KB2686509 repeatedly fails with Error code 0x8007F0F4
2012-05-08T19:14:06+00:00
2012-05-15T03:18:54+00:00
This is obsolete
I wrote a VB Script to fix two problems while running microsoft security update KB2686509
HKLM\SYSTEM\CurrentControlSet\Control\Keyboard LayoutandHKLM\SYSTEM\CurrentControlSet\Control\Keyboard Layouts
for those who are no registry freaks.
*Here you can download my little hotfix as ZIP-file.*
What does it do? Nothing magic!
1. Makes a registry backup
2. delete entries in Keyboard Layout
3. checks every keyentry in Keyboard Layouts against existing file in %SystemRoot%\System32
Hope I help someone with this script.
Regards
Christian from Germany
Update 2012/06/03
I have written a batch file too. So you can use this instead the vbs solution.
It's a little bit harder, because the batch file exports the two keys, deletes them, creates blank entries. Then you have to run the KB2686509 again! After doing this do not reboot, press continue in the command window (restoring old entries) and then reboot.
If one of the (bad) keys does not exists, the batch file creates a blank entry, so KB2686509 should work.
Here you can download the batch file http://www.vivus.net/dl/
2012-05-08T22:52:59+00:00
New instructions OF 6/19/2012
The FIX-IT’s for this KB have been released today for this Security update. They are available for download at : http://support.microsoft.com/kb/2686509
Since we’ve figured it out, can you see if any of these solutions fixes you up?
Edit on Sunday 5/13 - I figured out the problem.  I had remapped a keyboard key.
If you are hitting this error and do NOT have a faultykeyboard.log file see if you can follow this post and get the patch installed:
KB2686509 - Failure - due to remapping of a key - TechNet Articles - United States (English) - TechNet Wiki:
http://social.technet.microsoft.com/wiki/contents/articles/10829.kb2686509-failure-due-to-remapping-of-a-key.aspx
If you upgraded from Windows ME or 98 to XP (you see nothing but .kbd files listed in your faultykeyboard.log file) -- follow this post:
KB2686509 - Failure - due to upgrade from Windows ME or 98 to Windows XP - TechNet Articles - United States (English) - TechNet Wiki:
http://social.technet.microsoft.com/wiki/contents/articles/10876.kb2686509-failure-due-to-upgrade-from-windows-me-or-98-to-windows-xp.aspx
If you have DLLs noted in the faultykeyboard.log file but can't find them on your PC follow this post:
KB2686509 - Failure due to missing DLL files - TechNet Articles - United States (English) - TechNet Wiki:**http://social.technet.microsoft.com/wiki/contents/articles/10880.kb2686509-failure-due-to-missing-dll-files.aspx**
IF NONE OF THESE WORK, email susan-at-msmvps.com and I'll have someone from Microsoft call you back to fix your system.
Freudi always posts great analysis:
2686509 (MS12-034) - Vulnerability in the keyboard layout handling on Windows XP SP3 - 8:05:12 - patch-info.de:
http://translate.googleusercontent.com/translate_c?hl=en&ie=UTF8&prev=_t&rurl=translate.google.com&sl=de&tl=en&u=http://patch-info.de/artikel/2012/05/08/1324&usg=ALkJrhgcu5tcIlkGoRk0XYjsGBlgYvLePw
397 additional answers
    2012-08-18T21:31:05+00:00
    I have attempted to manually update the security message but got a message saying due to prerequisites missing [KB2686509.log]
    1.531: ================================================================================
    1.531: 2012/08/16 18:06:46.015 (local)
    1.546: C:\WINDOWS\SoftwareDistribution\Download\3438087687b5dd8accc81e44f72f02e7\update\update.exe (version 6.3.13.0)
    1.578: DoInstallation: GetProcAddress(InitializeCustomizationDLL) Returned: 0x7f
    1.578: Failed To Enable SE_SHUTDOWN_PRIVILEGE
    1.609: Hotfix started with following command line: -q -z -er /ParentInfo:5c7d3dc7c5cecd41bf6507d5d873f857
    1.609: In Function GetReleaseSet, line 1240, RegQueryValueEx failed with error 0x2
    1.703: Return Value From IsMachineSafe = 0
    1.703: IsMachineSafe returned 441092
    1.703: Fist Condition in Prereq.IsMachineSafe.Section Failed
    1.703: Condition Check for Line 1 of PreRequisite returned FALSE
    1.718: ReadStringFromInf: UpdSpGetLineText failed: 0xe0000102
    1.718: KB2686509 Setup encountered an error:  Setup cannot continue because one or more prerequisites required to install KB2686509 failed. For More details check the Log File c:\windows\KB2686509.log
    1.734: ReadStringFromInf: UpdSpGetLineText failed: 0xe0000102
    1.734: Setup cannot continue because one or more prerequisites required to install KB2686509 failed. For More details check the Log File c:\windows\KB2686509.log
    1.734: Update.exe extended error code = 0xf0f4
    16.312: ================================================================================
    16.312: 2012/08/17 18:00:53.499 (local)
    16.344: C:\WINDOWS\SoftwareDistribution\Download\3438087687b5dd8accc81e44f72f02e7\update\update.exe (version 6.3.13.0)
    37.015: DoInstallation: GetProcAddress(InitializeCustomizationDLL) Returned: 0x7f
    37.015: Failed To Enable SE_SHUTDOWN_PRIVILEGE
    37.047: Hotfix started with following command line: -q -z -er /ParentInfo:315063ebf3b1d74cadbe90ad913f279f
    37.078: In Function GetReleaseSet, line 1240, RegQueryValueEx failed with error 0x2
    37.219: Return Value From IsMachineSafe = 0
    37.219: IsMachineSafe returned 441092
    37.219: Fist Condition in Prereq.IsMachineSafe.Section Failed
    37.219: Condition Check for Line 1 of PreRequisite returned FALSE
    37.234: ReadStringFromInf: UpdSpGetLineText failed: 0xe0000102
    37.234: KB2686509 Setup encountered an error:  Setup cannot continue because one or more prerequisites required to install KB2686509 failed. For More details check the Log File c:\windows\KB2686509.log
    37.250: ReadStringFromInf: UpdSpGetLineText failed: 0xe0000102
    37.250: Setup cannot continue because one or more prerequisites required to install KB2686509 failed. For More details check the Log File c:\windows\KB2686509.log
    37.250: Update.exe extended error code = 0xf0f4
    13.000: ================================================================================
    13.000: 2012/08/18 18:00:35.478 (local)
    13.015: C:\WINDOWS\SoftwareDistribution\Download\3438087687b5dd8accc81e44f72f02e7\update\update.exe (version 6.3.13.0)
    13.125: DoInstallation: GetProcAddress(InitializeCustomizationDLL) Returned: 0x7f
    13.125: Failed To Enable SE_SHUTDOWN_PRIVILEGE
    13.140: Hotfix started with following command line: -q -z -er /ParentInfo:3271827bd4df0b4cb29309c9e31c2d6f
    13.156: In Function GetReleaseSet, line 1240, RegQueryValueEx failed with error 0x2
    13.297: Return Value From IsMachineSafe = 0
    13.297: IsMachineSafe returned 441092
    13.297: Fist Condition in Prereq.IsMachineSafe.Section Failed
    13.297: Condition Check for Line 1 of PreRequisite returned FALSE
    13.328: ReadStringFromInf: UpdSpGetLineText failed: 0xe0000102
    13.328: KB2686509 Setup encountered an error:  Setup cannot continue because one or more prerequisites required to install KB2686509 failed. For More details check the Log File c:\windows\KB2686509.log
    13.344: ReadStringFromInf: UpdSpGetLineText failed: 0xe0000102
    13.344: Setup cannot continue because one or more prerequisites required to install KB2686509 failed. For More details check the Log File c:\windows\KB2686509.log
    13.344: Update.exe extended error code = 0xf0f4
    16.469: ================================================================================
    16.469: 2012/08/18 19:03:12.206 (local)
    16.500: C:\WINDOWS\SoftwareDistribution\Download\3438087687b5dd8accc81e44f72f02e7\update\update.exe (version 6.3.13.0)
    16.531: DoInstallation: GetProcAddress(InitializeCustomizationDLL) Returned: 0x7f
    16.531: Failed To Enable SE_SHUTDOWN_PRIVILEGE
    16.547: Hotfix started with following command line: -q -z -er /ParentInfo:b1fa0c0b4dad0a49bb25d5d91bddacf4
    16.547: In Function GetReleaseSet, line 1240, RegQueryValueEx failed with error 0x2
    16.672: Return Value From IsMachineSafe = 0
    16.672: IsMachineSafe returned 441092
    16.672: Fist Condition in Prereq.IsMachineSafe.Section Failed
    16.672: Condition Check for Line 1 of PreRequisite returned FALSE
    16.703: ReadStringFromInf: UpdSpGetLineText failed: 0xe0000102
    16.703: KB2686509 Setup encountered an error:  Setup cannot continue because one or more prerequisites required to install KB2686509 failed. For More details check the Log File c:\windows\KB2686509.log
    16.719: ReadStringFromInf: UpdSpGetLineText failed: 0xe0000102
    16.719: Setup cannot continue because one or more prerequisites required to install KB2686509 failed. For More details check the Log File c:\windows\KB2686509.log
    16.719: Update.exe extended error code = 0xf0f4
    11.047: ================================================================================
    11.047: 2012/08/19 07:21:13.609 (local)
    11.047: c:\e3d66e91db71b77e1881ffbd\update\update.exe (version 6.3.13.0)
    11.094: DoInstallation: GetProcAddress(InitializeCustomizationDLL) Returned: 0x7f
    11.110: Hotfix started with following command line:
    11.328: In Function GetReleaseSet, line 1240, RegQueryValueEx failed with error 0x2
    11.391: CreateUserInterface:  GetProcAddress for DefineInstallCustomUI failed:  0x7f
    11.907: Return Value From IsMachineSafe = 0
    11.907: IsMachineSafe returned 441092
    11.907: Fist Condition in Prereq.IsMachineSafe.Section Failed
    11.907: Condition Check for Line 1 of PreRequisite returned FALSE
    11.922: ReadStringFromInf: UpdSpGetLineText failed: 0xe0000102
    11.922: KB2686509 Setup encountered an error:  Setup cannot continue because one or more prerequisites required to install KB2686509 failed. For More details check the Log File c:\windows\KB2686509.log
    11.938: ReadStringFromInf: UpdSpGetLineText failed: 0xe0000102
    11.938: Setup cannot continue because one or more prerequisites required to install KB2686509 failed. For More details check the Log File c:\windows\KB2686509.log
    27.110: Message displayed to the user: Setup cannot continue because one or more prerequisites required to install KB2686509 failed. For More details check the Log File c:\windows\KB2686509.log
    27.110: User Input: OK
    27.110: Update.exe extended error code = 0xf0f4
    27.110: Update.exe return code was masked to 0x643 for MSI custom action compliance.
    0.906: ================================================================================
    0.906: 2012/08/19 07:22:12.656 (local)
    0.906: c:\f9d4ef926baaba432713\update\update.exe (version 6.3.13.0)
    0.937: DoInstallation: GetProcAddress(InitializeCustomizationDLL) Returned: 0x7f
    0.937: Hotfix started with following command line:
    0.937: In Function GetReleaseSet, line 1240, RegQueryValueEx failed with error 0x2
    0.937: CreateUserInterface:  GetProcAddress for DefineInstallCustomUI failed:  0x7f
    1.000: Return Value From IsMachineSafe = 0
    1.000: IsMachineSafe returned 441092
    1.000: Fist Condition in Prereq.IsMachineSafe.Section Failed
    1.000: Condition Check for Line 1 of PreRequisite returned FALSE
    1.015: ReadStringFromInf: UpdSpGetLineText failed: 0xe0000102
    1.015: KB2686509 Setup encountered an error:  Setup cannot continue because one or more prerequisites required to install KB2686509 failed. For More details check the Log File c:\windows\KB2686509.log
    1.031: ReadStringFromInf: UpdSpGetLineText failed: 0xe0000102
    1.031: Setup cannot continue because one or more prerequisites required to install KB2686509 failed. For More details check the Log File c:\windows\KB2686509.log
    and to check log.
    Please can you advise me further. Thank you for your time.
    Regards
    David Brewer.
    2012-08-19T00:24:35+00:00
    @DavidBrewer only...
    1. Is it the same computer as in this previous thread of yours? =>  http://answers.microsoft.com/en-us/ie/forum/ie8-windows_xp/trying-to-download-and-install-internet-explorer-8/0c68d9ac-5b45-4169-a65e-54d5f882111c
    Open Add/Remove Programs & make sure the Show Updates box at the top is checked (and leave it checked); then select the Name option in the Sort by box on the right. Now scroll down & tell me if ALL of the following other updates are listed?
        (a) KB2722913, KB2723135, KB2705219, KB2712808 & KB2731847;
        (b) KB2698365, KB2691442, KB2655992 & KB2719985;
        (c) KB2707511, KB2676562, KB2659262 & KB2695962
        (d) KB2653956; KB2661637, KB2598479, KB2631813 & KB2585542
        (e) KB2393802 and especially Update for Windows XP (KB971029).
    2012-08-19T11:07:53+00:00
    your update really works! Thank you!!!
    I had neither the entry of the files listed in faultykeyboard.log (bd101.dll) nor the files elsewhere .
    Mathias
