KB2686509 repeatedly fails with Error code 0x8007F0F4
2012-05-08T19:14:06+00:00
2012-05-15T03:18:54+00:00
This is obsolete
I wrote a VB Script to fix two problems while running microsoft security update KB2686509
HKLM\SYSTEM\CurrentControlSet\Control\Keyboard LayoutandHKLM\SYSTEM\CurrentControlSet\Control\Keyboard Layouts
for those who are no registry freaks.
*Here you can download my little hotfix as ZIP-file.*
What does it do? Nothing magic!
1. Makes a registry backup
2. delete entries in Keyboard Layout
3. checks every keyentry in Keyboard Layouts against existing file in %SystemRoot%\System32
Hope I help someone with this script.
Regards
Christian from Germany
Update 2012/06/03
I have written a batch file too. So you can use this instead the vbs solution.
It's a little bit harder, because the batch file exports the two keys, deletes them, creates blank entries. Then you have to run the KB2686509 again! After doing this do not reboot, press continue in the command window (restoring old entries) and then reboot.
If one of the (bad) keys does not exists, the batch file creates a blank entry, so KB2686509 should work.
Here you can download the batch file http://www.vivus.net/dl/
2012-05-08T22:52:59+00:00
New instructions OF 6/19/2012
The FIX-IT’s for this KB have been released today for this Security update. They are available for download at : http://support.microsoft.com/kb/2686509
Since we’ve figured it out, can you see if any of these solutions fixes you up?
Edit on Sunday 5/13 - I figured out the problem.  I had remapped a keyboard key.
If you are hitting this error and do NOT have a faultykeyboard.log file see if you can follow this post and get the patch installed:
KB2686509 - Failure - due to remapping of a key - TechNet Articles - United States (English) - TechNet Wiki:
http://social.technet.microsoft.com/wiki/contents/articles/10829.kb2686509-failure-due-to-remapping-of-a-key.aspx
If you upgraded from Windows ME or 98 to XP (you see nothing but .kbd files listed in your faultykeyboard.log file) -- follow this post:
KB2686509 - Failure - due to upgrade from Windows ME or 98 to Windows XP - TechNet Articles - United States (English) - TechNet Wiki:
http://social.technet.microsoft.com/wiki/contents/articles/10876.kb2686509-failure-due-to-upgrade-from-windows-me-or-98-to-windows-xp.aspx
If you have DLLs noted in the faultykeyboard.log file but can't find them on your PC follow this post:
KB2686509 - Failure due to missing DLL files - TechNet Articles - United States (English) - TechNet Wiki:**http://social.technet.microsoft.com/wiki/contents/articles/10880.kb2686509-failure-due-to-missing-dll-files.aspx**
IF NONE OF THESE WORK, email susan-at-msmvps.com and I'll have someone from Microsoft call you back to fix your system.
Freudi always posts great analysis:
2686509 (MS12-034) - Vulnerability in the keyboard layout handling on Windows XP SP3 - 8:05:12 - patch-info.de:
http://translate.googleusercontent.com/translate_c?hl=en&ie=UTF8&prev=_t&rurl=translate.google.com&sl=de&tl=en&u=http://patch-info.de/artikel/2012/05/08/1324&usg=ALkJrhgcu5tcIlkGoRk0XYjsGBlgYvLePw
397 additional answers
    2012-05-11T08:14:32+00:00
    For now, hide the thing until I can convince someone at Microsoft to build a FixIT tool.
    Just post a "me too" here indicating that you are an XP.
    With all due respect Bear, I wouldn't do a new thread, I'd pile on this one and showcase the body count.
    I have one here, testing another myself.
    me too
    2012-05-11T08:09:29+00:00
    Hmm, I did a registry edit a long time ago to disable the left windows key, I'm guessing that may be a factor.
    Yes! That did it. I had turned off my Windows keys with a registry edit because I would press it by mistake when in full screen games.
    I just ran the Microsoft Fix-it
    Enable the Windows key
    Microsoft Fix it 50464
    from here: http://support.microsoft.com/kb/216893
    Rebooted and bam. The update installed fine!
    Thanks!
    Hi there, thanks for this info / update, that might even work...
    Question again on your quote, if i diabled the WinKey, reboot pc/server, install the Fix: kb2686509
    Can I Enable the WinKey again after installing the Fix?
    (and again reboot, so 3 reboots are needed, verry silly though...)
    2012-05-11T00:45:18+00:00
    @Wmassey,
    Also had nearly identical faultykeyboard.log as you did on WIN XP SP3 Dell.  It appears that XP uses only kbd*.dll  files for keyboard mapping.  Not sure where my registry *.kbd files came from but this machine was upgraded from a ME system at least, so possibly left over from that???  Like you I could not locate any *.kbd files on this computer.
    There may be more than 75 "kbd*.kbd" entries in my registry, so does anyone know if I can safely delete them all at one time (don't think you can use wildcard * in search)?  Perhaps MS will make a HOTFIX that might do that.
    I don't think I have ever deleted a registry key, so I'm a little afraid of doing that.
    One other possible issue for me (or others) might be that this Dell has a program, DELLTOUCH which enables mapping of extra buttons on this extended function keyboard, which for example, launch email or navigate to home page.  I'm guessing this is also in the registry somewhere.  Not sure if it might interefere with patch.
