KB2686509 repeatedly fails with Error code 0x8007F0F4
2012-05-08T19:14:06+00:00
2012-05-15T03:18:54+00:00
This is obsolete
I wrote a VB Script to fix two problems while running microsoft security update KB2686509
HKLM\SYSTEM\CurrentControlSet\Control\Keyboard LayoutandHKLM\SYSTEM\CurrentControlSet\Control\Keyboard Layouts
for those who are no registry freaks.
*Here you can download my little hotfix as ZIP-file.*
What does it do? Nothing magic!
1. Makes a registry backup
2. delete entries in Keyboard Layout
3. checks every keyentry in Keyboard Layouts against existing file in %SystemRoot%\System32
Hope I help someone with this script.
Regards
Christian from Germany
Update 2012/06/03
I have written a batch file too. So you can use this instead the vbs solution.
It's a little bit harder, because the batch file exports the two keys, deletes them, creates blank entries. Then you have to run the KB2686509 again! After doing this do not reboot, press continue in the command window (restoring old entries) and then reboot.
If one of the (bad) keys does not exists, the batch file creates a blank entry, so KB2686509 should work.
Here you can download the batch file http://www.vivus.net/dl/
2012-05-08T22:52:59+00:00
New instructions OF 6/19/2012
The FIX-IT’s for this KB have been released today for this Security update. They are available for download at : http://support.microsoft.com/kb/2686509
Since we’ve figured it out, can you see if any of these solutions fixes you up?
Edit on Sunday 5/13 - I figured out the problem.  I had remapped a keyboard key.
If you are hitting this error and do NOT have a faultykeyboard.log file see if you can follow this post and get the patch installed:
KB2686509 - Failure - due to remapping of a key - TechNet Articles - United States (English) - TechNet Wiki:
http://social.technet.microsoft.com/wiki/contents/articles/10829.kb2686509-failure-due-to-remapping-of-a-key.aspx
If you upgraded from Windows ME or 98 to XP (you see nothing but .kbd files listed in your faultykeyboard.log file) -- follow this post:
KB2686509 - Failure - due to upgrade from Windows ME or 98 to Windows XP - TechNet Articles - United States (English) - TechNet Wiki:
http://social.technet.microsoft.com/wiki/contents/articles/10876.kb2686509-failure-due-to-upgrade-from-windows-me-or-98-to-windows-xp.aspx
If you have DLLs noted in the faultykeyboard.log file but can't find them on your PC follow this post:
KB2686509 - Failure due to missing DLL files - TechNet Articles - United States (English) - TechNet Wiki:**http://social.technet.microsoft.com/wiki/contents/articles/10880.kb2686509-failure-due-to-missing-dll-files.aspx**
IF NONE OF THESE WORK, email susan-at-msmvps.com and I'll have someone from Microsoft call you back to fix your system.
Freudi always posts great analysis:
2686509 (MS12-034) - Vulnerability in the keyboard layout handling on Windows XP SP3 - 8:05:12 - patch-info.de:
http://translate.googleusercontent.com/translate_c?hl=en&ie=UTF8&prev=_t&rurl=translate.google.com&sl=de&tl=en&u=http://patch-info.de/artikel/2012/05/08/1324&usg=ALkJrhgcu5tcIlkGoRk0XYjsGBlgYvLePw
397 additional answers
    2012-07-17T07:23:49+00:00
    cseman,
    I held off for his reply, but...
    I was going to suggest that you put  KB2718704 on since it is missing, and that the log file might be misplaced due to the VM thing, and/or the keyboard fix that won't go on might be looking at the system (VM) registry instead of the one of the partition, etc.  You could try a system search for faultykeyboard, and try putting that missing fix on, just for kicks.  Good Luck!
    2012-07-17T15:16:01+00:00
    Security Update for Windows XP (KB2686509)  **Error Code:**0x8007F0F4;
    I have tried to download Fix it 50882 but when I run it reports not applicable for this system or application. I am running windows XP Professional 2002 Service pack 3.
    Regedit :Keyboard Layout only contains the file (Default) reg_SZ. (Value not set).
    Values for KB2686509.log are:
    3.969: ================================================================================
    3.969: 2012/07/17 01:25:03.390 (local)
    3.969: C:\WINDOWS\SoftwareDistribution\Download\3438087687b5dd8accc81e44f72f02e7\update\update.exe (version 6.3.13.0)
    3.985: DoInstallation: GetProcAddress(InitializeCustomizationDLL) Returned: 0x7f
    3.985: Failed To Enable SE_SHUTDOWN_PRIVILEGE
    3.985: Hotfix started with following command line: -q -z -er /ParentInfo:126a5c86853db44db12926ed78299676
    4.016: In Function GetReleaseSet, line 1240, RegQueryValueEx failed with error 0x2
    4.047: Return Value From IsMachineSafe = 0
    4.047: IsMachineSafe returned 441092
    4.047: Fist Condition in Prereq.IsMachineSafe.Section Failed
    4.047: Condition Check for Line 1 of PreRequisite returned FALSE
    4.047: ReadStringFromInf: UpdSpGetLineText failed: 0xe0000102
    4.047: KB2686509 Setup encountered an error:  Setup cannot continue because one or more prerequisites required to install KB2686509 failed. For More details check the Log File c:\windows\KB2686509.log
    4.047: Setup cannot continue because one or more prerequisites required to install KB2686509 failed. For More details check the Log File c:\windows\KB2686509.log
    4.047: Update.exe extended error code = 0xf0f4
    Any assistance would be greatly appreciated, Thank you,
    A. Clarke
    2012-07-19T19:49:04+00:00
    I'm also getting this failure. My XP system was originally ME. I also have a faultykeyboard.log which contains
    kbdsp.kbd
    kbdsp.kbd
    kbdno.kbd
    kbdla.kbd
    kbdla.kbd
    kbdla.kbd
    kbdla.kbd
    kbdla.kbd
    kbdus.kbd
    kbdla.kbd
    kbdus.kbd
    kbdla.kbd
    kbdla.kbd
    kbdla.kbd
    kbdla.kbd
    kbdla.kbd
    kbdla.kbd
    kbdla.kbd
    kbdla.kbd
    kbdla.kbd
    kbdla.kbd
    kbdla.kbd
    kbdla.kbd
    kbdycl.kbd
    and was last updated the last time I tried to install the update.
    The KB2686509 log shows the same error as in 74astrosweep's posting.
