7 64-bit Medal of Honor Allied Assault
2010-12-07T15:20:53+00:00
i installed mohaa to a native windows xp 32-bit machine and copied the whole installation folder over to a 7 64-bit machine.
before running the game i ran the configure.exe located in the main install folder then boom.
MOS
this is not a question... this is the fix : )
Windows for home | Previous Windows versions | Gaming
2016-01-02T05:35:23+00:00
"Game won't even start..."
Assuming you are using the  disk based version of the game, your problem would be from a new source.
A malware introduced by MS with Win10 called DRM Blocking , and subversively installed to Win7/8/8.1 via
Windows Updates, that tries to prevent  people from playing hundreds of disk based games.
This game has a file on disk 2 titled secdrv.sys which is targetd by DRM Blocking.
I have a long rant, and options for bypassing the DRM Blocking   --here--  .
  • Using a noCD circumvents both DRM Blocking and the CD check - medal-honor-allied-assaultI used to use this noCD for MOH-AA before I bought the download version with the two expansion packs from
Good Old Games  ( Normally $10 USD, but $5- USD or less when a sale is on).
http://www.gog.com/
2011-11-28T01:11:10+00:00
ah yes ---- install on my Dell XPS Laptop was a pain --- kept crashing, folders missing... until now.
As noted above, copied EAGAMES folder from my Windows XP desktop onto my XPS laptop.
Placed the folder in C Drive, program files (not x86).
Run configure.exe located in mohaa/main folder... and boom.. works like a charm...well, so far so good
2011-04-14T10:51:43+00:00
Wouldn't have thought that necessary. I was able to install MOH-AA with no compatibility
settings on Win7 64bit.
It may be because I don't install to the default directory - Program Files (x86).
Aside from that all I can think of that may be different is patching the game, and having the Windows updates all installed (except the 'optional'  updates).
52 additional answers
    2016-01-02T05:10:22+00:00
    "i installed mohaa to a native windows xp 32-bit machine and copied the whole installation folder over to a 7 64-bit machine.
    before running the game i ran the configure.exe located in the main install folder."
    the game itself needs to be installed to a DIFFERENT machine or a 'virtual machine'.. do NOT install the game to the machine you want to run it on.
    after you do that, copy the mohaa installation folder from the machine you installed it on over to the machine you want to run it on.. (basically mohaa is NOT installed to the machine you're going to run it on.
    run the configure.exe from the mohaa folder before running the game on the NEW machine that you copied the folder to.
  2. Deleted
