KB2686509 repeatedly fails with Error code 0x8007F0F4
2012-05-08T19:14:06+00:00
2012-05-15T03:18:54+00:00
This is obsolete
I wrote a VB Script to fix two problems while running microsoft security update KB2686509
HKLM\SYSTEM\CurrentControlSet\Control\Keyboard LayoutandHKLM\SYSTEM\CurrentControlSet\Control\Keyboard Layouts
for those who are no registry freaks.
*Here you can download my little hotfix as ZIP-file.*
What does it do? Nothing magic!
1. Makes a registry backup
2. delete entries in Keyboard Layout
3. checks every keyentry in Keyboard Layouts against existing file in %SystemRoot%\System32
Hope I help someone with this script.
Regards
Christian from Germany
Update 2012/06/03
I have written a batch file too. So you can use this instead the vbs solution.
It's a little bit harder, because the batch file exports the two keys, deletes them, creates blank entries. Then you have to run the KB2686509 again! After doing this do not reboot, press continue in the command window (restoring old entries) and then reboot.
If one of the (bad) keys does not exists, the batch file creates a blank entry, so KB2686509 should work.
Here you can download the batch file http://www.vivus.net/dl/
2012-05-08T22:52:59+00:00
New instructions OF 6/19/2012
The FIX-IT’s for this KB have been released today for this Security update. They are available for download at : http://support.microsoft.com/kb/2686509
Since we’ve figured it out, can you see if any of these solutions fixes you up?
Edit on Sunday 5/13 - I figured out the problem.  I had remapped a keyboard key.
If you are hitting this error and do NOT have a faultykeyboard.log file see if you can follow this post and get the patch installed:
KB2686509 - Failure - due to remapping of a key - TechNet Articles - United States (English) - TechNet Wiki:
http://social.technet.microsoft.com/wiki/contents/articles/10829.kb2686509-failure-due-to-remapping-of-a-key.aspx
If you upgraded from Windows ME or 98 to XP (you see nothing but .kbd files listed in your faultykeyboard.log file) -- follow this post:
KB2686509 - Failure - due to upgrade from Windows ME or 98 to Windows XP - TechNet Articles - United States (English) - TechNet Wiki:
http://social.technet.microsoft.com/wiki/contents/articles/10876.kb2686509-failure-due-to-upgrade-from-windows-me-or-98-to-windows-xp.aspx
If you have DLLs noted in the faultykeyboard.log file but can't find them on your PC follow this post:
KB2686509 - Failure due to missing DLL files - TechNet Articles - United States (English) - TechNet Wiki:**http://social.technet.microsoft.com/wiki/contents/articles/10880.kb2686509-failure-due-to-missing-dll-files.aspx**
IF NONE OF THESE WORK, email susan-at-msmvps.com and I'll have someone from Microsoft call you back to fix your system.
Freudi always posts great analysis:
2686509 (MS12-034) - Vulnerability in the keyboard layout handling on Windows XP SP3 - 8:05:12 - patch-info.de:
http://translate.googleusercontent.com/translate_c?hl=en&ie=UTF8&prev=_t&rurl=translate.google.com&sl=de&tl=en&u=http://patch-info.de/artikel/2012/05/08/1324&usg=ALkJrhgcu5tcIlkGoRk0XYjsGBlgYvLePw
397 additional answers
    2012-05-09T09:24:09+00:00
    Here's a Process Monitor log file of KB2686509 trying to install in case someone at MS wants to have a look.
    2012-05-09T09:40:06+00:00
    Hmm, I did a registry edit a long time ago to disable the left windows key, I'm guessing that may be a factor.
    Yes! That did it. I had turned off my Windows keys with a registry edit because I would press it by mistake when in full screen games.
    I just ran the Microsoft Fix-it
    Enable the Windows key
    Microsoft Fix it 50464
    from here: http://support.microsoft.com/kb/216893
    Rebooted and bam. The update installed fine!
    Thanks!
    2012-05-09T09:44:01+00:00
    I had custom scancode mappings to disable winkeys from a long time ago.
    After removing my scancode mappings with the following registry file the update successfully finished:
    Windows Registry Editor Version 5.00
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout]
    "Scancode Map"=-
    For further troubleshooting I'm enclosing the critical parts of the update logs:
    Failed log:
    2.172: In Function GetReleaseSet, line 1240, RegQueryValueEx failed with error 0x2
    10.907: Return Value From IsMachineSafe = 0
    10.907: IsMachineSafe returned 441092
    10.907: Fist Condition in Prereq.IsMachineSafe.Section Failed
    10.907: Condition Check for Line 1 of PreRequisite returned FALSE
    Successful log:
    2.641: In Function GetReleaseSet, line 1240, RegQueryValueEx failed with error 0x2
    3.078: Return Value From IsMachineSafe = 1
    3.078: IsMachineSafe returned 441092
    3.156: Return Value From IsMachineSafe = 1
    3.156: IsMachineSafe returned value( 0x1 ) which is Equal To 0x1
    3.156: Condition succeeded for section Prereq.IsMachineSafe.Section in Line 1 of PreRequisite
