Error code 641 and code 80070641?
2012-05-23T15:10:07+00:00
When attempting to download updates I get an error message that indicates code 641 and code 80070641?  What does this mean?
2012-06-01T18:16:21+00:00
   I use Vista Business Service Pack 2.  I also use System Mechanic Pro for registry cleaning and other repairs.  Sorry, not sure which green button I needed to unmark-can you let me know?
Thanks!
The very topmost one.  Assuming you had marked Answer before, then click the UNMARK green icon to clear it (first).
Windows update exception code 0x00000641 / 0x80070641 usually indicates an issue with the Windows Installer service.
Sometimes it is due to a difficulty in accessing it; sometimes it means it's missing, or inactive (disabled) for some reason.
If you have used Iolo System Mechanic for automated (auto-fix) runs, and have these exception codes, the cause is an overagressive fix by this app.
First suggestion is to Undo recent fixes by S M, then insure it's not set to autorun or autofix.
Do NOT keep using System Mechanic until there is a permanent fix from Iolo.
Contact Iolo support (iolo.com)
and demand a permanent fix.
System Mechanic "registry cleaning" has put a double whammy on your system in having removed two registry keys.
The following will put things back in order for the registry {at least for the Installer service}, so that you can then proceed to redo Windows Update.
This are for VISTA systems <<<---
Download this file from Ramesh S http://www.winhelponline.com/fileasso/regfix\_vista.zip
Save it to your DESKTOP.
EXtract the contents to your DESKTOP.
go to Start, type in
REGEDIT and press Enter-key
from main menu, select File
then select IMPORT
navigate the dialog (click on DESKTOP icon on left to select it)
type in regfix_vista.reg in the Filename text-box and click Open button.
Once the merge is complete, you will see a confirmation message.
Click OK when done.
Next, get this second registry-fix
Download and SAVE to your system (to the Desktop or a unique folder) the following registry-fix file
http://download.bleepingcomputer.com/win-services/vista/msiserver.reg
Do a RIGHT-Click on msiserver.reg file and select MERGE
Allow it to merge into the registry.
If prompted by UAC User Account Control, allow to proceed.
IF and only if, the Merge option is not available, then double-click on the file and allow it to merge into the registry.
IF and ".reg" file pops up in REGEDIT, when prompted whether to Merge answer Yes.
When done with the two registry fixes, Exit / close REGEDIT.
then Logoff and Restart Windows fresh.
Now, retry Windows Update in a new run.
Just only do a Custom scan.
select just the Critical or Important updates. (un-select any optional ones).
Let me know if this helps. and if so, kindly click the green YES (Helpful) icon to the left.
If this solves your issue, kindly click on green MARK It icon on the right.
42 additional answers
    2012-07-09T22:41:33+00:00
    I'm not a computer pro, geek, whiz, whatever, but this solution worked perfectly for me on Vista Home Premium X64 after my Windows Installer was removed by Iolo.
    2012-07-18T22:07:33+00:00
    Thank you for the feedback, GSXATC.
    Cheers.
