wifi does not have a valid ip configuration windows 8
2012-10-29T11:59:17+00:00
After upgrading to Windows 8 Final Version
it worked fine for 2 days then, WIFI stoped working.
every time I try to connect it gives me limited connection.
when I try trouble shout it give me the following message :" wifi does not have a valid ip configuration ".
even trying a cable connection, same message appear.
I somehow managed to get on my neighbor WIFI not sure how that happened, but I can only use internet on Desktop mode,
Metro interface have no access to wifi.
I would like to know if you can assist me with this issue?
2012-11-15T05:51:36+00:00
I was having this problem too. Solved it by following the directions here:
http://www.eightforums.com/network-sharing/11811-windows-8-wifi-help.html
This part in the first reply fixed the problem:
"With upgrades sometimes winsock or the TCP/IP stack gets corrupted. To reset them both type the following two commands into an elevated command prompt one at a timehitting enter after each one then reboot the system.
netsh winsock reset catalog (reset winsock entries)
netsh int ip reset reset.log hit (reset TCP/IP stack)"
Hope this helps someone else.
Cheers.
91 additional answers
    2013-05-11T14:22:54+00:00
    Wow, this was very helpful. I had to google to see how to run command pront as an administrator. but the fix fix worked the first time. I wish microsoft update fixes this automatically as people use wifi everyday.
    Sorry to say, that is why I keep a Mac with me all the time. Maybe time to time to just ship once and for all.
    This issue was a pain.
    2013-06-10T15:59:23+00:00
    In my case what works was entering into the Wi-Fi properties window and unmarking every item of the list, then entering again and marking each item and selecting OK.
    2013-07-22T22:19:46+00:00
    just set your adapter to static ip. it worked for me several times.
    2013-09-04T15:48:32+00:00
    FRUSTRATED to no end!!  The command prompt commands did not work, but what I have found on my HP ENVY with Windows 8 is that I can now logon at home; however, not at any other single location.  So obviously whatever I did ONE time worked for my home, but isn't working for anything else.    Obviously, when my phone and everyone else's laptops are able to login, the problem is NOT the router or any of the other useless suggestions.
    I do not have the AVG antivirus or any other at the time I was having the problem.  After getting a temporary fix to be able to login at home, I then downloaded my ATT MCafee suite.   But the problem existed before then.   Even at home I have had to REFRESH my computer, so the fix was NOT permanent.
    Today, after doing what was suggested on another thread, I have obtained an IP4 address, but no IP6, yet still unable to connect to internet:
    Press windows logo key + X and click on command prompt(admin)
     now type in : ipconfig /flushdns
     then disable your wireless adapter ( network and sharing center -> change adapter settings )
     Restart your computer
     enable internet connection
    So I am still desperately looking for an answer, now bc I have an IP4 address the troubleshooter says everything is working great.. Even though I can't connect to the internet... OMG!!  sooo frustrated.
