\Control\Keyboard Layouts
for those who are no registry freaks.
*Here you can download my little hotfix as ZIP-file.*
What does it do? Nothing magic!
1. Makes a registry backup
2. delete entries in Keyboard Layout
3. checks every keyentry in Keyboard Layouts against existing file in %SystemRoot%\System32
Hope I help someone with this script.
Regards
Christian from Germany
Update 2012/06/03
I have written a batch file too. So you can use this instead the vbs solution.
It's a little bit harder, because the batch file exports the two keys, deletes them, creates blank entries. Then you have to run the KB2686509 again! After doing this do not reboot, press continue in the command window (restoring old entries) and then reboot.
If one of the (bad) keys does not exists, the batch file creates a blank entry, so KB2686509 should work.
Here you can download the batch file http://www.vivus.net/dl/
2012-05-08T22:52:59+00:00
New instructions OF 6/19/2012
The FIX-IT’s for this KB have been released today for this Security update. They are available for download at : http://support.microsoft.com/kb/2686509
Since we’ve figured it out, can you see if any of these solutions fixes you up?
Edit on Sunday 5/13 - I figured out the problem.  I had remapped a keyboard key.
If you are hitting this error and do NOT have a faultykeyboard.log file see if you can follow this post and get the patch installed:
KB2686509 - Failure - due to remapping of a key - TechNet Articles - United States (English) - TechNet Wiki:
http://social.technet.microsoft.com/wiki/contents/articles/10829.kb2686509-failure-due-to-remapping-of-a-key.aspx
If you upgraded from Windows ME or 98 to XP (you see nothing but .kbd files listed in your faultykeyboard.log file) -- follow this post:
KB2686509 - Failure - due to upgrade from Windows ME or 98 to Windows XP - TechNet Articles - United States (English) - TechNet Wiki:
http://social.technet.microsoft.com/wiki/contents/articles/10876.kb2686509-failure-due-to-upgrade-from-windows-me-or-98-to-windows-xp.aspx
If you have DLLs noted in the faultykeyboard.log file but can't find them on your PC follow this post:
KB2686509 - Failure due to missing DLL files - TechNet Articles - United States (English) - TechNet Wiki:**http://social.technet.microsoft.com/wiki/contents/articles/10880.kb2686509-failure-due-to-missing-dll-files.aspx**
IF NONE OF THESE WORK, email susan-at-msmvps.com and I'll have someone from Microsoft call you back to fix your system.
Freudi always posts great analysis:
2686509 (MS12-034) - Vulnerability in the keyboard layout handling on Windows XP SP3 - 8:05:12 - patch-info.de:
http://translate.googleusercontent.com/translate_c?hl=en&ie=UTF8&prev=_t&rurl=translate.google.com&sl=de&tl=en&u=http://patch-info.de/artikel/2012/05/08/1324&usg=ALkJrhgcu5tcIlkGoRk0XYjsGBlgYvLePw
397 additional answers
    2012-10-21T13:42:37+00:00
    Hi, a little tip.
    I stumbled upon this problem on an XP machine. From the faultykeyboard.log file it appeared there were some keyboard layouts installed and then probably deleted manually or something like that.
    1. The layouts were listed in the log file one by one, not at the same time.
    2. The second layout was listed without the DLL file, just the name.
    3. The FixIt did not work.
    4. There were no such subkeys in the registry.
    If you have a custom keyboard layout(s) installed, please remove them through the Control Panel before fixing this problem. This way you can be certain you are not dealing with something you need.
    The proper way to fix the problem was to delete the numeric keys containing the specified DLL and/or keyboard layout name from the registry. I deleted  all occurrences (there are several Control Sets).
    You can reinstall your layouts, but please try to find a solution that has a proper install inf file and can be removed through Control panel later.
    Hope this helps!
    2012-11-14T21:20:17+00:00
    What if there is not a scan code listed inside of my LOCAL MACHINE/ ..../ keyboard layout ?
    I do have the default REG_SZ (values not set) listed but no binary scan code.
    As far as I know this machines keys have never been remapped- so this leads me to ask...
    How does one implement a new scancode map from scratch?
    Thanks for your time, any response is greatly appreciated.
    2012-11-14T21:35:05+00:00
    Thank you very much Christian S. - Moers on May 14th, 2012 my issues were solved... if only it didnt take 5.5 hours to find it amidst the logs of failures... Thanks so much. Cheers!
