Qualcomm Atheros AR5BWB222 Wireless Network Adapter adapter is not working.
2012-11-11T06:19:45+00:00
I have Acer V3-571 laptop.
I upgraded to windows 8 from windows 7.
Qualcomm Atheros AR5BWB222 Wireless Network Adapter adapter is showing working fine in the device manager ,but wifi is not working.
when I checked the on off soft switch in the Pc setting ,the swith found in disable position.Could anybody assist to solve it?
2012-12-13T15:59:03+00:00
Well I resolved it by bypassing the wireless adapter and buying a nano external wireless usb thing, it works perfectly now. problem still not fixed however.
I found a way to fix my Network, ive manually uninstalled the Network cards Drivers and downloaded the following file "win78-10.0.0.75-whql" from
http://www.atheros.cz/atheros-wireless-download.php?chipset=81&system=6
and simply installed the driver via the Device Manager
Hope this will help some of you.
Regards,
Pieter Cachet
53 additional answers
    2012-12-27T18:19:37+00:00
    Pieter!
    You're a hero! Installing the old windows 7 driver did the job. Works perfectly now.
    Thanks a million!
    2012-12-28T19:51:36+00:00
    Hi everyone.
    While I could not solve the unreliability on my device with the driver updates or the power saving settings.
    However, when I changed my wifi access point's channel from "auto" to "11" then all of the sudden my laptop wifi connection started working like a charm.
    Figured it may help while the big boys solve the driver issue...
    2013-01-01T11:01:25+00:00
    My wireless was not working to start with.
    After browsing several threads I followed one and changed it slightly to get mine to work on my Laptop (Acer Aspire V3-571).
    So try this:
    Go to the Device Manager:
    1.  Double-Click :   Qualcomm Atheros AR5BWB222 Wireless Network Adaptor
    2.  Right Click:        Update Driver Software
    3.  Select:               Browse My Computer ........
    4.  Select:               Let me pick
    5.  Select:              Atheros AR5BWB222 Wireless Network Adaptor
    (the one without the word: Qualcomm)
    6.  Select               Next
    7.  Restart Laptop.
    8.  An orange wireless light should come on and wireless should be working.
    2013-01-11T09:50:19+00:00
    Thank you yzze. After days of trying to figure out the problem we have fixed it using your steps.
    Cheers and yes folks this works!
