Zune Wireless Sync Error C00D07C9
2010-11-03T12:27:31+00:00
Even though my phone is configures and connects to my router for internet connection - I cannot configure wireless sync as I get the following error "C00D07C9"?
I have tried the FAQ but still nothing.
Please help.
Trevor
Windows for home | Other | Music, photos, and video
2011-02-18T02:57:16+00:00
Good call with this article!  I too had the same error with my Samsung Focus but I figured out that for some reason my route was not able to identify a device name, only the MAC address.  (possibly a bug in WP7)  Apparently Zune does not like this because as soon as I used a static IP address for my phone's MAC address and gave it the name of my phone as recognized by Zune, it worked!
Cheers!
2010-11-08T11:11:38+00:00
Hi TrevorScarlett
Are you still receiving the same error message?
Have you tried to configure the device manually?
There’re some important recommendations that you must be aware:
Make sure that the access point or the router to which you connect is a DHCP server (make sure that DHCP is turned on).
Try to reserve an IP address for the Zune device on the router.
If you are using two routers, make sure that the router to which you try to connect is the DHCP server.
2010-11-04T14:45:19+00:00
Hi TrevorScarlett,
You may find the following article helpful:
http://support.microsoft.com/kb/952304
111 additional answers
    2010-11-04T15:29:47+00:00
    I have been throught all of these and nothing.  I can connect to the router as when I am home I use it for browsing email and web from my phone.  I just for some reason cannot wirelessly sync my Win Phone 7.
    Strange.
    Trevor
    2010-11-12T12:31:07+00:00
    I have the same problem, the article is not helpful as it says to go to "Show Advanced Settings." but that option won't appear.
    1.      Settings-Wireless sync:
    2.      Clicked Set Up wireless sync
    3.      Boom!
    4.      Web help link points here:http://www.zune.net/en-US/support/webhelp/C00D07C9.htm?&webhelp\_mpver=4.7.1404.0&webhelp\_id=C00D07C9&webhelp\_contextid=0&webhelp\_originalid=C00D07C9&webhelp\_locale=en-US, which says that this should be done:
    a. In the Zune software, clickSettings,Device,Wireless Sync.
    b. Click Set Up Wireless Sync,Show Advanced Settings.
    c. Under Network Type, selectShared Authentication Using WEP Key and enter your network key.
    5.      No Show Advanced Settings in my UI… anybody can help?
