7 64-bit Medal of Honor Allied Assault
2010-12-07T15:20:53+00:00
i installed mohaa to a native windows xp 32-bit machine and copied the whole installation folder over to a 7 64-bit machine.
before running the game i ran the configure.exe located in the main install folder then boom.
MOS
this is not a question... this is the fix : )
Windows for home | Previous Windows versions | Gaming
2016-01-02T05:35:23+00:00
"Game won't even start..."
Assuming you are using the  disk based version of the game, your problem would be from a new source.
A malware introduced by MS with Win10 called DRM Blocking , and subversively installed to Win7/8/8.1 via
Windows Updates, that tries to prevent  people from playing hundreds of disk based games.
This game has a file on disk 2 titled secdrv.sys which is targetd by DRM Blocking.
I have a long rant, and options for bypassing the DRM Blocking   --here--  .
  • Using a noCD circumvents both DRM Blocking and the CD check - medal-honor-allied-assaultI used to use this noCD for MOH-AA before I bought the download version with the two expansion packs from
Good Old Games  ( Normally $10 USD, but $5- USD or less when a sale is on).
http://www.gog.com/
2011-11-28T01:11:10+00:00
ah yes ---- install on my Dell XPS Laptop was a pain --- kept crashing, folders missing... until now.
As noted above, copied EAGAMES folder from my Windows XP desktop onto my XPS laptop.
Placed the folder in C Drive, program files (not x86).
Run configure.exe located in mohaa/main folder... and boom.. works like a charm...well, so far so good
2011-04-14T10:51:43+00:00
Wouldn't have thought that necessary. I was able to install MOH-AA with no compatibility
settings on Win7 64bit.
It may be because I don't install to the default directory - Program Files (x86).
Aside from that all I can think of that may be different is patching the game, and having the Windows updates all installed (except the 'optional'  updates).
52 additional answers
    2016-01-24T01:18:16+00:00
    BossDweeb,
    This worked for me instantaneously, just as you said.  I was sure a Windows update had been the culprit, but you pinpointed it for me.  May I suggest that you spread  your fix to a larger audience.  It was not until I figured out that it was a compatibility issue and googled that, that I came to your post here.  There seems to be so many people out there with this same problem.  You have the answer!
    2016-01-02T06:02:28+00:00
    good to see you again BOSS and sure i totally get it and i do believe you are correct after a quick chrome search. 7/8/8.1 is good to go.. he should be able to get the game rolling on his os.. i'm deep in win 10 though and i know for a fact that the nocd cracks are viri infested websites. (don't ask; years of gaming) but in my case i think i'd have to buy it again (which isn't an issue) but i haven't played mohaa in such a long time i doubt i would.. shame they make ya buy the game again without drm (safedisc/securom) especially after all the pouting that all the gamers did AGAINST drm in the first place.
    anyway...
    happy new year to you Dweebe! :)
