Zune Wireless Sync Error C00D07C9
2010-11-03T12:27:31+00:00
Even though my phone is configures and connects to my router for internet connection - I cannot configure wireless sync as I get the following error "C00D07C9"?
I have tried the FAQ but still nothing.
Please help.
Trevor
Windows for home | Other | Music, photos, and video
2011-02-18T02:57:16+00:00
Good call with this article!  I too had the same error with my Samsung Focus but I figured out that for some reason my route was not able to identify a device name, only the MAC address.  (possibly a bug in WP7)  Apparently Zune does not like this because as soon as I used a static IP address for my phone's MAC address and gave it the name of my phone as recognized by Zune, it worked!
Cheers!
2010-11-08T11:11:38+00:00
Hi TrevorScarlett
Are you still receiving the same error message?
Have you tried to configure the device manually?
There’re some important recommendations that you must be aware:
Make sure that the access point or the router to which you connect is a DHCP server (make sure that DHCP is turned on).
Try to reserve an IP address for the Zune device on the router.
If you are using two routers, make sure that the router to which you try to connect is the DHCP server.
2010-11-04T14:45:19+00:00
Hi TrevorScarlett,
You may find the following article helpful:
http://support.microsoft.com/kb/952304
111 additional answers
    2013-03-16T11:53:00+00:00
    If that doesn't work then the only other thing I did (this may have fixed it too) was go to Start > Search programs and files > Windows Firewall with Advanced Security > Inbound Rules (Tab on the left) > Scroll down to where all the Zune rules are (Network Sharing Service rules) > click the first "Network Sharing Service" entry then hold ctrl+shift and click on the last entry > right click and finally click on Enable Rule. Then restart Zune and Wireless Sync should work :)
    Daniel
     This solved it for me on windows 8, connected to ethernet
    2013-03-25T10:07:46+00:00
    Cool! Glad to know I helped :D Yeah not sure why those rules were disabled in the first place :p
