How do I mass delete junk mail in Hotmail on Windows 8?
2012-11-22T20:52:08+00:00
How can I mass delete emails from my junk and deleted folder?  Takes too long to highlight and delete 7 or 8 at a time.
2012-11-24T13:51:42+00:00
Hi atomikbomb,
Certainly, there is an option of delete all of these emails in the Junk and deleted folders. There are two ways of going about manually- which means, you have to perform yourself the steps below:
  1. After signing in to your account, go to each of this folder.
  2. On the top of these emails, tick the box before the word ALL.
  3. Click delete menu above Junk or Deleted folder.
Another way to do it manually is doing the following steps:
  1. Hover the mouse cursor over the folder.
  2. Right click and choose empty folder.
Thanks!
48 additional answers
    2012-12-02T10:30:07+00:00
    guys i was having the same problem but now i found out that you can just do ctrl+a (that selects all) then click delete
    2012-12-01T22:09:10+00:00
    They are using the mail app. I am needing an answer to the same issue.
    2012-11-26T03:45:52+00:00
    Hi atomikbomb,
    Are you accessing your account on your Windows 8 PC using a web browser or using the Mail app?
    Please let us know so we can isolate the issue.
    Thanks.
    Johan
    2012-11-25T03:40:59+00:00
    There is no box or word that says ALL in the folders nor does hovering over them do anything.  But thanks for the idea!
