What is a bad pool header and how do I fix it?
2012-04-22T22:00:46+00:00
Windows has been taking 30 or so minutes to start.  I've tried repairing it but nothing seems to work and now I'm getting a blue screen that says "bad pool header".
2012-04-23T16:12:31+00:00
  1. Have you made any changes to the computer prior to the issue?
  2. Do you get any specific error codes?
A pool header issue is a problem with Windows memory allocation. Device driver issues are probably the most common, but this can have diverse causes including bad sectors or other disk write issues, and problems with some routers. (By theory, RAM problems would be suspect for memory pool issues).
Method 1:
Disconnect any external devices connected to the computer except the mouse and keyboard, check what happens.
With Windows 7, you can run a check disk from system recovery options using command prompt.
Refer the article mentioned below:
What are the system recovery options in Windows 7?
http://windows.microsoft.com/en-us/windows7/What-are-the-system-recovery-options-in-Windows-7
Method 2:
If the above step fails follow the steps:
Step 1:
Restart computer in safe mode and check if the issue persists. Follow the steps in the link:
http://windows.microsoft.com/en-US/windows7/Start-your-computer-in-safe-mode
Step 2:
If safe mode works restart computer in clean boot and check if the issue persists.Follow “step 1” in the link to enable to clean boot:
http://support.microsoft.com/kb/929135
Follow the step 7 from the article to “Reset the computer to start as usual”, after performing the clean boot troubleshooting.
Method 3:
If the above step fails follow the steps in the link:
http://windows.microsoft.com/en-US/windows7/Resolving-stop-blue-screen-errors-in-Windows-7
Hope this helps.
49 additional answers
    2015-08-07T20:03:15+00:00
    I had the same "BAD_POOL_HEADER" issue with Windows 8.  I came back to W7 and now I am checking my C drive, defragmenting it, and now cleaning it from lost files.  I will re-install W8 and see if the issue goes away.
    2015-11-12T06:21:57+00:00
    Hi, I have Windows 10 and I have the same error code whenever I try to move my mouse. Around after I log In can anyone help me with this?
    2015-11-30T19:13:07+00:00
    That is all well and good if your machine will boot. My problem started when I updated windows 10 this morning. Now I can not get it to boot. Keeps restarting. I am just about done with windows. Every version I have used always crashes at least once. Then it takes many days of work, without any help from Microsoft, to get it back up and running.
    Considering Apple.
  4. Deleted
