Ralink/Motorola BC8 Bluetooth 3.0 + HS Adapter not working on windows 8
2012-11-01T04:36:34+00:00
I have a HP dv6 6119tx laptop that had windows 7 pre installed. The Ra link/Motorola BC8 Bluetooth 3.0 + HS Adapter is not working on windows 8, which worked perfect on windows 7, I checked through all HP resources for the drivers and installed the latest one too, but the adapter is not working as desired after the experience I had while working with Bluetooth on Windows 7. Please Help me to make the adapter work properly on windows 8
2013-05-11T19:41:11+00:00
Below solution worked for me
1.       Open Device manager
2.       Right click on Bluetooth driver and click on update
3.       Click on “Browse my computer for driver software”
4.       Click on “Let me pick from a list of driver in my computer”
5.       Un check “Show compatible hardware” checkbox
6.       Select Cambridge silicon Radio Ltd
7.       Select “Generic Bluetooth radio”
8.       Click next
9.       Click finish
2013-05-09T19:36:22+00:00
Hello All,
Finally the Bluetooth is working for me now. What you need to do is install Motorola RALINK Bluetooth Windows 7 drivers in compatibility mode and check if that does the trick.
Install the driver in Compatibility mode:
a.       Download theMotorola RALINK Bluetooth driver for Windows 7 from the manufacturer’s website and save it on your local disk.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-99320-1&cc=us&dlc=en&lc=en&os=4062&product=5239406&query=%20Pavilion%20g6-2016tx&sw_lang=&tool=
b.      Right click on the setup file of the driver and select “Properties”.
c.       Select “Compatibility” Tab.
d.      Place a check mark next to “Run this program in Compatibility mode” and select Windows 7 from the drop down list.
e.      Let the driver install and then check the functionality.
50 additional answers
    2014-05-19T15:54:05+00:00
     Try deleting and removing all Bluetooth garbage, restart computer, re-install adapter, go to drivers, select your own, un-check box, look for   BCM2033 Bluetooth 2.4 GHz Single Chip Transceiver under the Broadcom subtitle.  I have tried everything and this worked. I am not very savvy with technical terms but the the driver that worked in Windows 7 will not work and that is no one has come up with new driver.
    This worked for me.
    with windows 8.1 pro x64
    2016-04-14T18:20:39+00:00
    1.open device manager
    2.right click-go to properties
    3.Enable
    done dats it.it worked for me..i too have a hp dv6 laptop.
