Hi all,
I recently used the error checking tool on my internal hard drive on my laptop. It found errors and told me to reboot. Now everytime I boot my pc a message in the action center pops up saying "Restart to repair drive errors", and no matter how many times I
try, it still tells me there are drive errors.
I can't seem to find any more details on the exact errors. I run Windows 8 Pro. Can anyone help me or point me in the right direction?
EDIT: Running Chkdsk from the command promt returns a similar error, albeit a little more wordy: "Chkdsk cannot run because the volume [the C: drive, the one that has errors -RF] in in use by another process. Would you like to schedule this volume to be checked
the next time the system restarts?" Replying <y> and rebooting, gives the same errors: the action center still tells me to reboot, and Chkdsk returns the same message as before.
I also tried running sfc, just for good measure. The log created (CBS.log) shows several errors at the bottom, seemingly all pertaining to autochk.exe, in some way or another.
I wonder if this may have been caused by running drive optimization and stopping prematurely (in order to reboot for the error checking utility).
