How to install a driver that does not contain digital signature information in Windows 8?
2012-10-31T16:13:02+00:00
It displays a message stating "The third-party INF does not contain digital signature information"
2014-09-10T10:25:52+00:00
Hello Nick,
Thank you for your response.
I appreciate your efforts towards resolving the issue.
I would suggest you to try following steps and check if it helps.
a. Press Windows + X keys and click command prompt(admin).
b. Type the following command in command prompt and press Enter.
bcdedit /set loadoptions DDISABLE_INTEGRITY_CHECKS & bcdedit /set testsigning on
c. Close command prompt.
I hope this information helps.
Please do let us know if you need any further assistance.
Thank you
2013-01-17T17:10:08+00:00
Turn off the check.
Hold the shift key while clicking on Restart
Select Troubleshoot > Advanced Options > Startup Settings > Restart
After Restart select option 7.
2015-04-26T11:10:48+00:00
I appreciate your patience.
Did you try using suggestions provided in the previous posts?
If not, please use those suggestions and reply with results.
If issue still persists, I would suggest you to run this Microsoft fixit and check.
Refer:
Fix problems that programs cannot be installed or uninstalled
https://support.microsoft.com/en-us/mats/program_install_and_uninstall
Thank you
49 additional answers
    2012-11-01T05:54:50+00:00
    Thank you for posting in Microsoft Community.
    I understand that you are getting error in "The third-party INF does not contain digital signature information" in Windows 8.
    I can imagine the inconvenience you have experienced. I will definitely help you with this.
    1.      What is the make and model of the computer?
    2.      Which driver you are trying to install?
    Please follow the methods.
    Method 1:
    Run the hardware troubleshooter and check if that helps. Follow these steps to run the troubleshooter.
    a)    Press the ‘**Windows + w’**and type **‘troubleshooting’**in the search and press enter.
    b)    Click on ‘Hardware and Sound’ and select ‘Hardware and Devices’ and click on ‘next’ to run the troubleshooter.
    Method 2:
    Install the drivers in Windows 7 Compatibility mode and see if it helps.
    a: Right Click on the set up file of the driver and then select Properties.
    b: Then click the compatibility tab and select Windows 7 from the list and then click ok.
    2013-01-09T12:05:54+00:00
    Respected Sir,
    i have applied both the methods but problem is still the same. Please Help. Thanks.
