Vari bright option:
Power -> Power Play -> uncheck Enable Vari-Bright
Everytime I disconnect my AC power cord Windows 8 shows a Erro Dialog:
Runtime Error!
Program: C:\WINDOWS\system32\atibtmon.exe
This application has requested the Runtime to terminate it in an unusual way.
Please contact the application's support team for more information.
Anyone having the same problem?
Any hotfix for this?
Computer: DELL XPS Studio 16
Vari bright option:
Unchecking the "Vari Bright" option in the ATI Catalyst Control Center resolved the issue for me as well. It seems this option dims the brightness of the display when unplugged; however, I believe Windows also does this (or, at least it does on my Dell XPS 16). Perhaps two programs attempting to essentially do the same thing are the cause of the atibtmon issue?
I encountered this problem with my Pavilion DV6 after upgrading to W8 64bit as well and it's more irritating than it ought to be. For what it's worth though, I opened the AMD Vision Engine Control Center and disabled the "Vari Bright" option under the Power tab and that seemed to fix getting the error message every time my laptop is unplugged. Doesn't fix the underlying problem and will will decrease my unplugged-time a bit, but I can live with that.
Thanks for the legwork though, Amiarage. Looks like we;ll need to content ourselves with waiting for ATI to fix it.
I am also having this problem. I am also using the Dell Studio XPS 16.
I upgraded to Windows 8 Pro, 64-bit yesterday. However, the problem did not occur until I installed the ATI drivers this afternoon.
I'm sorry, where is the "Vari Bright" option? I can't seem to locate it.
