How to install a driver that does not contain digital signature information in Windows 8?
2012-10-31T16:13:02+00:00
It displays a message stating "The third-party INF does not contain digital signature information"
2014-09-10T10:25:52+00:00
Hello Nick,
Thank you for your response.
I appreciate your efforts towards resolving the issue.
I would suggest you to try following steps and check if it helps.
a. Press Windows + X keys and click command prompt(admin).
b. Type the following command in command prompt and press Enter.
bcdedit /set loadoptions DDISABLE_INTEGRITY_CHECKS & bcdedit /set testsigning on
c. Close command prompt.
I hope this information helps.
Please do let us know if you need any further assistance.
Thank you
2013-01-17T17:10:08+00:00
Turn off the check.
Hold the shift key while clicking on Restart
Select Troubleshoot > Advanced Options > Startup Settings > Restart
After Restart select option 7.
2015-04-26T11:10:48+00:00
I appreciate your patience.
Did you try using suggestions provided in the previous posts?
If not, please use those suggestions and reply with results.
If issue still persists, I would suggest you to run this Microsoft fixit and check.
Refer:
Fix problems that programs cannot be installed or uninstalled
https://support.microsoft.com/en-us/mats/program_install_and_uninstall
Thank you
49 additional answers
    2015-03-20T00:54:20+00:00
    Go to Start - Then Command Prompt
    Enter command "shutdown /r /o /f /t 00"
    Click the "OK" button
    System will restart to a "Choose an option" screen
    Then select "Troubleshoot" from "Choose an option" screen
    Then select "Advanced options" from "Troubleshoot" screen
    Then select "Windows Startup Settings" from "Advanced options" screen
    Click "Restart" button
    System will restart to "Advanced Boot Options" screen
    Select "Disable Driver Signature Enforcement"
    Restart & install drivers...
    Trust me it works.
    Thank you very much. This worked for me.
    2015-04-04T20:13:23+00:00
    I'm trying to install synaptics driver for touchpad on windows technical preview and it is saying that I cannot because the driver is not signed. So, i tried the solution above and got this message: An error has occurred setting the element data. The value is protected by Secure Boot policy and cannot be modified or deleted. Please advise.
