IRQL_NOT_LESS_OR_EQUAL blue screen
2010-11-13T12:01:26+00:00
i just got 2 blue screens again... they just pop up every time i play 3D Games :\
But i just updated my Video Drivers :S
and these codes don't help me at all
i also checked the dump files with BS View
red are: portcls.sys, p17.sys, ntkrnlpa.exe, halmacpi.dll,
and on the other dump: ntkrnlpa.exe, win32k.sys
even got a dump with: dxgmms1.sys but that was before installing new video drivers, didn't get that one since :\ also cdd.dll
i hope anyone can help me
OS: Windows 7 86x
  BCCode:    1000008e
  BCP1:    C0000005
  BCP2:    9E4E6F00
  BCP3:    A1D2F724
  BCP4:    00000000
  OS Version:    6_1_7600
  Service Pack:    0_0
  Product:    256_1
  BCCode:    d1
  BCP1:    B4F05950
  BCP2:    00000007
  BCP3:    00000001
  BCP4:    91DC475D
  Service Pack:    0_0
  Product:    256_1
2010-11-13T22:25:45+00:00
I'll reply in English here.
the PAGE_FAULT_IN_NONPAGED_AREA (50) is caused by the AVG driver:
    Image path: \SystemRoot\system32\DRIVERS\avgntflt.sys
    Image name: avgntflt.sys
    Timestamp:        Fri May 07 14:28:31 2010
Try to get an Update for AVG.
the KERNEL_MODE_EXCEPTION_NOT_HANDLED_M (1000008e) happens while GDI operations, so update the graphic card driver:
ChildEBP RetAddr  Args to Child
a1d2f7b8 9e4fa20e a1d2fcfc a1d2fb50 000004e8 win32k!ESTROBJ::vCharPos_H1+0x99
a1d2f7f0 9e4facfa ffbbe050 0000000b a1d2fcfc win32k!ESTROBJ::vInit+0x1d8
a1d2fb38 9e46af67 a1d2fcfc 0000004e 0000006a win32k!GreExtTextOutWLocked+0x62f
a1d2fbb4 9e4cfb07 02cccccc ffbbe068 00001004 win32k!GreBatchTextOut+0x1e6
a1d2fd24 82c4f3ec 000000c9 01ee8b70 01ee8b80 win32k!NtGdiFlushUserBatch+0x123
a1d2fd34 776c64f4 badb0d00 01ee8b70 00000000 nt!KiFastCallEntry+0xcc
    Image path: \SystemRoot\system32\DRIVERS\atikmdag.sys
    Image name: atikmdag.sys
    Timestamp:        Wed Sep 29 03:37:54 2010
the DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1) crash is caused by this driver:
    Image path: \SystemRoot\system32\drivers\P17.sys
    Image name: P17.sys
    Timestamp:        Fri Oct 16 04:11:53 2009
So update the soundblaster live card driver.
The other crashes are too old. They should be fixed with the newer drivers.
André
"A programmer is just a tool which converts caffeine into code" CLIP- Stellvertreter http://www.winvistaside.de/
46 additional answers
    2010-11-16T09:16:41+00:00
    The main BIOS you need to concern yourself with is from the System Maker or Motherboard
    maker so you need to check their sites by your model information and also contact their
    support as some do not make BIOS updates public. Check in their forums (if any).
    Some video cards have a BIOS that can be flashed though that would come from the device
    maker's sites.
    Rob Brown - MS MVP - Windows Desktop Experience : Bicycle - Mark Twain said it right.
    2010-11-16T17:44:02+00:00
    Hmm, after changeing the slot of the soundcard on my mainboard it seems like the bluescreen caused by my soundcard driers disapeared (till now)
    also the DX bluescreen didn't come back, but i don't know what could have caused this one now:
    Just happend:
    Crash List Created by using BlueScreenView
    Dump File Crash Time Bug Check String Bug Check Code Parameter 1 Parameter 2 Parameter 3 Parameter 4 Caused By Driver Caused By Address File Description Product Name Company File Version Processor Full Path Processors Count Major Version Minor Version
    111610-21512-01.dmp 16.11.2010 18:35:35 KERNEL_MODE_EXCEPTION_NOT_HANDLED 0x1000008e 0xc000001d 0x82e09cff 0xae18587c 0x00000000 ntkrnlpa.exe ntkrnlpa.exe+200cff NT Kernel & System Microsoft® Windows® Operating System Microsoft Corporation 6.1.7600.16617 (win7_gdr.100618-1621) 32-bit C:\Windows\Minidump\111610-21512-01.dmp 2 15 7600
    any ideas?
    or could this still be my ram and win7 mem test is fail?
    since my bluescreens are getting so random o_O
    thanks!
    2010-11-17T01:24:55+00:00
    use memtest86+. The Windows tool is not very good.
    the latest crash has this exception:
    // MessageId: STATUS_ILLEGAL_INSTRUCTION
    // MessageText:
    // {EXCEPTION}
    // Illegal Instruction
    // An attempt was made to execute an illegal instruction.
    #define STATUS_ILLEGAL_INSTRUCTION       ((NTSTATUS)0xC000001D L)
    So also run Prime95 to test your CPU for errors.
    2010-11-17T10:31:20+00:00
    // MessageText:
    // {EXCEPTION}
    [Wed Nov 17 11:27:52 2010] FATAL ERROR: Rounding was 0.5, expected less than 0.4 Hardware failure detected, consult stress.txt file.
    Worker #1 ( CPU 0 )  stopped working pretty quick ( after like 5 minutes )
    worker #2 ( CPU 1 ) is still running
    edit:\ bluescreen again because of my soundblaster drivers.. omg =..
    been playing a game to test the stability for like... 2 1/2 hours now - no crash no lag ( usualy its 10-15min max! ) then i thought fine - let's tab out :| - i wrote 3 lines of text and tada blue screen =..
    not a new one tho - already had this before it's a d1 again:
    i'll let the CPU test run for a few hours now and see what happens.
    111710-19936-01.dmp 17.11.2010 12:37:52 DRIVER_IRQL_NOT_LESS_OR_EQUAL 0x000000d1 0x0000ce8d 0x00000007 0x00000001 0x91c0fe75 P17.sys P17.sys+d74a WDM Audio Miniport (Basic) Driver Creative Technology Ltd. 5.12.01.2016 32-bit C:\Windows\Minidump\111710-19936-01.dmp 2 15 7600
