Neighbor keeps inserting his wireless router into my network infrastructure?
2011-08-10T13:09:02+00:00
neighbor keeps adding his router to my network infrastructure. Not sure how this is happening. Have deleted network profile and re installed with just my router, added/changed passwords, and within a few days here is this other router listed in addition to mine as part of the network infrastructure again. How do I prevent this? How much of a security risk is this vs. just really annoying? I have cable internet, and a Linkseys modem and wireless router.
2011-08-17T15:29:17+00:00
If someone hacked into your router, they could well have hacked into your computer also and you may have something running in your computer that is doing this.  Its very hard to diagnose over this forum.  But if you are losing bandwidth, it suggests hacking.  And that is illegal and it might be used for illegal purposes, so if you knew it was someone hacking, you can contact local law enforcement, as it is more than someone accessing your internet capability (such as might be the case if you had an unsecured network).  This is robbery by tampering with your system, so that is clearly not kosher.  They could also be using your bandwidth for illegal purposes and the cops would come after you, as its your account.
I would scan your systems for malware and viruses.  Then also go to Start | Run and type msconfig and see what programs are running at startup and its possible there is a program that is resetting the "Belkin thing" or is opening a back door to your system.  For diagnostic purposes you might also try turning off the wireless features completely and just running the router hard-wired and then see if you get the "Belkin thing" coming back in.
Its likely someone very close to you as the wireless signal doesn't transmit over the entire neighborhood.  It could even be someone in their vehicle out on the street.  If you are friendly with the neighbors, you can ask them.  Otherwise I'd ask law enforcement for their advice.
steve
42 additional answers
    2011-11-04T20:11:46+00:00
    I'm glad you were able to resolve things.
    cheers,
    steve
    2012-05-22T01:38:46+00:00
    Just in case, if you may run into this in the future, under 'device manager' you can see an odd ball 'Microsoft Virtual WiFi Miniport Adapter'.
    That is a confirmation presence of the trouble-maker.
    1.dis-able wireless wi-fi
    2.use cmd in 'admin' user and type in the following:
    'netsh wlan stop hostednetwork'
    'netsh wlan set hostednetwork mode=disallow'
    1. reboot your pc
