IRQL_NOT_LESS_OR_EQUAL blue screen
2010-11-13T12:01:26+00:00
i just got 2 blue screens again... they just pop up every time i play 3D Games :\
But i just updated my Video Drivers :S
and these codes don't help me at all
i also checked the dump files with BS View
red are: portcls.sys, p17.sys, ntkrnlpa.exe, halmacpi.dll,
and on the other dump: ntkrnlpa.exe, win32k.sys
even got a dump with: dxgmms1.sys but that was before installing new video drivers, didn't get that one since :\ also cdd.dll
i hope anyone can help me
OS: Windows 7 86x
  BCCode:    1000008e
  BCP1:    C0000005
  BCP2:    9E4E6F00
  BCP3:    A1D2F724
  BCP4:    00000000
  OS Version:    6_1_7600
  Service Pack:    0_0
  Product:    256_1
  BCCode:    d1
  BCP1:    B4F05950
  BCP2:    00000007
  BCP3:    00000001
  BCP4:    91DC475D
  Service Pack:    0_0
  Product:    256_1
2010-11-13T22:25:45+00:00
I'll reply in English here.
the PAGE_FAULT_IN_NONPAGED_AREA (50) is caused by the AVG driver:
    Image path: \SystemRoot\system32\DRIVERS\avgntflt.sys
    Image name: avgntflt.sys
    Timestamp:        Fri May 07 14:28:31 2010
Try to get an Update for AVG.
the KERNEL_MODE_EXCEPTION_NOT_HANDLED_M (1000008e) happens while GDI operations, so update the graphic card driver:
ChildEBP RetAddr  Args to Child
a1d2f7b8 9e4fa20e a1d2fcfc a1d2fb50 000004e8 win32k!ESTROBJ::vCharPos_H1+0x99
a1d2f7f0 9e4facfa ffbbe050 0000000b a1d2fcfc win32k!ESTROBJ::vInit+0x1d8
a1d2fb38 9e46af67 a1d2fcfc 0000004e 0000006a win32k!GreExtTextOutWLocked+0x62f
a1d2fbb4 9e4cfb07 02cccccc ffbbe068 00001004 win32k!GreBatchTextOut+0x1e6
a1d2fd24 82c4f3ec 000000c9 01ee8b70 01ee8b80 win32k!NtGdiFlushUserBatch+0x123
a1d2fd34 776c64f4 badb0d00 01ee8b70 00000000 nt!KiFastCallEntry+0xcc
    Image path: \SystemRoot\system32\DRIVERS\atikmdag.sys
    Image name: atikmdag.sys
    Timestamp:        Wed Sep 29 03:37:54 2010
the DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1) crash is caused by this driver:
    Image path: \SystemRoot\system32\drivers\P17.sys
    Image name: P17.sys
    Timestamp:        Fri Oct 16 04:11:53 2009
So update the soundblaster live card driver.
The other crashes are too old. They should be fixed with the newer drivers.
André
"A programmer is just a tool which converts caffeine into code" CLIP- Stellvertreter http://www.winvistaside.de/
46 additional answers
    2010-11-17T11:51:30+00:00
    Well.. seems like i didn't have to run it for a few hours =(
    Result after 15 SECONDS...
    http://www.imagebanana.com/view/2ap3ptqc/prime95.png
    doesn't look too good huh? =(
    tho i chosed a different test now ( with L2 check etc.. ) :\
    argh.. does that mean it could by my CPU, RAM or Power Supply? :|
    okay.. it sure is my RAM, CPU or Power Supply :|
    Final Result:
    http://img5.imagebanana.com/img/t5cno1zf/result.png
    oh sh**t...
    tho i wonder why my pc doesn't crash on 2D Games.. :| even if there's much stuff going one .. sure it's less work for the CPU but 3D games are more GPU intensive than CPU intensive :\ argh... it's getting so confusing and i don't want to buy new parts that are actually still working >_< like i buy a new CPU and then still get BSoD's because that wasn't the problem and something else caused the cpu calculating problems ;_; argh..
    waiting for a new advice : <
    [Wed Nov 17 11:27:52 2010]
    FATAL ERROR: Rounding was 0.5, expected less than 0.4
    Hardware failure detected, consult stress.txt file.
    [Wed Nov 17 11:40:34 2010]
    [Wed Nov 17 12:48:13 2010]
    FATAL ERROR: Rounding was 0.484375, expected less than 0.4
    [Wed Nov 17 12:58:26 2010]
    edit:\
    Error on both CPU cores now :|
    http://img5.imagebanana.com/img/45eth68d/omg.png
    omg.. :\
    2010-11-18T00:18:04+00:00
    This is not good. If you do OC, undo it. If you run at stock level, get a new CPU.
    2010-11-18T09:14:43+00:00
    It's not Overclocked - i don't do that with any of my hardware parts - so there is no way anything else could be causing this ? and this could also resolve the other blue screens i got ? or atleast be the main reason for it ?
    well it could really be my cpu since i once had problems with it and it overheated to over 100°C a few times but i sent the whole pc back to where i bought it and they said they fixed it :\ - seems like they just fixed the over heating ( fan controll unit was broken ) - damn..
    i'm still afraid to buy a new CPU and then still get my regular BSoD all the time :\
    *argh*
    2010-11-18T23:36:06+00:00
    look into the stress.txt. What is shown there?
