IRQL_NOT_LESS_OR_EQUAL blue screen
2010-11-13T12:01:26+00:00
i just got 2 blue screens again... they just pop up every time i play 3D Games :\
But i just updated my Video Drivers :S
and these codes don't help me at all
i also checked the dump files with BS View
red are: portcls.sys, p17.sys, ntkrnlpa.exe, halmacpi.dll,
and on the other dump: ntkrnlpa.exe, win32k.sys
even got a dump with: dxgmms1.sys but that was before installing new video drivers, didn't get that one since :\ also cdd.dll
i hope anyone can help me
OS: Windows 7 86x
  BCCode:    1000008e
  BCP1:    C0000005
  BCP2:    9E4E6F00
  BCP3:    A1D2F724
  BCP4:    00000000
  OS Version:    6_1_7600
  Service Pack:    0_0
  Product:    256_1
  BCCode:    d1
  BCP1:    B4F05950
  BCP2:    00000007
  BCP3:    00000001
  BCP4:    91DC475D
  Service Pack:    0_0
  Product:    256_1
2010-11-13T22:25:45+00:00
I'll reply in English here.
the PAGE_FAULT_IN_NONPAGED_AREA (50) is caused by the AVG driver:
    Image path: \SystemRoot\system32\DRIVERS\avgntflt.sys
    Image name: avgntflt.sys
    Timestamp:        Fri May 07 14:28:31 2010
Try to get an Update for AVG.
the KERNEL_MODE_EXCEPTION_NOT_HANDLED_M (1000008e) happens while GDI operations, so update the graphic card driver:
ChildEBP RetAddr  Args to Child
a1d2f7b8 9e4fa20e a1d2fcfc a1d2fb50 000004e8 win32k!ESTROBJ::vCharPos_H1+0x99
a1d2f7f0 9e4facfa ffbbe050 0000000b a1d2fcfc win32k!ESTROBJ::vInit+0x1d8
a1d2fb38 9e46af67 a1d2fcfc 0000004e 0000006a win32k!GreExtTextOutWLocked+0x62f
a1d2fbb4 9e4cfb07 02cccccc ffbbe068 00001004 win32k!GreBatchTextOut+0x1e6
a1d2fd24 82c4f3ec 000000c9 01ee8b70 01ee8b80 win32k!NtGdiFlushUserBatch+0x123
a1d2fd34 776c64f4 badb0d00 01ee8b70 00000000 nt!KiFastCallEntry+0xcc
    Image path: \SystemRoot\system32\DRIVERS\atikmdag.sys
    Image name: atikmdag.sys
    Timestamp:        Wed Sep 29 03:37:54 2010
the DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1) crash is caused by this driver:
    Image path: \SystemRoot\system32\drivers\P17.sys
    Image name: P17.sys
    Timestamp:        Fri Oct 16 04:11:53 2009
So update the soundblaster live card driver.
The other crashes are too old. They should be fixed with the newer drivers.
André
"A programmer is just a tool which converts caffeine into code" CLIP- Stellvertreter http://www.winvistaside.de/
46 additional answers
    2010-11-15T18:12:27+00:00
    Think video drivers though there can be other causes such as BIOS and memory.
    dxgmms1.sys crash – Blue Screen Of Death (others video drivers besides Nvidia can cause this)
    http://nzgeek.org/blog/dxgmms1-sys-crash-blue-screen-of-death/
    If there are RAID drivers they are very suspect and/or driver problems are very real prospects.
    Other major possibilities are Video and other drivers. See the driver section in my generic
    bluescreen troubleshooting methods below. BIOS, low level chipset drivers, memory and
    antivirus/antispyway/security programs can also cause this. Check the troubleshooter and when
    you get to the driver section refer to the generic methods in next message and then return to
    the troubleshooter if needed.
    BCCode: D1     0x000000D1
    Cause
    A driver tried to access an address that is pageable (or that is completely invalid) while the IRQL was too high.
    This bug check is usually caused by drivers that have used improper addresses.
    If the first parameter has the same value as the fourth parameter, and the third parameter indicates an execute operation, this bug check was likely caused by a driver that was trying to execute code when the code itself was paged out. Possible causes for the page fault include the following:
    • The function was marked as pageable and was running at an elevated IRQL (which includes obtaining a lock).
    • The function call was made to a function in another driver, and that driver was unloaded.
    • The function was called by using a function pointer that was an invalid pointer.
    BCCode: d1   0x000000d1  <-- read this linkhttp://www.faultwire.com/solutions-fatal\_error/DRIVER-IRQL-NOT-LESS-OR-EQUAL-0x000000D1-\*1210.html?order=votes
    See the troubleshooters above - update BIOS and drivers and check memory.
    Hope this helps.
    Rob Brown - MS MVP - Windows Desktop Experience : Bicycle - Mark Twain said it right.
    2010-11-16T07:43:11+00:00
    I already tried all of the steps above and even more =\
    • memory check => everything is ok
    • pagefile => deleted and recreated
    • Update Windows => Happens automaticly
    • Raid Controller => None
    • Latest Drivers => Done
    • Latest Updates => Yup
    • KB974431 => Also Already Installed
    well atleast i got rid of the Bluescreen from my Video Card - but it seems like my Sound card loves those..
    Could it help if i switch the Soundcarts socket on the mainboard? - there are 2 PCI's and i put it into the lower one; could that help or isn't it worth trying? cuz i'd have to break the metal for that :x
    p.s: most of the things mentioned i should check in my BIOS ... i just can't seem to find them there :|
    edit:\ I just used SiSoftware Sandra to analyze for system Problems and it told me this:
    • My Ram is not Registred or Buffered and i should do that ( tho idk how - already checked)
    • It's telling my my 2nd CPU Sensor has 82°C; wich can't be true :S - since my CPU is running at 40-60°C
    • WmiPrvSE.exe doesn't exist anymore
    • sppsvc.exe doesn't exist anymore
    • PrintIsolationHost doesn't exist anymore
    • Midi output driver G5 Invalid ( i got the newest driver for my card =\  - tho who cares about Midi )
    • ATI (AMD) IXP SB600 PCI to PCI Bridge: 'VGA palette snooping' should be deactivated (how?)
    • Mainboard Temperature too high ( weird it's at 36°C )
    • Also it's telling my my CPU is not able to run in bus  "master"
    => And wth while scanning my soundcard just stopped working o_O what ever i play .. nothing.. hate ;_; - i think creative doesn't support their old products as much as they should =..
    oh well..
    thanks! - you guys are great :)
    2010-11-16T08:03:26+00:00
    BIOS updates come from the System Maker or MotherBoard Maker for custom systems.
    Make sure you update the Sound drivers at the same time from System Maker pr MotherBoard
    Maker's site. There may be updated drivers available from the Sound Device Maker's Site.
    You can disable the on-board sound in the BIOS and use an add-in Sound card or a USB sound
    card. (If the sound card is an issue.)
    Hope this helps.
    2010-11-16T08:33:00+00:00
    Already happend - the onboard soundcard stopped to work - so i had to deactivate it in the bios a while ago and deinstall the drivers.
    I got a SB Live! 24-Bit now from Creative and also got the latest drivers "SB24_PCDRV_LB_1_04_0090" - wich are the newest for this model
    i even looked up the modelnumber on my card "SB0410" so that shouldn't be the problem.
    But quick update: I moved the soundcard up by 1 slot and cleaned it from dust and other stuff that could have caused to problems ( looked like smth glueish was on it - i rubbed it off carefully ) maybe that made short time overload or a short, idk i will test it now on the 2nd PCI bench and keep you updated.
    and a BIOS update shouldn't help me too much if you check this link:
    http://www.gigabyte.de/products/product-page.aspx?pid=2695&dl=1#bios
    I got the version number F7, there's only F8 and F9 - both don't have updates that would help me in any way and F10 is Beta nty.
    Also i never heared an PC analytic program telling me to update my Video BIOS o_O - are there even any Grafic card manufacturer that have Video BIOS updates available? never heared of that.
    thanks a lot so far ! i hope i can get rid of my bluescreens :D!
    Basti
