How to pair/connect Bluetooth audio device to Windows 7 PC when Windows 7 reports "Device driver software was not successfully installed. Bluetooth Peripheral Device. No driver found."
2012-02-29T00:14:29+00:00
I spent many hours trying to figure out how to connect my two Windows 7 64-bit PCs to my Bluetooth stereo audio device (the Motorola S705) but the problem seems to be generic to many Bluetooth stereo audio devices, and the web shows many people having this problem, so I thought I'd post my solution in case it helps anyone else.
SYMPTOMS:
A Bluetooth-capable Windows 7 PC can pair, but can’t connect, to a stereo audio device (like the Motorola S705 SoundPilot) via Bluetooth. The PC and the audio device may pair, but then Windows 7 provides the following error messages: “Device driver software was not successfully installed. Bluetooth Peripheral Device. No driver found.”
It may be worth noting that I had no problem connecting my Bluetooth audio device to my cell phone or Windows XP PC. And the Windows 7 PC was able to connect to other Bluetooth devices, such as mice or keyboards.
CAUSE:
Even though a Windows 7 PC may have a working Bluetooth driver that connects to some Bluetooth devices (like mice or keyboards), a Windows 7 PC may not have the necessary A2DP & AVRCP (audio-capable) Bluetooth software & drivers installed. This software deficiency may occur, especially if the PC has been upgraded from an earlier version of Windows or the PC maker has simply not provided the latest driver update.  This problem can occur even if "Windows Update" is enabled and even if Windows 7 is allowed to automatically search for the driver online.
SOLUTION:
If the PC has an add-on Bluetooth adapter/dongle, download & install the latest driver directly from the Bluetooth dongle maker’s website, if possible.
A) If the PC has Bluetooth built-in, download & install the latest Bluetooth driver directly from the PC manufacturer, if possible.
B) If the add-on Bluetooth adapter/dongle maker, or the PC-maker doesn't offer full-featured Bluetooth software for Windows 7, it is possible (not guaranteed) that the maker of the Bluetooth chips inside the adapter/dongle/PC does offer such full-featured Bluetooth software (but the maker of the adapter/dongle/PC didn't bother to test it and include it on their website).  If so, you may be able to do the following:
  1. On the Windows 7 PC, go into to the “Device Manager” (Start Menu/Control Panel/Device Manager) and expand “Bluetooth Radios”.  You should see two items.  (Ignore the 2nd item which says something like Microsoft Bluetooth Enumerator.)  The first item should contain the name of the Bluetooth module, possibly with the name of the Bluetooth chipmaker (e.g. Broadcom, Cambridge Silicon Radio "CSR", or Toshiba), but also possibly with just the module maker's name (e.g. Dell, or HP).  If the chipmaker's name isn't apparent, then double-click on the icon, click on the "Details" tab, and then select "Manufacturer" from the "Properties" drop down menu.  The Bluetooth chipmaker's name should appear under "Properties".  If not, you're probably out of luck but you could surf around some of the other "Properties" so see if you can get a hint at the Bluetooth chipmaker's name.
  2. Go to the chipmaker’s website to download the latest driver. For example, in the case of a Broadcom Bluetooth radio chip, download the Widcomm Bluetooth software from Broadcom’s website, http://www.broadcom.com/support/bluetooth/update.php
  3. With the Bluetooth hardware adapter/dongle installed (if not built-in), install the chipmaker’s Bluetooth software.
Once the Bluetooth software is installed, you should be able to pair and connect with the Bluetooth audio device in the normal manner (Start Menu/Devices and Printers/Add a device).
Note that in any case, once the driver is installed and the Bluetooth audio device is properly installed, paired, and connected, you may need to go into the audio properties of the PC (Start Menu/Control panel/Sound) and set the default audio playback device to be the Bluetooth headphones when listening through the Bluetooth audio device. When not listening through the Bluetooth audio device, the user will have to switch the default audio playback device back to the speakers.
2012-02-29T18:54:20+00:00
Thank you for sharing the resolution, as this would help other members of the community facing the same issue.
If you have any other queries or comments related to Microsoft Windows, you can post it on Microsoft Answers Forum and we will be happy to answer you.
Hope this information helps you.
49 additional answers
    2015-04-06T03:19:33+00:00
    I tried the Broadcom WIDCOMM Bluetooth for Windows Software but the tool failed to update. I also tried the Intel driver and it didn't work for me either.
    I could solve the problem by clean uninstall/install of all Bluetooth devices and drivers (steps below). following steps below. Just to keep things into context here is my system details:
    System: Dell Latitude E6220
    Operating System: Windows 7 32-bit
    Onboard Bluetooth Module: Dell Wireless 375 Bluetooth Module
    Bluetooth Manufacturer: Broadcom
    Bluetooth Headset: Rapoo H6080 Bluetooth Foldable Headset
    Headset Bluetooth Technology: Bluetooth 4.0 wireless audio transmission
    Headset Bluetooth Profile: Advanced Audio Distribution Profile (A2DP)
    Steps for clean uninstalling, installing and configuring Bluetooth drivers for connecting Bluetooth headset that requires A2DP profile:
    1. Go to "Devices and Printers", right-click on the Bluetooth headset device and select "Properties" and then select "Hardware" tab.
    2. Under "Device Functions", select a function and click on "Properties" button.
    3. Select "Driver" tab and click on "Uninstall" button.
    4. On "Confirm Device Uninstall" window, tick "Delete the driver software for this device" option and then click "Ok". This will uninstall and delete the driver attached to this device function.
    5. Repeat steps 2-4 for each device function in the list. Most probably all device functions will use the same driver, but I did this to be sure.
    6. Once you are done, click on "Ok" to close the device "Properties" window.
    7. Go back to "Devices and Printers", select the headset Bluetooth device, and then click on "Remove device". Wait until the removal process is complete.
    8. Go to "Device Manager" and expand "Bluetooth Radios". Right-click on the Bluetooth device module and select "Properties", and then select the "Driver" tab.
    9. Click on "Uninstall" button to uninstall the driver.
    10. On "Confirm Device Uninstall" window, tick "Delete the driver software for this device" option and then click "Ok". This will uninstall and delete the driver attached to the Bluetooth device module.
    11. Click on "Ok" to close the Bluetooth device module "Properties" window.
    12. Go back to "Device Manager" and click on "Scan for hardware changes". Windows should recognize the Bluetooth module again and will install the latest approved driver from Microsoft Updates. In my case, Windows found the most recent Broadcom driver v. 12.0.0.8047 dated 18/10/2013.
    13. Now switch on your Bluetooth headset on pairing mode.
    14. Go to "Devices and Printers" and click on "Add a device" and follow the Windows "Add a Device" wizard. This should install and pair with your Bluetooth headset.
    15. Once the device is added to your "Devices and Printers" list, right-click on the device and select "Properties".
    16. Select the "Services" tab and make sure that "Audio Sink" (if exists) and "Headset" are ticked, then click on "Ok". If either one was not marked before this will install additional device functions using the latest driver you just installed.
    17. The last step would be to configure Windows to use the Bluetooth headset as the default audio device. To do this follow the next steps.
    18. Right-click on the Audio icon on Windows "Taskbar" and select "Playback devices".
    19. On Playback tab, select the newly added Bluetooth headset device and click on "Set Default".
    20. Switch to "Recording" tab, select the newly added Bluetooth headset device and click on "Set Default".
    21. Click on "Ok" and you are done.
    Hope this helps!!
    I think this can work sirosly works. From jai 124
    2015-09-27T21:51:23+00:00
    14 HOURS OF HAIL later... this is what finally worked for my Plantronics headset:
    My Windows 7 computer does not have internal BT
    • delete previous BT attempts/drivers/devices (start over)
    • plug in USB bluetooth dongle (mine is an Asus BT21), let Windows put a Generic driver on it
    • install Broadcom's wizard (SetupBtwDownloadSE.exe downloaded from their site), it figures out what your system needs and installs it
    • reboot
    • use Windows update, on mine it located "Broadcom 2046 BT 2.1+EDR w First Connect" to replace/update Generic BT (for my Asus USB BT dongle)
    • reboot
    • add a device under BT devices (for my headset), will recognize the pairing and show the device, ***R clk on the newly discovered device and select ADD THIS DEVICE (not the properties!)**** (I kept selecting Properties for variations on the 4 check boxes)
    • DO NOT SELECT NEXT button, only use the R clk and select Add this Device
    • it auto added it's needed drivers, and recognized it (added Hands-free, Romote Control and AV)
    "This device has been successfully added to this computer"
    • R clk device and Control is there
    • sound properties now lists it
    • simply make it the default for sound, then when you turn it off it should default to speakers again
    This ordeal nearly killed me, but I won.
    2016-03-23T10:10:06+00:00
    Thanks for this awesome tip! Spent hours trying to figure this out and this finally fixed the issue. Required a couple resets after the drivers installed. But once i went into the Services option and selected "Listen to Music" the headset started working!
    2016-11-30T09:54:56+00:00
    I tried long back to connect my Sony Bluetooth Stereo Headset ( MDR-EX31BN ), it was not successful. And now after reading this KB, i tried it and installed latest Intel Wireless Bluetooth Drivers (https://downloadcenter.intel.com/product/72252/Intel-PROSet-Wireless-Software) and tried to pair the device. The overall process took 5 mins and finally achieved and able to access it. After installation go to "Devices and Printers" and Right click on Bluetooth headset and select "Service", a window will pop-up and select "Listen to Music".
    There you are and enjoy hands free music/calls on laptop.
    Thanks to the Article !!!
