Right-click on the Desktop, choose Screen Resolution then change Orientation to Landscape and Apply the setting.
how do I rotate screen display 90 degrees - I'm reading sideways
Somehow my Dell Inspiron laptop screen rotated right 90 degrees so I am reading sideways with my head tilted to the right. How can I fix it by rotating the display 90 degrees left?
MODERATOR'S NOTE 7 JULY 2018
This 7 1/2 year old thread was answered within a day of it's initial posting (as well as several more times since then). It has run its course and is now locked. For your convenience, three solutions are repeated below:
MSEng, February 27, 2011:
ThrashZone, February 27, 2011:
If that doesn't work try to right click your desktop and select graphics properties, it will open your graphics chip and look for (rotate) and click it and some choices should be listed.
You can also right click and select (graphics options), point to (rotation) and check (normal) if it's not already or adjust it to the right spin direction :)
Bruce Hagen, February 28, 2011:
Hold down the Ctrl+Alt keys and use the arrow keys to rotate it back.
If none of these solutions solve your problem, please read the following articles and ask your own new question, giving specific details about your system and your problem:
How to begin your own, new thread about your computer & your problem
Hi Dennis,
To address your concern, you can refer to Ronnie Vernon's post on September 19, 2010 for further troubleshooting by clicking on this link.
Let us know how it goes.
Regards.
118 additional answers
2015-03-20T08:59:02+00:00 Cheers Bruce.. I was charged £20 once for this while a guy spent 5mins making out he was trying different things.. Simplest was is as you said to press Ctrl and Alt together and appropriate 'Arrow' key to move screen 90degrees whichever way you need to..
2015-05-18T10:10:05+00:00 TY IT FIXED IT
2015-06-08T00:02:59+00:00 I had the same problem just now - something fell onto my keyboard and the screen rotated 90 degrees counterclockwise - I didn't know what happened or how to fix it! I was able to search with my head sideways and found this answer - worked like a charm! Thanks!
