wifi does not have a valid ip configuration windows 8
2012-10-29T11:59:17+00:00
After upgrading to Windows 8 Final Version
it worked fine for 2 days then, WIFI stoped working.
every time I try to connect it gives me limited connection.
when I try trouble shout it give me the following message :" wifi does not have a valid ip configuration ".
even trying a cable connection, same message appear.
I somehow managed to get on my neighbor WIFI not sure how that happened, but I can only use internet on Desktop mode,
Metro interface have no access to wifi.
I would like to know if you can assist me with this issue?
2012-11-15T05:51:36+00:00
I was having this problem too. Solved it by following the directions here:
http://www.eightforums.com/network-sharing/11811-windows-8-wifi-help.html
This part in the first reply fixed the problem:
"With upgrades sometimes winsock or the TCP/IP stack gets corrupted. To reset them both type the following two commands into an elevated command prompt one at a timehitting enter after each one then reboot the system.
netsh winsock reset catalog (reset winsock entries)
netsh int ip reset reset.log hit (reset TCP/IP stack)"
Hope this helps someone else.
Cheers.
91 additional answers
    2013-02-26T09:42:42+00:00
    My 4th reset also says failed (access is denied)
    Did you ever solve?
    2013-02-26T11:38:03+00:00
    PEOPLE... simply uninstall your anti-virus, then re-install it. Your internet connection will be fixed. Windows * engineers need to step up and make this OS a lot more user friendly because they have failed hard so far
    2013-02-26T19:26:42+00:00
    This is what worked for my tablet.  havent had an issue since.
    Ed
    2013-03-11T22:33:45+00:00
    I'm current using Asus RT-N56U router and I suddenly remember after perform a firmware update for my router ever since then all seems wrong, that's when I got my Limited Network. This issue doesn't happen whenever I tether to my ipad so I strongly suspect it must be related to router firmware.
    As my system is running on Windows 8 64Bit, naturally the firmware update file for my router I will look under the same category but then again, I recall I don't experience the Limited Network at all when my router is on Windows 7 32Bit firmware. Since there's no solution to date, I decided to give it a try and revert back the firmware to Windows 7 32Bit version.
    Guess what, my connection somehow back to normal and I don't get to see the yellow exclamation icon on the network bar anymore for the past 2 days so I suggest you guys to try it out and install the firmware for Windows 7 32Bit for your router and see whether it works. It seems to work for mine but no harm for you guys to try it and meanwhile I will monitor it for the next few days.
