Zune Wireless Sync Error C00D07C9
2010-11-03T12:27:31+00:00
Even though my phone is configures and connects to my router for internet connection - I cannot configure wireless sync as I get the following error "C00D07C9"?
I have tried the FAQ but still nothing.
Please help.
Trevor
Windows for home | Other | Music, photos, and video
2011-02-18T02:57:16+00:00
Good call with this article!  I too had the same error with my Samsung Focus but I figured out that for some reason my route was not able to identify a device name, only the MAC address.  (possibly a bug in WP7)  Apparently Zune does not like this because as soon as I used a static IP address for my phone's MAC address and gave it the name of my phone as recognized by Zune, it worked!
Cheers!
2010-11-08T11:11:38+00:00
Hi TrevorScarlett
Are you still receiving the same error message?
Have you tried to configure the device manually?
There’re some important recommendations that you must be aware:
Make sure that the access point or the router to which you connect is a DHCP server (make sure that DHCP is turned on).
Try to reserve an IP address for the Zune device on the router.
If you are using two routers, make sure that the router to which you try to connect is the DHCP server.
2010-11-04T14:45:19+00:00
Hi TrevorScarlett,
You may find the following article helpful:
http://support.microsoft.com/kb/952304
111 additional answers
    2012-11-28T16:11:44+00:00
    IS it now possible to confirm that: Microsoft f... up something that really works very very very well with nokias SYMBIAN phones ? That BOTH the phone (obviously) AND the pc/server that runs Zune MUST be connected through wifi !!! IN WHAT WORLD IS THAT A GOOD SOLUTION ? I've seen a lot of people in here, who - like I do, have my server attached to the network with a nice, trustful CABLE ! For what ? Security and speed. Besides the point, that my server is not fittet with wifi. Dear Microsoft. This should NOT be hard to solve: Understand what we want: 1: Turn on pc(server 2: Rev up Zune (we really don't wanna - replace the **** with Nokia Suite. It's much better - in that - IT WORKS) 3: Connect Phone to Wifi. No fixed ip, no tin foil around th lower 3'rd of the phone. JUST CONNECT. 4: NOW - as by magic (at least for MS) Zune figures out: HEY - I know this unit on the network (It can be done - my router does it - and my server - and my symbian phone) 5: NOW SYNC ! Fix it, or Your WP adventure will go down in flames. Most basic featur. SYNC.
    2012-11-28T17:16:17+00:00
    The PC running Zune can be wired or wireless. We have both here. Wireless sync works on my wife's wired PC with her phone perfectly. My phone does not work on my PC whether I'm wired or wireless.
    In my case, a LOT of substitution testing is pointing heavily toward the phone. Now waiting to see if 7.8 fixes it without having to do a hard reset.
