How to install a driver that does not contain digital signature information in Windows 8?
2012-10-31T16:13:02+00:00
It displays a message stating "The third-party INF does not contain digital signature information"
2014-09-10T10:25:52+00:00
Hello Nick,
Thank you for your response.
I appreciate your efforts towards resolving the issue.
I would suggest you to try following steps and check if it helps.
a. Press Windows + X keys and click command prompt(admin).
b. Type the following command in command prompt and press Enter.
bcdedit /set loadoptions DDISABLE_INTEGRITY_CHECKS & bcdedit /set testsigning on
c. Close command prompt.
I hope this information helps.
Please do let us know if you need any further assistance.
Thank you
2013-01-17T17:10:08+00:00
Turn off the check.
Hold the shift key while clicking on Restart
Select Troubleshoot > Advanced Options > Startup Settings > Restart
After Restart select option 7.
2015-04-26T11:10:48+00:00
I appreciate your patience.
Did you try using suggestions provided in the previous posts?
If not, please use those suggestions and reply with results.
If issue still persists, I would suggest you to run this Microsoft fixit and check.
Refer:
Fix problems that programs cannot be installed or uninstalled
https://support.microsoft.com/en-us/mats/program_install_and_uninstall
Thank you
49 additional answers
    2015-04-23T11:16:49+00:00
    Hi all,
    I tried all the solutions listed to no avail.  I have an Asus X205ta and I am trying to install Singer Futura Quartet software.  It has a 3rd party software that will not allow me to install due to the INF not having a digital signature.  The third party softwares driver is listed as CLEM.
    I know a little about computers so can navigate pretty well around them.  This one has me so frustrated as I have a 1000.00 sewing machine sitting here collecting dust!  PLEASE HELP ME!!!
    Mouse
    2015-05-14T13:44:28+00:00
    How do I exit Test Mode
