wifi does not have a valid ip configuration windows 8
2012-10-29T11:59:17+00:00
After upgrading to Windows 8 Final Version
it worked fine for 2 days then, WIFI stoped working.
every time I try to connect it gives me limited connection.
when I try trouble shout it give me the following message :" wifi does not have a valid ip configuration ".
even trying a cable connection, same message appear.
I somehow managed to get on my neighbor WIFI not sure how that happened, but I can only use internet on Desktop mode,
Metro interface have no access to wifi.
I would like to know if you can assist me with this issue?
2012-11-15T05:51:36+00:00
I was having this problem too. Solved it by following the directions here:
http://www.eightforums.com/network-sharing/11811-windows-8-wifi-help.html
This part in the first reply fixed the problem:
"With upgrades sometimes winsock or the TCP/IP stack gets corrupted. To reset them both type the following two commands into an elevated command prompt one at a timehitting enter after each one then reboot the system.
netsh winsock reset catalog (reset winsock entries)
netsh int ip reset reset.log hit (reset TCP/IP stack)"
Hope this helps someone else.
Cheers.
91 additional answers
    2013-02-23T00:33:09+00:00
    I also did this and I was immediately connected to the web. Reinstalled and it worked fine. Hopefully MS Engineers address these issues soon as I've already encountered numerous bugs using W8.
    2013-02-23T04:09:14+00:00
    I just faced the same situation and ran through a troubleshoot and report given is ( wifi does not have a valid ip configuration - problem fixed).
    As for now the limited issue is gone and will monitor it for the next few days.
    2013-02-25T04:33:00+00:00
    Worked for me as well - THANKS!
    2013-02-26T09:41:10+00:00
    I did this and it didnt work for me.  After i do the second step i get the following
    Resetting Interface OK
    Resetting Neighbour OK
    Resetting PAth OK
    Resetting, failed
    Access is denied
    Resetting, OK
    Restart the computer to complete this action.
    Any Ideas on what the failed element is?
