network error 0x80070035 the network path was not found
2010-12-22T04:27:15+00:00
I have network problem with Win7 pro. When I click on my network folder links for my local network I geterror 0x80070035 the network path was not found.
The network has been set up for 4 months it includes 3 PC's, up until now the only problems have been minor, such as links disappearing from network, which a system restart has been needed to refresh the network and that worked.
The other 2 PC's can see and access each other and see and access the troubled Win7 Pro PC, but the troubled Win7 Pro PC can't even get to its own network folders without theerror 0x80070035 the network path was not found popping up.
After hours of checking I have found no resolution, however as I restored the PC several times, occasionally the service would reappear for awhile.
In my search for possible causes I have opened Device Manager  with the show hidden devices selected, under Network adapters and found189 instances of Microsoft 6to4 Adapter.
I only have 3 PC's networked! Does anyone know if this is a normal number for Win7 or have I found part of an anomaly.
Any suggestions?
c.maresca
2010-12-23T22:33:25+00:00
Thank you for your input.
In searching for a solution to my Win7 Pro network problem I have been over all of the settings you mentioned before I posted my question and found no problem , everything is as required to have a complete network and the network was fine other than the occasional missing links I described in my original post. The only addition to the PC configuration since the network was originally set up was automatic updates by MS update.
The good news is that as I have researched this to the max, I found 2 posts in the Win7 network forum that combined provided the fix for my network problem.
As I have been researching this I have noticed many people are having similar network issues. I know there are many reasons for connectivity issues, so the solutions are specific to the problems, but if other network users are experiencing the problem of multiple instances of Microsoft 6to4 Adapter and local network error 0x80070035 the network path was not found the solution I located has worked for me.
If you would like to know more reply to this feed.
c.maresca
45 additional answers
    2016-10-07T09:45:45+00:00
    I appear to have exactly the same problem. On which PC did you clear the route table, the one that could not access, or the one that could not be accessed? And how do I clear the route table, is that in the hosts file?
    2017-02-18T22:18:56+00:00
    I want to know how to fix it...Thanks
    2017-02-20T16:01:45+00:00
    Your Windows question is more complex than what is typically answered in the Microsoft Answers forums. It is better suited for the IT Pro audience on TechNet. Please post your question in the TechNet Forum.
    Regards.
    2017-03-28T04:29:41+00:00
    I have a laptop with windows 10 home and a desktop with windows 10 pro.
    Both have wireless router connection to the internet.
    Both can ping and tracert each other.
    They are both on the same WORKGROUP.
    Both local firewalls are disabled.
    They each have a shared folder.
    They can both "see" each other in the Network group in file explorer.
    When I click on either one of them I get error 0x80070035 "The network path was not found".
    I have been trying to resolve this for many days without success.
    Please help me get these 2 computers to share folders.
