I also tried creating a new profile like The Saint 22 suggested but the problem is present in the new profile too. :(
Explorer.exe Crashes Constantly When Accessing Control Panel or Any Start Menu Item on WIN 7 x64
I have explorer.exe crashing when I try to open the Control Panel on Seven x64 and on some right clicking on files and on anything I search or try to open in the Start Menu.
I think the problem started after I created the Godmode folder through Windows 7 Manager from Yamisoft (I managed to get rid of Godmode anyway).
I can access all components of the Control Panel through the cpl files in Windows directory and none crashes but if I try to open the main Control Panel window explorer crashes.
I run ShellExView and disabled all Shell extension which are NOT from Microsoft and the problem persist.
The problem doesn't occur in Safe Boot mode.
I checked the Event Viewer and the explorer crashes have this info:
The description for Event ID 1000 from source Application Error cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
explorer.exe6.1.7600.164504aebab8dntdll.dll6.1.7600.165594ba9b802c000041d000000000004d301b3c01cbbf3adb80f4d8C:\Windows\explorer.exeC:\Windows\SYSTEM32\ntdll.dlla36102d9-2b31-11e0-94f8-001b24531bd0
********************************System
– Provider
[ Name] Application Error
– EventID 1000
[ Qualifiers] 0
Level 2
Task 100
Keywords 0×80000000000000
– TimeCreated
[ SystemTime] 2011-01-28T22:55:02.000000000Z
EventRecordID 326966
Channel Application
Computer MYPC
Security
- EventData
I run sfc while in safe mode since it wouldn't start in normal mode and it says that it couldn't repair some files.
2011-01-31 09:32:39, Info CBS Starting TrustedInstaller initialization.
2011-01-31 09:32:39, Info CBS Loaded Servicing Stack v6.1.7601.17514 with Core: C:\Windows\winsxs\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.1.7601.17514_none_678566b7ddea04a5\cbscore.dll
2011-01-31 09:32:41, Info CSI 00000001@2011/1/31:08:32:41.135 WcpInitialize (wcp.dll version 0.0.0.6) called (stack @0x7fef1f5e94d @0x7fef31a9839 @0x7fef31734d3 @0xff5ce97c @0xff5cd799 @0xff5cdb2f)
2011-01-31 09:32:41, Info CSI 00000002@2011/1/31:08:32:41.245 WcpInitialize (wcp.dll version 0.0.0.6) called (stack @0x7fef1f5e94d @0x7fef31f6806 @0x7fef31c2a9c @0x7fef31735a9 @0xff5ce97c @0xff5cd799)
2011-01-31 09:32:41, Info CSI 00000003@2011/1/31:08:32:41.247 WcpInitialize (wcp.dll version 0.0.0.6) called (stack @0x7fef1f5e94d @0x7fef9d68728 @0x7fef9d68856 @0xff5ce474 @0xff5cd7de @0xff5cdb2f)
2011-01-31 09:32:41, Info CBS Ending TrustedInstaller initialization.
2011-01-31 09:32:41, Info CBS Starting the TrustedInstaller main loop.
2011-01-31 09:32:41, Info CBS TrustedInstaller service starts successfully.
2011-01-31 09:32:41, Info CBS SQM: Initializing online with Windows opt-in: False
2011-01-31 09:32:41, Info CBS SQM: Cleaning up report files older than 10 days.
2011-01-31 09:32:41, Info CBS SQM: Requesting upload of all unsent reports.
2011-01-31 09:32:41, Info CBS SQM: Failed to start upload with file pattern: C:\Windows\servicing\sqm\*_std.sqm, flags: 0x2 [HRESULT = 0x80004005 - E_FAIL]
2011-01-31 09:32:41, Info CBS SQM: Failed to start standard sample upload. [HRESULT = 0x80004005 - E_FAIL]
2011-01-31 09:32:41, Info CBS SQM: Queued 0 file(s) for upload with pattern: C:\Windows\servicing\sqm\*_all.sqm, flags: 0x6
2011-01-31 09:32:41, Info CBS SQM: Warning: Failed to upload all unsent reports. [HRESULT = 0x80004005 - E_FAIL]
2011-01-31 09:32:41, Info CBS No startup processing required, TrustedInstaller service was not set as autostart, or else a reboot is still pending.
2011-01-31 09:32:41, Info CBS NonStart: Checking to ensure startup processing was not required.
2011-01-31 09:32:41, Info CSI 00000004 IAdvancedInstallerAwareStore_ResolvePendingTransactions (call 1) (flags = 00000004, progress = NULL, phase = 0, pdwDisposition = @0xbcf9f0
2011-01-31 09:32:41, Info CSI 00000005 Creating NT transaction (seq 1), objectname [6]"(null)"
2011-01-31 09:32:41, Info CSI 00000006 Created NT transaction (seq 1) result 0x00000000, handle @0x248
2011-01-31 09:32:41, Info CSI 00000007@2011/1/31:08:32:41.327 CSI perf trace:
CSIPERF:TXCOMMIT;815
2011-01-31 09:32:41, Info CBS NonStart: Success, startup processing not required as expected.
2011-01-31 09:32:41, Info CBS Startup processing thread terminated normally
2011-01-31 09:32:41, Info CSI 00000008 CSI Store 3337712 (0x000000000032edf0) initialized
2011-01-31 09:32:41, Info CBS Session: 30130465_1825506437 initialized by client WindowsUpdateAgent.
2011-01-31 09:32:41, Info CBS Failed to internally open package. [HRESULT = 0x800f0805 - CBS_E_INVALID_PACKAGE]
2011-01-31 09:32:41, Info CBS Session: 30130465_1825536439 initialized by client WindowsUpdateAgent.
2011-01-31 09:32:54, Info CBS Session: 30130465_1952173682 initialized by client WindowsUpdateAgent.
2011-01-31 09:32:54, Info CBS Appl: detect Parent, Package: Package_for_KB2120976~31bf3856ad364e35~x866.1.1.0, Parent: Microsoft-Media-Foundation-Package~31bf3856ad364e35~x866.1.7600.16385, Disposition = Detect, VersionComp: EQ, ServiceComp:
EQ, BuildComp: EQ, DistributionComp: GE, RevisionComp: GE, Exist: present
2011-01-31 09:32:54, Info CBS Appl: detectParent: package: Package_for_KB2120976~31bf3856ad364e35~x86~~6.1.1.0, no parent found, go absent
2011-01-31 09:32:54, Info CBS Appl: detect Parent, Package: Package_for_KB2120976~31bf3856ad364e35~x866.1.1.0, Parent: WinEmb-Media-Support~31bf3856ad364e35~x866.1.7600.16385, Disposition = Detect, VersionComp: EQ, ServiceComp: EQ, BuildComp:
2011-01-31 09:32:54, Info CBS Appl: detect Parent, Package: Package_for_KB2120976~31bf3856ad364e35~x866.1.1.0, Parent: Microsoft-Windows-Media-Format-Package~31bf3856ad364e35~x866.1.7600.16385, Disposition = Detect, VersionComp: EQ,
ServiceComp: EQ, BuildComp: EQ, DistributionComp: GE, RevisionComp: GE, Exist: present
2011-01-31 09:32:54, Info CBS Appl: detect Parent, Package: Package_for_KB2120976~31bf3856ad364e35~x866.1.1.0, Parent: WinEmb-PremiumCodecs-WMV~31bf3856ad364e35~x866.1.7600.16385, Disposition = Detect, VersionComp: EQ, ServiceComp: EQ,
2011-01-31 09:32:54, Info CBS Appl: detect Parent, Package: Package_for_KB2120976~31bf3856ad364e35~x86~~6.1.1.0, disposition state from detectParent: Absent
2011-01-31 09:32:54, Info CBS Appl: Evaluating package applicability for package Package_for_KB2120976~31bf3856ad364e35~x86~~6.1.1.0, applicable state: Absent
2011-01-31 09:32:54, Info CBS EvaluateApplicability, package: Package_for_KB2120976~31bf3856ad364e35~x86~~6.1.1.0, Package applicability: Absent.
2011-01-31 09:32:54, Info CBS Session: 30130465_1952653710 initialized by client WindowsUpdateAgent.
2011-01-31 09:32:54, Info CBS Appl: detect Parent, Package: Package_for_KB2120976~31bf3856ad364e35~amd646.1.1.0, Parent: Microsoft-Media-Foundation-Package~31bf3856ad364e35~amd646.1.7600.16385, Disposition = Detect, VersionComp: EQ,
2011-01-31 09:32:54, Info CBS Appl: detectParent: package: Package_for_KB2120976~31bf3856ad364e35~amd646.1.1.0, related parent found: Microsoft-Media-Foundation-Package~31bf3856ad364e35~amd646.1.7601.17514, which is not real parent
2011-01-31 09:32:54, Info CBS Appl: detectParent: package: Package_for_KB2120976~31bf3856ad364e35~amd646.1.1.0, parent found: Microsoft-Media-Foundation-Package~31bf3856ad364e35~amd646.1.7600.16385, state: Superseded
2011-01-31 09:32:54, Info CBS Appl: detect Parent, Package: Package_for_KB2120976~31bf3856ad364e35~amd646.1.1.0, Parent: WinEmb-Media-Support~31bf3856ad364e35~amd646.1.7600.16385, Disposition = Detect, VersionComp: EQ, ServiceComp: EQ,
2011-01-31 09:32:54, Info CBS Appl: detectParent: package: Package_for_KB2120976~31bf3856ad364e35~amd64~~6.1.1.0, no parent found, go absent
2011-01-31 09:32:54, Info CBS Appl: detect Parent, Package: Package_for_KB2120976~31bf3856ad364e35~amd646.1.1.0, Parent: Microsoft-Windows-Media-Format-Package~31bf3856ad364e35~amd646.1.7600.16385, Disposition = Detect, VersionComp:
EQ, ServiceComp: EQ, BuildComp: EQ, DistributionComp: GE, RevisionComp: GE, Exist: present
2011-01-31 09:32:54, Info CBS Appl: detectParent: package: Package_for_KB2120976~31bf3856ad364e35~amd646.1.1.0, related parent found: Microsoft-Windows-Media-Format-Package~31bf3856ad364e35~amd646.1.7601.17514, which is not real parent
2011-01-31 09:32:54, Info CBS Appl: detectParent: package: Package_for_KB2120976~31bf3856ad364e35~amd646.1.1.0, parent found: Microsoft-Windows-Media-Format-Package~31bf3856ad364e35~amd646.1.7600.16385, state: Superseded
2011-01-31 09:32:54, Info CBS Appl: detect Parent, Package: Package_for_KB2120976~31bf3856ad364e35~amd646.1.1.0, Parent: WinEmb-PremiumCodecs-WMV~31bf3856ad364e35~amd646.1.7600.16385, Disposition = Detect, VersionComp: EQ, ServiceComp:
2011-01-31 09:32:54, Info CBS Appl: detect Parent, Package: Package_for_KB2120976~31bf3856ad364e35~amd64~~6.1.1.0, disposition state from detectParent: Superseded
2011-01-31 09:32:54, Info CBS Appl: Evaluating package applicability for package Package_for_KB2120976~31bf3856ad364e35~amd64~~6.1.1.0, applicable state: Superseded
2011-01-31 09:32:54, Info CBS EvaluateApplicability, package: Package_for_KB2120976~31bf3856ad364e35~amd64~~6.1.1.0, Package applicability: Superseded.
2011-01-31 09:33:07, Info CBS Archived backup log: C:\Windows\Logs\CBS\CbsPersist_20110131083239.cab.
2011-01-31 09:33:55, Info CBS Session: 30130465_2563278636 initialized by client WindowsUpdateAgent.
2011-01-31 09:33:55, Info CBS Failed to internally open package. [HRESULT = 0x800f0805 - CBS_E_INVALID_PACKAGE]
2011-01-31 09:33:55, Info CBS Session: 30130465_2563308637 initialized by client WindowsUpdateAgent.
2011-01-31 09:34:04, Info CBS Session: 30130465_2654683864 initialized by client WindowsUpdateAgent.
2011-01-31 09:34:04, Info CBS Read out cached package applicability for package: Package_for_KB2120976~31bf3856ad364e35~x86~~6.1.1.0, ApplicableState: 0, CurrentState:0
2011-01-31 09:34:04, Info CBS Session: 30130465_2654723866 initialized by client WindowsUpdateAgent.
2011-01-31 09:34:04, Info CBS Read out cached package applicability for package: Package_for_KB2120976~31bf3856ad364e35~amd64~~6.1.1.0, ApplicableState: 80, CurrentState:80
2011-01-31 09:34:05, Info CBS Session: 30130465_2668024627 initialized by client WindowsUpdateAgent.
2011-01-31 09:34:05, Info CBS Read out cached package applicability for package: Package_for_KB2120976~31bf3856ad364e35~x86~~6.1.1.0, ApplicableState: 0, CurrentState:0
2011-01-31 09:34:05, Info CBS Session: 30130465_2668064629 initialized by client WindowsUpdateAgent.
2011-01-31 09:34:05, Info CBS Read out cached package applicability for package: Package_for_KB2120976~31bf3856ad364e35~amd64~~6.1.1.0, ApplicableState: 80, CurrentState:80
2011-01-31 09:48:43, Info CBS Reboot mark refs incremented to: 1
2011-01-31 09:48:43, Info CBS Scavenge: Starts
2011-01-31 09:48:43, Info CSI 00000009@2011/1/31:08:48:43.184 CSI Transaction @0x2f2660 initialized for deployment engine {d16d444c-56d8-11d5-882d-0080c847b195} with flags 00000002 and client id [10]"TI6.0_0:0/"
2011-01-31 09:48:43, Info CBS Scavenge: Begin CSI Store
2011-01-31 09:48:44, Info CSI 0000000a Performing 1 operations; 1 are not lock/unlock and follow:
Scavenge (8): flags: 00000017
2011-01-31 09:48:44, Info CSI 0000000b Store coherency cookie matches last scavenge cookie, skipping scavenge.
2011-01-31 09:48:44, Info CSI 0000000c ICSITransaction::Commit calling IStorePendingTransaction::Apply - coldpatching=FALSE applyflags=7
2011-01-31 09:48:44, Info CSI 0000000d Creating NT transaction (seq 2), objectname [6]"(null)"
2011-01-31 09:48:44, Info CSI 0000000e Created NT transaction (seq 2) result 0x00000000, handle @0x19c
2011-01-31 09:48:44, Info CSI 0000000f@2011/1/31:08:48:44.960 CSI perf trace:
CSIPERF:TXCOMMIT;36691
2011-01-31 09:48:44, Info CBS Scavenge: Completed, disposition: 0X1
2011-01-31 09:48:44, Info CSI 00000010@2011/1/31:08:48:44.961 CSI Transaction @0x2f2660 destroyed
2011-01-31 09:48:44, Info CBS Reboot mark refs: 0
2011-01-31 09:48:44, Info CBS Idle processing thread terminated normally
2011-01-31 09:48:44, Info CBS Ending the TrustedInstaller main loop.
2011-01-31 09:48:44, Info CBS Starting TrustedInstaller finalization.
2011-01-31 09:48:45, Info CBS Ending TrustedInstaller finalization.
2011-01-31 16:54:42, Info CBS Starting TrustedInstaller initialization.
2011-01-31 16:54:42, Info CBS Loaded Servicing Stack v6.1.7601.17514 with Core: C:\Windows\winsxs\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.1.7601.17514_none_678566b7ddea04a5\cbscore.dll
2011-01-31 16:54:51, Info CSI 00000001@2011/1/31:15:54:51.699 WcpInitialize (wcp.dll version 0.0.0.6) called (stack @0x7fef49be94d @0x7fef4e49839 @0x7fef4e134d3 @0x10000e97c @0x10000d799 @0x10000db2f)
2011-01-31 16:54:52, Info CSI 00000002@2011/1/31:15:54:52.425 WcpInitialize (wcp.dll version 0.0.0.6) called (stack @0x7fef49be94d @0x7fef4e96806 @0x7fef4e62a9c @0x7fef4e135a9 @0x10000e97c @0x10000d799)
2011-01-31 16:54:53, Info CSI 00000003@2011/1/31:15:54:53.221 WcpInitialize (wcp.dll version 0.0.0.6) called (stack @0x7fef49be94d @0x7fef40e8728 @0x7fef40e8856 @0x10000e474 @0x10000d7de @0x10000db2f)
2011-01-31 16:54:53, Info CBS Ending TrustedInstaller initialization.
2011-01-31 16:54:53, Info CBS Starting the TrustedInstaller main loop.
2011-01-31 16:54:53, Info CBS TrustedInstaller service starts successfully.
2011-01-31 16:54:53, Info CBS SQM: Initializing online with Windows opt-in: False
2011-01-31 16:54:53, Info CBS SQM: Cleaning up report files older than 10 days.
2011-01-31 16:54:53, Info CBS SQM: Requesting upload of all unsent reports.
2011-01-31 16:54:53, Info CBS SQM: Failed to start upload with file pattern: C:\Windows\servicing\sqm\*_std.sqm, flags: 0x2 [HRESULT = 0x80004005 - E_FAIL]
2011-01-31 16:54:53, Info CBS SQM: Failed to start standard sample upload. [HRESULT = 0x80004005 - E_FAIL]
2011-01-31 16:54:53, Info CBS SQM: Queued 0 file(s) for upload with pattern: C:\Windows\servicing\sqm\*_all.sqm, flags: 0x6
2011-01-31 16:54:53, Info CBS SQM: Warning: Failed to upload all unsent reports. [HRESULT = 0x80004005 - E_FAIL]
2011-01-31 16:54:53, Info CBS No startup processing required, TrustedInstaller service was not set as autostart, or else a reboot is still pending.
2011-01-31 16:54:53, Info CBS NonStart: Checking to ensure startup processing was not required.
2011-01-31 16:54:54, Info CSI 00000004 IAdvancedInstallerAwareStore_ResolvePendingTransactions (call 1) (flags = 00000004, progress = NULL, phase = 0, pdwDisposition = @0x112f9b0
2011-01-31 16:54:54, Info CSI 00000005 Creating NT transaction (seq 1), objectname [6]"(null)"
2011-01-31 16:54:54, Info CSI 00000006 Created NT transaction (seq 1) result 0x00000000, handle @0x238
2011-01-31 16:54:56, Info CSI 00000007@2011/1/31:15:54:56.368 CSI perf trace:
CSIPERF:TXCOMMIT;2472
2011-01-31 16:54:56, Info CBS NonStart: Success, startup processing not required as expected.
2011-01-31 16:54:56, Info CBS Startup processing thread terminated normally
2011-01-31 16:54:57, Info CSI 00000008 CSI Store 3610864 (0x00000000003718f0) initialized
2011-01-31 16:54:57, Info CBS Session: 30130527_898285604 initialized by client lpksetup.
2011-01-31 16:55:08, Info CBS Session: 30130527_898285604 finalized. Reboot required: no [HRESULT = 0x00000000 - S_OK]
2011-01-31 17:02:18, Info CBS Session: 30130528_1017002201 initialized by client WindowsUpdateAgent.
2011-01-31 17:02:18, Info CBS Read out cached package applicability for package: Package_for_KB2120976~31bf3856ad364e35~x86~~6.1.1.0, ApplicableState: 0, CurrentState:0
2011-01-31 17:02:18, Info CBS Session: 30130528_1017042203 initialized by client WindowsUpdateAgent.
2011-01-31 17:02:18, Info CBS Read out cached package applicability for package: Package_for_KB2120976~31bf3856ad364e35~amd64~~6.1.1.0, ApplicableState: 80, CurrentState:80
2011-01-31 17:12:20, Info CBS Reboot mark refs incremented to: 1
2011-01-31 17:12:21, Info CBS Scavenge: Starts
2011-01-31 17:12:21, Info CSI 00000009@2011/1/31:16:12:21.746 CSI Transaction @0x1110850 initialized for deployment engine {d16d444c-56d8-11d5-882d-0080c847b195} with flags 00000002 and client id [10]"TI6.0_0:0/"
2011-01-31 17:12:21, Info CBS Scavenge: Begin CSI Store
2011-01-31 17:13:07, Info CSI 0000000a Performing 1 operations; 1 are not lock/unlock and follow:
2011-01-31 17:13:08, Info CSI 0000000b Store coherency cookie matches last scavenge cookie, skipping scavenge.
2011-01-31 17:13:19, Info CSI 0000000c ICSITransaction::Commit calling IStorePendingTransaction::Apply - coldpatching=FALSE applyflags=7
2011-01-31 17:13:21, Info CSI 0000000d Creating NT transaction (seq 2), objectname [6]"(null)"
2011-01-31 17:13:21, Info CSI 0000000e Created NT transaction (seq 2) result 0x00000000, handle @0x268
2011-01-31 17:13:21, Info CSI 0000000f@2011/1/31:16:13:21.509 CSI perf trace:
CSIPERF:TXCOMMIT;114980
2011-01-31 17:13:21, Info CBS Scavenge: Completed, disposition: 0X1
2011-01-31 17:13:21, Info CSI 00000010@2011/1/31:16:13:21.509 CSI Transaction @0x1110850 destroyed
2011-01-31 17:13:22, Info CBS Reboot mark refs: 0
2011-01-31 17:13:22, Info CBS Idle processing thread terminated normally
2011-01-31 17:13:22, Info CBS Ending the TrustedInstaller main loop.
2011-01-31 17:13:22, Info CBS Starting TrustedInstaller finalization.
2011-01-31 17:13:35, Info CBS Ending TrustedInstaller finalization.
2011-01-31 17:36:21, Info CBS Starting TrustedInstaller initialization.
2011-01-31 17:36:21, Info CBS Loaded Servicing Stack v6.1.7601.17514 with Core: C:\Windows\winsxs\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.1.7601.17514_none_678566b7ddea04a5\cbscore.dll
2011-01-31 17:36:24, Info CSI 00000001@2011/1/31:16:36:24.750 WcpInitialize (wcp.dll version 0.0.0.6) called (stack @0x7feeefae94d @0x7fef4a79839 @0x7fef4a434d3 @0xff23e97c @0xff23d799 @0xff23db2f)
2011-01-31 17:36:25, Info CSI 00000002@2011/1/31:16:36:25.104 WcpInitialize (wcp.dll version 0.0.0.6) called (stack @0x7feeefae94d @0x7fef4ac6806 @0x7fef4a92a9c @0x7fef4a435a9 @0xff23e97c @0xff23d799)
2011-01-31 17:36:25, Info CSI 00000003@2011/1/31:16:36:25.105 WcpInitialize (wcp.dll version 0.0.0.6) called (stack @0x7feeefae94d @0x7fef9448728 @0x7fef9448856 @0xff23e474 @0xff23d7de @0xff23db2f)
2011-01-31 17:36:25, Info CBS Ending TrustedInstaller initialization.
2011-01-31 17:36:25, Info CBS Starting the TrustedInstaller main loop.
2011-01-31 17:36:25, Info CBS TrustedInstaller service starts successfully.
2011-01-31 17:36:25, Info CBS SQM: Initializing online with Windows opt-in: False
2011-01-31 17:36:25, Info CBS SQM: Cleaning up report files older than 10 days.
2011-01-31 17:36:25, Info CBS SQM: Requesting upload of all unsent reports.
2011-01-31 17:36:25, Info CBS SQM: Failed to start upload with file pattern: C:\Windows\servicing\sqm\*_std.sqm, flags: 0x2 [HRESULT = 0x80004005 - E_FAIL]
2011-01-31 17:36:25, Info CBS SQM: Failed to start standard sample upload. [HRESULT = 0x80004005 - E_FAIL]
2011-01-31 17:36:25, Info CBS SQM: Queued 0 file(s) for upload with pattern: C:\Windows\servicing\sqm\*_all.sqm, flags: 0x6
2011-01-31 17:36:25, Info CBS SQM: Warning: Failed to upload all unsent reports. [HRESULT = 0x80004005 - E_FAIL]
2011-01-31 17:36:25, Info CBS No startup processing required, TrustedInstaller service was not set as autostart, or else a reboot is still pending.
2011-01-31 17:36:25, Info CBS NonStart: Checking to ensure startup processing was not required.
2011-01-31 17:36:25, Info CSI 00000004 IAdvancedInstallerAwareStore_ResolvePendingTransactions (call 1) (flags = 00000004, progress = NULL, phase = 0, pdwDisposition = @0x107fa30
2011-01-31 17:36:25, Info CSI 00000005 Creating NT transaction (seq 1), objectname [6]"(null)"
2011-01-31 17:36:25, Info CSI 00000006 Created NT transaction (seq 1) result 0x00000000, handle @0x238
2011-01-31 17:36:25, Info CSI 00000007@2011/1/31:16:36:25.651 CSI perf trace:
CSIPERF:TXCOMMIT;34358
2011-01-31 17:36:25, Info CBS NonStart: Success, startup processing not required as expected.
2011-01-31 17:36:25, Info CBS Startup processing thread terminated normally
2011-01-31 17:36:25, Info CSI 00000008 CSI Store 2955504 (0x00000000002d18f0) initialized
2011-01-31 17:36:25, Info CBS Session: 30130533_12956583 initialized by client WindowsUpdateAgent.
2011-01-31 17:36:25, Info CBS Failed to internally open package. [HRESULT = 0x800f0805 - CBS_E_INVALID_PACKAGE]
2011-01-31 17:36:25, Info CBS Session: 30130533_13506615 initialized by client WindowsUpdateAgent.
2011-01-31 17:46:27, Info CBS Reboot mark refs incremented to: 1
2011-01-31 17:46:27, Info CBS Scavenge: Starts
2011-01-31 17:46:27, Info CSI 00000009@2011/1/31:16:46:27.533 CSI Transaction @0x2900b0 initialized for deployment engine {d16d444c-56d8-11d5-882d-0080c847b195} with flags 00000002 and client id [10]"TI6.0_0:0/"
2011-01-31 17:46:27, Info CBS Scavenge: Begin CSI Store
2011-01-31 17:46:29, Info CSI 0000000a Performing 1 operations; 1 are not lock/unlock and follow:
2011-01-31 17:46:29, Info CSI 0000000b Store coherency cookie matches last scavenge cookie, skipping scavenge.
2011-01-31 17:46:29, Info CSI 0000000c ICSITransaction::Commit calling IStorePendingTransaction::Apply - coldpatching=FALSE applyflags=7
2011-01-31 17:46:29, Info CSI 0000000d Creating NT transaction (seq 2), objectname [6]"(null)"
2011-01-31 17:46:29, Info CSI 0000000e Created NT transaction (seq 2) result 0x00000000, handle @0x274
2011-01-31 17:46:29, Info CSI 0000000f@2011/1/31:16:46:29.561 CSI perf trace:
CSIPERF:TXCOMMIT;51920
2011-01-31 17:46:29, Info CBS Scavenge: Completed, disposition: 0X1
2011-01-31 17:46:29, Info CSI 00000010@2011/1/31:16:46:29.561 CSI Transaction @0x2900b0 destroyed
2011-01-31 17:46:29, Info CBS Reboot mark refs: 0
2011-01-31 17:46:29, Info CBS Idle processing thread terminated normally
2011-01-31 17:46:29, Info CBS Ending the TrustedInstaller main loop.
2011-01-31 17:46:29, Info CBS Starting TrustedInstaller finalization.
2011-01-31 17:46:32, Info CBS Ending TrustedInstaller finalization.
Any help please?
Thank you :)
Deleted
2011-02-11T20:07:56+00:00 -
2011-02-11T20:20:45+00:00 Yes I installed the SP1 few days ago on the suggestion of a friend in the hope it might fix the issue but no luck.
Do I really have to uninstall it?
It took like 2 hours to install.
Many thanks
Yes. You are already having problems. You cannot get support should it come to that with prerelease software on the system. whether MS requires removal as a precondition to installation of the rtm due on the 22nd is not clear yet but they usually do.
Also, you cannot do a repair installation with a service pack installed because none of the dvds out there have the sp. Repair installation fails if the installed Windows is at a higher service pack level than the dvd.
I am already thinking that a repair installation is a likely outcome.
Colin Barnhorst Windows 7 Ultimate x64 on DIY with 6GB ram.
2011-02-11T23:00:18+00:00 Just to be clear I installed the SP1 when I already had problems and had tried several things suggested.
Anyway I will try and remove it but to attempt what after that?
Also the repair installation is what you do with the Seven installation disk?
In that case I have tried it (before installing SP1) and had no result either.
If it's something different what is it and how do I do it please?
Thank you
2011-02-11T23:20:20+00:00 Hi Threshold,
The Idea behind the New User profile is, the current profile might have been corrupted, a new User account might fix the problem, and if it works, then you just need to copy the user account folder and replace it with the new one. You dont have to reinstall anything. (Specifically OS or any Applications).
Click on start and type in "Problem Report " Select "View All Problem Reports" and you would find the list of crash reports. Scroll the list and Select the "Windows Explorer" "Stopped working" and open it. You would find the full details of the crash. Just copy and paste it here and lets see how we can proceed from there.
Note: Apologies for the Delayed reply
Thanks and Regards, || The Saint || Destruction of Morning is the Creation of Noon.
