Ralink/Motorola BC8 Bluetooth 3.0 + HS Adapter not working on windows 8
2012-11-01T04:36:34+00:00
I have a HP dv6 6119tx laptop that had windows 7 pre installed. The Ra link/Motorola BC8 Bluetooth 3.0 + HS Adapter is not working on windows 8, which worked perfect on windows 7, I checked through all HP resources for the drivers and installed the latest one too, but the adapter is not working as desired after the experience I had while working with Bluetooth on Windows 7. Please Help me to make the adapter work properly on windows 8
2013-05-11T19:41:11+00:00
Below solution worked for me
1.       Open Device manager
2.       Right click on Bluetooth driver and click on update
3.       Click on “Browse my computer for driver software”
4.       Click on “Let me pick from a list of driver in my computer”
5.       Un check “Show compatible hardware” checkbox
6.       Select Cambridge silicon Radio Ltd
7.       Select “Generic Bluetooth radio”
8.       Click next
9.       Click finish
2013-05-09T19:36:22+00:00
Hello All,
Finally the Bluetooth is working for me now. What you need to do is install Motorola RALINK Bluetooth Windows 7 drivers in compatibility mode and check if that does the trick.
Install the driver in Compatibility mode:
a.       Download theMotorola RALINK Bluetooth driver for Windows 7 from the manufacturer’s website and save it on your local disk.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-99320-1&cc=us&dlc=en&lc=en&os=4062&product=5239406&query=%20Pavilion%20g6-2016tx&sw_lang=&tool=
b.      Right click on the setup file of the driver and select “Properties”.
c.       Select “Compatibility” Tab.
d.      Place a check mark next to “Run this program in Compatibility mode” and select Windows 7 from the drop down list.
e.      Let the driver install and then check the functionality.
50 additional answers
    2013-02-27T17:46:48+00:00
    I have issue with BCM2033 Bluetooth 2.4 GHz Single Chip Transceiver, but Blutonium BCM2035 Bluetooth 2.4 GHz Single Chip Transceiver work well.
    Successful pairing with Microsoft Bluetooth Notebook Mouse 5000 and Samsung HS3000
    2013-02-27T18:08:07+00:00
    same problem having same laptop as u dv 6 6119tx. i made a call at hp also but they r saying we have some issues or technical probs but we are working on it. but no solution till now facing this problem since i upgraded to windows 8.
    2013-03-09T04:18:30+00:00
    I had the same problem with HP Pavilion dm1z 3200 after upgrading to Windows 8 and tried all the listed suggestions but none worked until I installed a 3rd party driver from bluesoleil and it installed and paired perfectly. One downside is the software is only a trial version for 30 days. You can downloadit here: http://www.bluesoleil.com/products/S0001201005190001.html. Full version will cost $27.99.
    You can also download older versions for free but I haven't tested its compatibility with Windows 8 yet. I'm gonna ride this trial version for the next 30 days and worry about it when the trial version is up.
