Zune Wireless Sync Error C00D07C9
2010-11-03T12:27:31+00:00
Even though my phone is configures and connects to my router for internet connection - I cannot configure wireless sync as I get the following error "C00D07C9"?
I have tried the FAQ but still nothing.
Please help.
Trevor
Windows for home | Other | Music, photos, and video
2011-02-18T02:57:16+00:00
Good call with this article!  I too had the same error with my Samsung Focus but I figured out that for some reason my route was not able to identify a device name, only the MAC address.  (possibly a bug in WP7)  Apparently Zune does not like this because as soon as I used a static IP address for my phone's MAC address and gave it the name of my phone as recognized by Zune, it worked!
Cheers!
2010-11-08T11:11:38+00:00
Hi TrevorScarlett
Are you still receiving the same error message?
Have you tried to configure the device manually?
There’re some important recommendations that you must be aware:
Make sure that the access point or the router to which you connect is a DHCP server (make sure that DHCP is turned on).
Try to reserve an IP address for the Zune device on the router.
If you are using two routers, make sure that the router to which you try to connect is the DHCP server.
2010-11-04T14:45:19+00:00
Hi TrevorScarlett,
You may find the following article helpful:
http://support.microsoft.com/kb/952304
111 additional answers
    2010-12-12T13:13:58+00:00
    I just need some clarfication. Sorry to bump this old post, but I thought I'd ask here rather than create a new topic. According to this:
    • Your phone and PC are both connected to your home Wi-Fi network. Note that wireless sync is not supported on workplace Wi-Fi networks.
    When setting up wireless sync is it 100% necessary to have your PC connected to your LAN via WiFi as well as your Zune? The PC I sync from only utilizes the wired portion of my LAN.
    Thanks!
    No, not at all.  either, or , or both.
    Zune MVP
    2011-01-15T21:50:57+00:00
    Above mentioned fixes do not work for me.  I have a brand new HTC HD7.  I have all firewalls off,  no MAC filtering on my router, anti-virus disabled, connected to the same wireless router, and still no connection.  I also have the above mentioned zune software version that does not have an advanced settings button. I have ports 5432, 9080, 9081, and 4321 forwarded, but I doubt that is the problem.   What am I missing? I always get error c00d07c9 when setting up sync.  Any help would be awesome.
