wifi does not have a valid ip configuration windows 8
2012-10-29T11:59:17+00:00
After upgrading to Windows 8 Final Version
it worked fine for 2 days then, WIFI stoped working.
every time I try to connect it gives me limited connection.
when I try trouble shout it give me the following message :" wifi does not have a valid ip configuration ".
even trying a cable connection, same message appear.
I somehow managed to get on my neighbor WIFI not sure how that happened, but I can only use internet on Desktop mode,
Metro interface have no access to wifi.
I would like to know if you can assist me with this issue?
2012-11-15T05:51:36+00:00
I was having this problem too. Solved it by following the directions here:
http://www.eightforums.com/network-sharing/11811-windows-8-wifi-help.html
This part in the first reply fixed the problem:
"With upgrades sometimes winsock or the TCP/IP stack gets corrupted. To reset them both type the following two commands into an elevated command prompt one at a timehitting enter after each one then reboot the system.
netsh winsock reset catalog (reset winsock entries)
netsh int ip reset reset.log hit (reset TCP/IP stack)"
Hope this helps someone else.
Cheers.
91 additional answers
    2013-02-14T00:25:29+00:00
    Did not work for me either, sounds like a did you try turning it on and off again fix attempt...
    2013-02-15T18:55:58+00:00
    For the people who tried everything and couldnt find a solution like me ; I wanna share what worked for me after a week of suffering ... I have uninstalled all the intell based drivers and softwares for my wireless and bluetooth and after a restart windows  automatically  installed its own drivers ... And the problem got solved by itself.... I hope this one helps someone else besides me ... ;)
    2013-02-17T00:35:35+00:00
    The "netsh" commands do work for me, but I have to do this every few days.  I would like a PERMANENT fix.  Any suggestions are greatly appreciated.  Thank you.
    2013-02-17T00:58:34+00:00
    I second this request for a permanent fix, I'm also having to do this at least once a week!
    It's a PITA. C'mon Microsoft Engineers, how about something more from you guys other than just directing everyone to the useless Network Wizard.
