How to install a driver that does not contain digital signature information in Windows 8?
2012-10-31T16:13:02+00:00
It displays a message stating "The third-party INF does not contain digital signature information"
2014-09-10T10:25:52+00:00
Hello Nick,
Thank you for your response.
I appreciate your efforts towards resolving the issue.
I would suggest you to try following steps and check if it helps.
a. Press Windows + X keys and click command prompt(admin).
b. Type the following command in command prompt and press Enter.
bcdedit /set loadoptions DDISABLE_INTEGRITY_CHECKS & bcdedit /set testsigning on
c. Close command prompt.
I hope this information helps.
Please do let us know if you need any further assistance.
Thank you
2013-01-17T17:10:08+00:00
Turn off the check.
Hold the shift key while clicking on Restart
Select Troubleshoot > Advanced Options > Startup Settings > Restart
After Restart select option 7.
2015-04-26T11:10:48+00:00
I appreciate your patience.
Did you try using suggestions provided in the previous posts?
If not, please use those suggestions and reply with results.
If issue still persists, I would suggest you to run this Microsoft fixit and check.
Refer:
Fix problems that programs cannot be installed or uninstalled
https://support.microsoft.com/en-us/mats/program_install_and_uninstall
Thank you
49 additional answers
    2015-05-29T08:35:14+00:00
    it works but whenever we restart the system the problem occurs again.
    and repeating the same above solution is annoying.
    2015-05-29T09:06:53+00:00
    I tried all the stuff about signatures, reboot commands etc and they didn't work in trying to install a program with equipment, as written for XP. My IT colleague ended up doing this for me, and though I do not pretend to be able to replicate what he did, I got the gist of it.
    Basically, I had installed all the drivers and including the small essential dll file that the computer kept telling me "was not on my computer, try downloading again", the problem was that the old program I was trying to install didn't know where to look for same in Windows 8.1. I think my colleague just copied the drivers into the correct location, or told the old prog where to look, if that makes sense.
    Kind Regards Fred
