I'm downloading the 32 bit driver,* however, since I wrote,,,,,
I went back and did the system HDA controller removal again. It would reinstall themselves as quickly as I deleted them this time. I uninstalled the audio drivers and was able to then take out the system controllers.
I uninstalled everything I could find on all and any audio device, realtek, CMI, etc. and even removed my USB3 PCI card. I booted and got a bunch of junk (shoulda saved the picture on another drive) that talked about trusted Microsoft audio driver. I also
got 2 unknown Multimedia devices. I reinstalled the CMI card (since is has worked) and booted. Found the same trusted Microsoft driver and 2 unknown devices. I Installed the CMI driver and some of that cleared up. Tried Realtek again. Found another PCI card
that had a CMI chip..... no luck, no change.
I went outside and beat the dog, came back in and restored the system from back up that I mentioned I was gonna make after I had the sound running. (I don't really have a dog)
Yes; I had SOUND.
I immediately restarted, as soon as I could get the system's attention. I STILL have sound. Conclusion: This has to be a software issue. Now: what changes the software?
But wait; there's more!!!
I did not disable the on-board realtek audio in the BIOS. Guess what? It shows good and sound comes out if it just like the CMI speakers. I can direct play back to either output. HDA is still unhappy.
My plans:
- NOT turn this PC off or reboot for a few days.
- NOT install anything at all.
- Give my buddy Auggy a few days off, if you wish!
I realize all my 'wonderful' helper applications are gonna be busy trying to load stuff but... I will wait and see.
Thanks, once more,
E.
_____________________
*****Long story short, this is a 64bit PC and I have 32bit Win8 running.
