Qualcomm Atheros AR5BWB222 Wireless Network Adapter adapter is not working.
2012-11-11T06:19:45+00:00
I have Acer V3-571 laptop.
I upgraded to windows 8 from windows 7.
Qualcomm Atheros AR5BWB222 Wireless Network Adapter adapter is showing working fine in the device manager ,but wifi is not working.
when I checked the on off soft switch in the Pc setting ,the swith found in disable position.Could anybody assist to solve it?
2012-12-13T15:59:03+00:00
Well I resolved it by bypassing the wireless adapter and buying a nano external wireless usb thing, it works perfectly now. problem still not fixed however.
I found a way to fix my Network, ive manually uninstalled the Network cards Drivers and downloaded the following file "win78-10.0.0.75-whql" from
http://www.atheros.cz/atheros-wireless-download.php?chipset=81&system=6
and simply installed the driver via the Device Manager
Hope this will help some of you.
Regards,
Pieter Cachet
53 additional answers
    2014-07-15T22:20:10+00:00
    There is nothing for you to download on the website.
    2014-07-17T08:58:04+00:00
    Follow the link : http://www.atheros.cz/atheros-wireless-download.php?chipset=81&system=6%20%20http://
    Click on "Click for Download", it will take you to a new page, wait a few seconds. It will the start the download file"win7-v10.0.0.276-whql.zip"
    2014-07-17T09:02:51+00:00
    Once you downloaded the file needed, Unzip file.
    Right click Computer > Properties > Device Manager > Select your Card > Right click > Update Drivers
    Browse my computer for Files > and there you go..... that should solve it. At-less it did for me.
    2014-07-17T09:13:04+00:00
    Or Try
    http://www.acer.ca/ac/en/CA/content/drivers
    Enter your SNID, product Model or follow the guide options.
