How to install a driver that does not contain digital signature information in Windows 8?
2012-10-31T16:13:02+00:00
It displays a message stating "The third-party INF does not contain digital signature information"
2014-09-10T10:25:52+00:00
Hello Nick,
Thank you for your response.
I appreciate your efforts towards resolving the issue.
I would suggest you to try following steps and check if it helps.
a. Press Windows + X keys and click command prompt(admin).
b. Type the following command in command prompt and press Enter.
bcdedit /set loadoptions DDISABLE_INTEGRITY_CHECKS & bcdedit /set testsigning on
c. Close command prompt.
I hope this information helps.
Please do let us know if you need any further assistance.
Thank you
2013-01-17T17:10:08+00:00
Turn off the check.
Hold the shift key while clicking on Restart
Select Troubleshoot > Advanced Options > Startup Settings > Restart
After Restart select option 7.
2015-04-26T11:10:48+00:00
I appreciate your patience.
Did you try using suggestions provided in the previous posts?
If not, please use those suggestions and reply with results.
If issue still persists, I would suggest you to run this Microsoft fixit and check.
Refer:
Fix problems that programs cannot be installed or uninstalled
https://support.microsoft.com/en-us/mats/program_install_and_uninstall
Thank you
49 additional answers
    2014-04-23T14:45:17+00:00
    Thanks for this. It's such a big help.
    2014-04-24T16:03:26+00:00
    Well, it hasn't worked (yet) on my Lenovo model 20332 laptop/tablet running 8.1:  after executing the listed commands I 'Update Driver' and the driver is located but the system responds with "Windows found driver software for your device but encountered an error while attempting to install it."
    I'm hopeful you'll be able to recommend a solution for me.
