Vari bright option:
Power -> Power Play -> uncheck Enable Vari-Bright
Everytime I disconnect my AC power cord Windows 8 shows a Erro Dialog:
Runtime Error!
Program: C:\WINDOWS\system32\atibtmon.exe
This application has requested the Runtime to terminate it in an unusual way.
Please contact the application's support team for more information.
Anyone having the same problem?
Any hotfix for this?
Computer: DELL XPS Studio 16
Vari bright option:
Unchecking the "Vari Bright" option in the ATI Catalyst Control Center resolved the issue for me as well. It seems this option dims the brightness of the display when unplugged; however, I believe Windows also does this (or, at least it does on my Dell XPS 16). Perhaps two programs attempting to essentially do the same thing are the cause of the atibtmon issue?
I encountered this problem with my Pavilion DV6 after upgrading to W8 64bit as well and it's more irritating than it ought to be. For what it's worth though, I opened the AMD Vision Engine Control Center and disabled the "Vari Bright" option under the Power tab and that seemed to fix getting the error message every time my laptop is unplugged. Doesn't fix the underlying problem and will will decrease my unplugged-time a bit, but I can live with that.
Thanks for the legwork though, Amiarage. Looks like we;ll need to content ourselves with waiting for ATI to fix it.
Yes, I am using Windows 8 64 bit and under my ATI Catalyst Control Center under the "Power" section I don't seem to have a "Vari Bright" option..
I also don't have a Vari Bright option. In the AMD VISION Engine Control Center, I have two options, Power and Performance. In the Power option, there's three choices, Wi-Fi Radio, Power Profiles, and CPU Power. In the Power Profiles option, there's nothing about Vari Bright. I've got a HP Pavilion dv7.
I got the same problem while reinstalling windows 7 on my mother's computer, but it's easy to fix.
The problem is that you have to get your drivers from acer for example, or other notebook maker site, and get the older drivers version. I got mine here and it work fine now.
Click here to get it. It should work on other notebook maker, as long as you have a similar graphic card. Just remember to uninstall the previous driver first. Problem solved.
