network error 0x80070035 the network path was not found
2010-12-22T04:27:15+00:00
I have network problem with Win7 pro. When I click on my network folder links for my local network I geterror 0x80070035 the network path was not found.
The network has been set up for 4 months it includes 3 PC's, up until now the only problems have been minor, such as links disappearing from network, which a system restart has been needed to refresh the network and that worked.
The other 2 PC's can see and access each other and see and access the troubled Win7 Pro PC, but the troubled Win7 Pro PC can't even get to its own network folders without theerror 0x80070035 the network path was not found popping up.
After hours of checking I have found no resolution, however as I restored the PC several times, occasionally the service would reappear for awhile.
In my search for possible causes I have opened Device Manager  with the show hidden devices selected, under Network adapters and found189 instances of Microsoft 6to4 Adapter.
I only have 3 PC's networked! Does anyone know if this is a normal number for Win7 or have I found part of an anomaly.
Any suggestions?
c.maresca
2010-12-23T22:33:25+00:00
Thank you for your input.
In searching for a solution to my Win7 Pro network problem I have been over all of the settings you mentioned before I posted my question and found no problem , everything is as required to have a complete network and the network was fine other than the occasional missing links I described in my original post. The only addition to the PC configuration since the network was originally set up was automatic updates by MS update.
The good news is that as I have researched this to the max, I found 2 posts in the Win7 network forum that combined provided the fix for my network problem.
As I have been researching this I have noticed many people are having similar network issues. I know there are many reasons for connectivity issues, so the solutions are specific to the problems, but if other network users are experiencing the problem of multiple instances of Microsoft 6to4 Adapter and local network error 0x80070035 the network path was not found the solution I located has worked for me.
If you would like to know more reply to this feed.
c.maresca
45 additional answers
    2017-03-28T04:42:11+00:00
    Did not work for me?????
    2017-04-08T08:13:58+00:00
    respond
    2017-04-15T14:18:07+00:00
    Roger H Grant's was the only answer which worked. I had the problem ONLY on a Windows 7 pro - the two non-Pro machines seem to be able to re-use the existing 6to4 adapter and do not need to start a new instance. I had about 200, b.t.w.
    2017-05-01T22:25:17+00:00
    We were having this problem on a Windows 10 Pro (1603) to Windows 10 Pro (1603) shared printer issue.  The PC with the shared printer had a PC name longer than 15 characters.  The PC connecting to it could see the PC and see the share, but when trying to connect to the printer it would give the 80070035 error.  I tried many different things and the thing that finally worked was:
    1. From the Start menu search for:  turn windows features
    2. select Turn Windows Features on or off from the list
    3. scroll down and uncheck SMB 1.0/CIFS File Sharing support and click OK
    4. Restart when prompted
    5. Then re-enable the feature again by going into Turn Windows Features on or off and then check SMB 1.0/CIFS File Sharing support, click OK
    6. Restart when prompted
    This seemed to reset whatever was causing the problem and allowed us to connect to the printer. Hope this helps.
