Zune Wireless Sync Error C00D07C9
2010-11-03T12:27:31+00:00
Even though my phone is configures and connects to my router for internet connection - I cannot configure wireless sync as I get the following error "C00D07C9"?
I have tried the FAQ but still nothing.
Please help.
Trevor
Windows for home | Other | Music, photos, and video
2011-02-18T02:57:16+00:00
Good call with this article!  I too had the same error with my Samsung Focus but I figured out that for some reason my route was not able to identify a device name, only the MAC address.  (possibly a bug in WP7)  Apparently Zune does not like this because as soon as I used a static IP address for my phone's MAC address and gave it the name of my phone as recognized by Zune, it worked!
Cheers!
2010-11-08T11:11:38+00:00
Hi TrevorScarlett
Are you still receiving the same error message?
Have you tried to configure the device manually?
There’re some important recommendations that you must be aware:
Make sure that the access point or the router to which you connect is a DHCP server (make sure that DHCP is turned on).
Try to reserve an IP address for the Zune device on the router.
If you are using two routers, make sure that the router to which you try to connect is the DHCP server.
2010-11-04T14:45:19+00:00
Hi TrevorScarlett,
You may find the following article helpful:
http://support.microsoft.com/kb/952304
111 additional answers
    2011-07-29T02:56:46+00:00
    Thank you! I could not get any other tip to work, and your tip finally made it work.  My antivirus software had a firewall that i forgot about
    2011-08-07T05:49:24+00:00
    Ok the exact problem happens to me i do exactly what it says but the "show advanced settings" doesn't show
    i went to :settings>Phone>wireless sync>set up wireless sync.
    then a black window comes up that says:
    "comfirm network
    your phone is connected to:
    "network name" (SSID)
    ________
    | refresh  |
    This will be the default network for wireless sync between this
    computer and this phone
    to use this network, connect to a different network using the
    phone and click refresh above."
