7 64-bit Medal of Honor Allied Assault
2010-12-07T15:20:53+00:00
i installed mohaa to a native windows xp 32-bit machine and copied the whole installation folder over to a 7 64-bit machine.
before running the game i ran the configure.exe located in the main install folder then boom.
MOS
this is not a question... this is the fix : )
Windows for home | Previous Windows versions | Gaming
2016-01-02T05:35:23+00:00
"Game won't even start..."
Assuming you are using the  disk based version of the game, your problem would be from a new source.
A malware introduced by MS with Win10 called DRM Blocking , and subversively installed to Win7/8/8.1 via
Windows Updates, that tries to prevent  people from playing hundreds of disk based games.
This game has a file on disk 2 titled secdrv.sys which is targetd by DRM Blocking.
I have a long rant, and options for bypassing the DRM Blocking   --here--  .
  • Using a noCD circumvents both DRM Blocking and the CD check - medal-honor-allied-assaultI used to use this noCD for MOH-AA before I bought the download version with the two expansion packs from
Good Old Games  ( Normally $10 USD, but $5- USD or less when a sale is on).
http://www.gog.com/
2011-11-28T01:11:10+00:00
ah yes ---- install on my Dell XPS Laptop was a pain --- kept crashing, folders missing... until now.
As noted above, copied EAGAMES folder from my Windows XP desktop onto my XPS laptop.
Placed the folder in C Drive, program files (not x86).
Run configure.exe located in mohaa/main folder... and boom.. works like a charm...well, so far so good
2011-04-14T10:51:43+00:00
Wouldn't have thought that necessary. I was able to install MOH-AA with no compatibility
settings on Win7 64bit.
It may be because I don't install to the default directory - Program Files (x86).
Aside from that all I can think of that may be different is patching the game, and having the Windows updates all installed (except the 'optional'  updates).
52 additional answers
    2013-04-12T09:44:33+00:00
    BossDweebe, I apologize for the childish comment.
    2013-04-13T11:02:39+00:00
    Thanks, mate. Accepted, and appreciated.  It's easy to get frustrated with games and computers in general.  Some people come in guns blazing with their first post. I've been  yelling at Steam quite
    a bit today (Not on the forums, just the at the setup on the machine not playing nice),
    and I can appreciate you may be in a stressful situation in general.
    About the only other thing I can suggest at the moment, is not installing to the default location -
    Program Files (X86).
    I don't know if it helps with this game as I install all games to another HDD or partition, and it is
    mostly helpful with permissions issues, but it is a useful trick for some games and may be worth
    a try. Just make a new folder in C:\ and install games to a sub-folder in that if you don't have another
    Partition.
    If you are able to upload a screen-shot to Skydrive it may help with troubleshooting.
    Just leave us a link .
    Do you have other games running properly ?
    @ HH -  If the games .exe has Compatibility set the rest is automatic. There is no need to trawl
    through the whole game, or change the shortcut.
    The most effective way to use Compatibility is to  change compatibility in the installer (setup.exe)
    on the games disk and install using Compatibility.
