Explorer.exe Crashes Constantly When Accessing Control Panel or Any Start Menu Item on WIN 7 x64
2011-01-31T18:24:43+00:00
I have explorer.exe crashing when I try to open the Control Panel on Seven x64 and on some right clicking on files and on anything I search or try to open in the Start Menu.
I think the problem started after I created the Godmode folder through Windows 7 Manager from Yamisoft (I managed to get rid of Godmode anyway).
I can access all components of the Control Panel through the cpl files in Windows directory and none crashes but if I try to open the main Control Panel window explorer crashes.
I run ShellExView and disabled all Shell extension which are NOT from Microsoft and the problem persist.
The problem doesn't occur in Safe Boot mode.
I checked the Event Viewer and the explorer crashes have this info:
The description for Event ID 1000 from source Application Error cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
explorer.exe6.1.7600.164504aebab8dntdll.dll6.1.7600.165594ba9b802c000041d000000000004d301b3c01cbbf3adb80f4d8C:\Windows\explorer.exeC:\Windows\SYSTEM32\ntdll.dlla36102d9-2b31-11e0-94f8-001b24531bd0
********************************System
– Provider
[ Name] Application Error
– EventID 1000
[ Qualifiers] 0
Level 2
Task 100
Keywords 0×80000000000000
– TimeCreated
[ SystemTime] 2011-01-28T22:55:02.000000000Z
EventRecordID 326966
Channel Application
Computer MYPC
Security
- EventData
I run sfc while in safe mode since it wouldn't start in normal mode and it says that it couldn't repair some files.
2011-01-31 09:32:39, Info                  CBS    Starting TrustedInstaller initialization.
2011-01-31 09:32:39, Info                  CBS    Loaded Servicing Stack v6.1.7601.17514 with Core: C:\Windows\winsxs\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.1.7601.17514_none_678566b7ddea04a5\cbscore.dll
2011-01-31 09:32:41, Info                  CSI    00000001@2011/1/31:08:32:41.135 WcpInitialize (wcp.dll version 0.0.0.6) called (stack @0x7fef1f5e94d @0x7fef31a9839 @0x7fef31734d3 @0xff5ce97c @0xff5cd799 @0xff5cdb2f)
2011-01-31 09:32:41, Info                  CSI    00000002@2011/1/31:08:32:41.245 WcpInitialize (wcp.dll version 0.0.0.6) called (stack @0x7fef1f5e94d @0x7fef31f6806 @0x7fef31c2a9c @0x7fef31735a9 @0xff5ce97c @0xff5cd799)
2011-01-31 09:32:41, Info                  CSI    00000003@2011/1/31:08:32:41.247 WcpInitialize (wcp.dll version 0.0.0.6) called (stack @0x7fef1f5e94d @0x7fef9d68728 @0x7fef9d68856 @0xff5ce474 @0xff5cd7de @0xff5cdb2f)
2011-01-31 09:32:41, Info                  CBS    Ending TrustedInstaller initialization.
2011-01-31 09:32:41, Info                  CBS    Starting the TrustedInstaller main loop.
2011-01-31 09:32:41, Info                  CBS    TrustedInstaller service starts successfully.
2011-01-31 09:32:41, Info                  CBS    SQM: Initializing online with Windows opt-in: False
2011-01-31 09:32:41, Info                  CBS    SQM: Cleaning up report files older than 10 days.
2011-01-31 09:32:41, Info                  CBS    SQM: Requesting upload of all unsent reports.
2011-01-31 09:32:41, Info                  CBS    SQM: Failed to start upload with file pattern: C:\Windows\servicing\sqm\*_std.sqm, flags: 0x2 [HRESULT = 0x80004005 - E_FAIL]
2011-01-31 09:32:41, Info                  CBS    SQM: Failed to start standard sample upload. [HRESULT = 0x80004005 - E_FAIL]
2011-01-31 09:32:41, Info                  CBS    SQM: Queued 0 file(s) for upload with pattern: C:\Windows\servicing\sqm\*_all.sqm, flags: 0x6
2011-01-31 09:32:41, Info                  CBS    SQM: Warning: Failed to upload all unsent reports. [HRESULT = 0x80004005 - E_FAIL]
2011-01-31 09:32:41, Info                  CBS    No startup processing required, TrustedInstaller service was not set as autostart, or else a reboot is still pending.
2011-01-31 09:32:41, Info                  CBS    NonStart: Checking to ensure startup processing was not required.
2011-01-31 09:32:41, Info                  CSI    00000004 IAdvancedInstallerAwareStore_ResolvePendingTransactions (call 1) (flags = 00000004, progress = NULL, phase = 0, pdwDisposition = @0xbcf9f0
2011-01-31 09:32:41, Info                  CSI    00000005 Creating NT transaction (seq 1), objectname [6]"(null)"
2011-01-31 09:32:41, Info                  CSI    00000006 Created NT transaction (seq 1) result 0x00000000, handle @0x248
2011-01-31 09:32:41, Info                  CSI    00000007@2011/1/31:08:32:41.327 CSI perf trace:
CSIPERF:TXCOMMIT;815
2011-01-31 09:32:41, Info                  CBS    NonStart: Success, startup processing not required as expected.
2011-01-31 09:32:41, Info                  CBS    Startup processing thread terminated normally
2011-01-31 09:32:41, Info                  CSI    00000008 CSI Store 3337712 (0x000000000032edf0) initialized
2011-01-31 09:32:41, Info                  CBS    Session: 30130465_1825506437 initialized by client WindowsUpdateAgent.
2011-01-31 09:32:41, Info                  CBS    Failed to internally open package. [HRESULT = 0x800f0805 - CBS_E_INVALID_PACKAGE]
2011-01-31 09:32:41, Info                  CBS    Session: 30130465_1825536439 initialized by client WindowsUpdateAgent.
2011-01-31 09:32:54, Info                  CBS    Session: 30130465_1952173682 initialized by client WindowsUpdateAgent.
2011-01-31 09:32:54, Info                  CBS    Appl: detect Parent, Package: Package_for_KB2120976~31bf3856ad364e35~x866.1.1.0, Parent: Microsoft-Media-Foundation-Package~31bf3856ad364e35~x866.1.7600.16385, Disposition = Detect, VersionComp: EQ, ServiceComp: EQ, BuildComp: EQ, DistributionComp: GE, RevisionComp: GE, Exist: present
2011-01-31 09:32:54, Info                  CBS    Appl: detectParent: package: Package_for_KB2120976~31bf3856ad364e35~x86~~6.1.1.0, no parent found, go absent
2011-01-31 09:32:54, Info                  CBS    Appl: detect Parent, Package: Package_for_KB2120976~31bf3856ad364e35~x866.1.1.0, Parent: WinEmb-Media-Support~31bf3856ad364e35~x866.1.7600.16385, Disposition = Detect, VersionComp: EQ, ServiceComp: EQ, BuildComp: EQ, DistributionComp: GE, RevisionComp: GE, Exist: present
2011-01-31 09:32:54, Info                  CBS    Appl: detect Parent, Package: Package_for_KB2120976~31bf3856ad364e35~x866.1.1.0, Parent: Microsoft-Windows-Media-Format-Package~31bf3856ad364e35~x866.1.7600.16385, Disposition = Detect, VersionComp: EQ, ServiceComp: EQ, BuildComp: EQ, DistributionComp: GE, RevisionComp: GE, Exist: present
2011-01-31 09:32:54, Info                  CBS    Appl: detect Parent, Package: Package_for_KB2120976~31bf3856ad364e35~x866.1.1.0, Parent: WinEmb-PremiumCodecs-WMV~31bf3856ad364e35~x866.1.7600.16385, Disposition = Detect, VersionComp: EQ, ServiceComp: EQ, BuildComp: EQ, DistributionComp: GE, RevisionComp: GE, Exist: present
2011-01-31 09:32:54, Info                  CBS    Appl: detect Parent, Package: Package_for_KB2120976~31bf3856ad364e35~x86~~6.1.1.0, disposition state from detectParent: Absent
2011-01-31 09:32:54, Info                  CBS    Appl: Evaluating package applicability for package Package_for_KB2120976~31bf3856ad364e35~x86~~6.1.1.0, applicable state: Absent
2011-01-31 09:32:54, Info                  CBS    EvaluateApplicability, package: Package_for_KB2120976~31bf3856ad364e35~x86~~6.1.1.0, Package applicability: Absent.
2011-01-31 09:32:54, Info                  CBS    Session: 30130465_1952653710 initialized by client WindowsUpdateAgent.
2011-01-31 09:32:54, Info                  CBS    Appl: detect Parent, Package: Package_for_KB2120976~31bf3856ad364e35~amd646.1.1.0, Parent: Microsoft-Media-Foundation-Package~31bf3856ad364e35~amd646.1.7600.16385, Disposition = Detect, VersionComp: EQ, ServiceComp: EQ, BuildComp: EQ, DistributionComp: GE, RevisionComp: GE, Exist: present
2011-01-31 09:32:54, Info                  CBS    Appl: detectParent: package: Package_for_KB2120976~31bf3856ad364e35~amd646.1.1.0, related parent found: Microsoft-Media-Foundation-Package~31bf3856ad364e35~amd646.1.7601.17514, which is not real parent
2011-01-31 09:32:54, Info                  CBS    Appl: detectParent: package: Package_for_KB2120976~31bf3856ad364e35~amd646.1.1.0, parent found: Microsoft-Media-Foundation-Package~31bf3856ad364e35~amd646.1.7600.16385, state: Superseded
2011-01-31 09:32:54, Info                  CBS    Appl: detect Parent, Package: Package_for_KB2120976~31bf3856ad364e35~amd646.1.1.0, Parent: WinEmb-Media-Support~31bf3856ad364e35~amd646.1.7600.16385, Disposition = Detect, VersionComp: EQ, ServiceComp: EQ, BuildComp: EQ, DistributionComp: GE, RevisionComp: GE, Exist: present
2011-01-31 09:32:54, Info                  CBS    Appl: detectParent: package: Package_for_KB2120976~31bf3856ad364e35~amd64~~6.1.1.0, no parent found, go absent
2011-01-31 09:32:54, Info                  CBS    Appl: detect Parent, Package: Package_for_KB2120976~31bf3856ad364e35~amd646.1.1.0, Parent: Microsoft-Windows-Media-Format-Package~31bf3856ad364e35~amd646.1.7600.16385, Disposition = Detect, VersionComp: EQ, ServiceComp: EQ, BuildComp: EQ, DistributionComp: GE, RevisionComp: GE, Exist: present
2011-01-31 09:32:54, Info                  CBS    Appl: detectParent: package: Package_for_KB2120976~31bf3856ad364e35~amd646.1.1.0, related parent found: Microsoft-Windows-Media-Format-Package~31bf3856ad364e35~amd646.1.7601.17514, which is not real parent
2011-01-31 09:32:54, Info                  CBS    Appl: detectParent: package: Package_for_KB2120976~31bf3856ad364e35~amd646.1.1.0, parent found: Microsoft-Windows-Media-Format-Package~31bf3856ad364e35~amd646.1.7600.16385, state: Superseded
2011-01-31 09:32:54, Info                  CBS    Appl: detect Parent, Package: Package_for_KB2120976~31bf3856ad364e35~amd646.1.1.0, Parent: WinEmb-PremiumCodecs-WMV~31bf3856ad364e35~amd646.1.7600.16385, Disposition = Detect, VersionComp: EQ, ServiceComp: EQ, BuildComp: EQ, DistributionComp: GE, RevisionComp: GE, Exist: present
2011-01-31 09:32:54, Info                  CBS    Appl: detect Parent, Package: Package_for_KB2120976~31bf3856ad364e35~amd64~~6.1.1.0, disposition state from detectParent: Superseded
2011-01-31 09:32:54, Info                  CBS    Appl: Evaluating package applicability for package Package_for_KB2120976~31bf3856ad364e35~amd64~~6.1.1.0, applicable state: Superseded
2011-01-31 09:32:54, Info                  CBS    EvaluateApplicability, package: Package_for_KB2120976~31bf3856ad364e35~amd64~~6.1.1.0, Package applicability: Superseded.
2011-01-31 09:33:07, Info                  CBS    Archived backup log: C:\Windows\Logs\CBS\CbsPersist_20110131083239.cab.
2011-01-31 09:33:55, Info                  CBS    Session: 30130465_2563278636 initialized by client WindowsUpdateAgent.
2011-01-31 09:33:55, Info                  CBS    Failed to internally open package. [HRESULT = 0x800f0805 - CBS_E_INVALID_PACKAGE]
2011-01-31 09:33:55, Info                  CBS    Session: 30130465_2563308637 initialized by client WindowsUpdateAgent.
2011-01-31 09:34:04, Info                  CBS    Session: 30130465_2654683864 initialized by client WindowsUpdateAgent.
2011-01-31 09:34:04, Info                  CBS    Read out cached package applicability for package: Package_for_KB2120976~31bf3856ad364e35~x86~~6.1.1.0, ApplicableState: 0, CurrentState:0
2011-01-31 09:34:04, Info                  CBS    Session: 30130465_2654723866 initialized by client WindowsUpdateAgent.
2011-01-31 09:34:04, Info                  CBS    Read out cached package applicability for package: Package_for_KB2120976~31bf3856ad364e35~amd64~~6.1.1.0, ApplicableState: 80, CurrentState:80
2011-01-31 09:34:05, Info                  CBS    Session: 30130465_2668024627 initialized by client WindowsUpdateAgent.
2011-01-31 09:34:05, Info                  CBS    Read out cached package applicability for package: Package_for_KB2120976~31bf3856ad364e35~x86~~6.1.1.0, ApplicableState: 0, CurrentState:0
2011-01-31 09:34:05, Info                  CBS    Session: 30130465_2668064629 initialized by client WindowsUpdateAgent.
2011-01-31 09:34:05, Info                  CBS    Read out cached package applicability for package: Package_for_KB2120976~31bf3856ad364e35~amd64~~6.1.1.0, ApplicableState: 80, CurrentState:80
2011-01-31 09:48:43, Info                  CBS    Reboot mark refs incremented to: 1
2011-01-31 09:48:43, Info                  CBS    Scavenge: Starts
2011-01-31 09:48:43, Info                  CSI    00000009@2011/1/31:08:48:43.184 CSI Transaction @0x2f2660 initialized for deployment engine {d16d444c-56d8-11d5-882d-0080c847b195} with flags 00000002 and client id [10]"TI6.0_0:0/"
2011-01-31 09:48:43, Info                  CBS    Scavenge: Begin CSI Store
2011-01-31 09:48:44, Info                  CSI    0000000a Performing 1 operations; 1 are not lock/unlock and follow:
  Scavenge (8): flags: 00000017
2011-01-31 09:48:44, Info                  CSI    0000000b Store coherency cookie matches last scavenge cookie, skipping scavenge.
2011-01-31 09:48:44, Info                  CSI    0000000c ICSITransaction::Commit calling IStorePendingTransaction::Apply - coldpatching=FALSE applyflags=7
2011-01-31 09:48:44, Info                  CSI    0000000d Creating NT transaction (seq 2), objectname [6]"(null)"
2011-01-31 09:48:44, Info                  CSI    0000000e Created NT transaction (seq 2) result 0x00000000, handle @0x19c
2011-01-31 09:48:44, Info                  CSI    0000000f@2011/1/31:08:48:44.960 CSI perf trace:
CSIPERF:TXCOMMIT;36691
2011-01-31 09:48:44, Info                  CBS    Scavenge: Completed, disposition: 0X1
2011-01-31 09:48:44, Info                  CSI    00000010@2011/1/31:08:48:44.961 CSI Transaction @0x2f2660 destroyed
2011-01-31 09:48:44, Info                  CBS    Reboot mark refs: 0
2011-01-31 09:48:44, Info                  CBS    Idle processing thread terminated normally
2011-01-31 09:48:44, Info                  CBS    Ending the TrustedInstaller main loop.
2011-01-31 09:48:44, Info                  CBS    Starting TrustedInstaller finalization.
2011-01-31 09:48:45, Info                  CBS    Ending TrustedInstaller finalization.
2011-01-31 16:54:42, Info                  CBS    Starting TrustedInstaller initialization.
2011-01-31 16:54:42, Info                  CBS    Loaded Servicing Stack v6.1.7601.17514 with Core: C:\Windows\winsxs\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.1.7601.17514_none_678566b7ddea04a5\cbscore.dll
2011-01-31 16:54:51, Info                  CSI    00000001@2011/1/31:15:54:51.699 WcpInitialize (wcp.dll version 0.0.0.6) called (stack @0x7fef49be94d @0x7fef4e49839 @0x7fef4e134d3 @0x10000e97c @0x10000d799 @0x10000db2f)
2011-01-31 16:54:52, Info                  CSI    00000002@2011/1/31:15:54:52.425 WcpInitialize (wcp.dll version 0.0.0.6) called (stack @0x7fef49be94d @0x7fef4e96806 @0x7fef4e62a9c @0x7fef4e135a9 @0x10000e97c @0x10000d799)
2011-01-31 16:54:53, Info                  CSI    00000003@2011/1/31:15:54:53.221 WcpInitialize (wcp.dll version 0.0.0.6) called (stack @0x7fef49be94d @0x7fef40e8728 @0x7fef40e8856 @0x10000e474 @0x10000d7de @0x10000db2f)
2011-01-31 16:54:53, Info                  CBS    Ending TrustedInstaller initialization.
2011-01-31 16:54:53, Info                  CBS    Starting the TrustedInstaller main loop.
2011-01-31 16:54:53, Info                  CBS    TrustedInstaller service starts successfully.
2011-01-31 16:54:53, Info                  CBS    SQM: Initializing online with Windows opt-in: False
2011-01-31 16:54:53, Info                  CBS    SQM: Cleaning up report files older than 10 days.
2011-01-31 16:54:53, Info                  CBS    SQM: Requesting upload of all unsent reports.
2011-01-31 16:54:53, Info                  CBS    SQM: Failed to start upload with file pattern: C:\Windows\servicing\sqm\*_std.sqm, flags: 0x2 [HRESULT = 0x80004005 - E_FAIL]
2011-01-31 16:54:53, Info                  CBS    SQM: Failed to start standard sample upload. [HRESULT = 0x80004005 - E_FAIL]
2011-01-31 16:54:53, Info                  CBS    SQM: Queued 0 file(s) for upload with pattern: C:\Windows\servicing\sqm\*_all.sqm, flags: 0x6
2011-01-31 16:54:53, Info                  CBS    SQM: Warning: Failed to upload all unsent reports. [HRESULT = 0x80004005 - E_FAIL]
2011-01-31 16:54:53, Info                  CBS    No startup processing required, TrustedInstaller service was not set as autostart, or else a reboot is still pending.
2011-01-31 16:54:53, Info                  CBS    NonStart: Checking to ensure startup processing was not required.
2011-01-31 16:54:54, Info                  CSI    00000004 IAdvancedInstallerAwareStore_ResolvePendingTransactions (call 1) (flags = 00000004, progress = NULL, phase = 0, pdwDisposition = @0x112f9b0
2011-01-31 16:54:54, Info                  CSI    00000005 Creating NT transaction (seq 1), objectname [6]"(null)"
2011-01-31 16:54:54, Info                  CSI    00000006 Created NT transaction (seq 1) result 0x00000000, handle @0x238
2011-01-31 16:54:56, Info                  CSI    00000007@2011/1/31:15:54:56.368 CSI perf trace:
CSIPERF:TXCOMMIT;2472
2011-01-31 16:54:56, Info                  CBS    NonStart: Success, startup processing not required as expected.
2011-01-31 16:54:56, Info                  CBS    Startup processing thread terminated normally
2011-01-31 16:54:57, Info                  CSI    00000008 CSI Store 3610864 (0x00000000003718f0) initialized
2011-01-31 16:54:57, Info                  CBS    Session: 30130527_898285604 initialized by client lpksetup.
2011-01-31 16:55:08, Info                  CBS    Session: 30130527_898285604 finalized. Reboot required: no [HRESULT = 0x00000000 - S_OK]
2011-01-31 17:02:18, Info                  CBS    Session: 30130528_1017002201 initialized by client WindowsUpdateAgent.
2011-01-31 17:02:18, Info                  CBS    Read out cached package applicability for package: Package_for_KB2120976~31bf3856ad364e35~x86~~6.1.1.0, ApplicableState: 0, CurrentState:0
2011-01-31 17:02:18, Info                  CBS    Session: 30130528_1017042203 initialized by client WindowsUpdateAgent.
2011-01-31 17:02:18, Info                  CBS    Read out cached package applicability for package: Package_for_KB2120976~31bf3856ad364e35~amd64~~6.1.1.0, ApplicableState: 80, CurrentState:80
2011-01-31 17:12:20, Info                  CBS    Reboot mark refs incremented to: 1
2011-01-31 17:12:21, Info                  CBS    Scavenge: Starts
2011-01-31 17:12:21, Info                  CSI    00000009@2011/1/31:16:12:21.746 CSI Transaction @0x1110850 initialized for deployment engine {d16d444c-56d8-11d5-882d-0080c847b195} with flags 00000002 and client id [10]"TI6.0_0:0/"
2011-01-31 17:12:21, Info                  CBS    Scavenge: Begin CSI Store
2011-01-31 17:13:07, Info                  CSI    0000000a Performing 1 operations; 1 are not lock/unlock and follow:
2011-01-31 17:13:08, Info                  CSI    0000000b Store coherency cookie matches last scavenge cookie, skipping scavenge.
2011-01-31 17:13:19, Info                  CSI    0000000c ICSITransaction::Commit calling IStorePendingTransaction::Apply - coldpatching=FALSE applyflags=7
2011-01-31 17:13:21, Info                  CSI    0000000d Creating NT transaction (seq 2), objectname [6]"(null)"
2011-01-31 17:13:21, Info                  CSI    0000000e Created NT transaction (seq 2) result 0x00000000, handle @0x268
2011-01-31 17:13:21, Info                  CSI    0000000f@2011/1/31:16:13:21.509 CSI perf trace:
CSIPERF:TXCOMMIT;114980
2011-01-31 17:13:21, Info                  CBS    Scavenge: Completed, disposition: 0X1
2011-01-31 17:13:21, Info                  CSI    00000010@2011/1/31:16:13:21.509 CSI Transaction @0x1110850 destroyed
2011-01-31 17:13:22, Info                  CBS    Reboot mark refs: 0
2011-01-31 17:13:22, Info                  CBS    Idle processing thread terminated normally
2011-01-31 17:13:22, Info                  CBS    Ending the TrustedInstaller main loop.
2011-01-31 17:13:22, Info                  CBS    Starting TrustedInstaller finalization.
2011-01-31 17:13:35, Info                  CBS    Ending TrustedInstaller finalization.
2011-01-31 17:36:21, Info                  CBS    Starting TrustedInstaller initialization.
2011-01-31 17:36:21, Info                  CBS    Loaded Servicing Stack v6.1.7601.17514 with Core: C:\Windows\winsxs\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.1.7601.17514_none_678566b7ddea04a5\cbscore.dll
2011-01-31 17:36:24, Info                  CSI    00000001@2011/1/31:16:36:24.750 WcpInitialize (wcp.dll version 0.0.0.6) called (stack @0x7feeefae94d @0x7fef4a79839 @0x7fef4a434d3 @0xff23e97c @0xff23d799 @0xff23db2f)
2011-01-31 17:36:25, Info                  CSI    00000002@2011/1/31:16:36:25.104 WcpInitialize (wcp.dll version 0.0.0.6) called (stack @0x7feeefae94d @0x7fef4ac6806 @0x7fef4a92a9c @0x7fef4a435a9 @0xff23e97c @0xff23d799)
2011-01-31 17:36:25, Info                  CSI    00000003@2011/1/31:16:36:25.105 WcpInitialize (wcp.dll version 0.0.0.6) called (stack @0x7feeefae94d @0x7fef9448728 @0x7fef9448856 @0xff23e474 @0xff23d7de @0xff23db2f)
2011-01-31 17:36:25, Info                  CBS    Ending TrustedInstaller initialization.
2011-01-31 17:36:25, Info                  CBS    Starting the TrustedInstaller main loop.
2011-01-31 17:36:25, Info                  CBS    TrustedInstaller service starts successfully.
2011-01-31 17:36:25, Info                  CBS    SQM: Initializing online with Windows opt-in: False
2011-01-31 17:36:25, Info                  CBS    SQM: Cleaning up report files older than 10 days.
2011-01-31 17:36:25, Info                  CBS    SQM: Requesting upload of all unsent reports.
2011-01-31 17:36:25, Info                  CBS    SQM: Failed to start upload with file pattern: C:\Windows\servicing\sqm\*_std.sqm, flags: 0x2 [HRESULT = 0x80004005 - E_FAIL]
2011-01-31 17:36:25, Info                  CBS    SQM: Failed to start standard sample upload. [HRESULT = 0x80004005 - E_FAIL]
2011-01-31 17:36:25, Info                  CBS    SQM: Queued 0 file(s) for upload with pattern: C:\Windows\servicing\sqm\*_all.sqm, flags: 0x6
2011-01-31 17:36:25, Info                  CBS    SQM: Warning: Failed to upload all unsent reports. [HRESULT = 0x80004005 - E_FAIL]
2011-01-31 17:36:25, Info                  CBS    No startup processing required, TrustedInstaller service was not set as autostart, or else a reboot is still pending.
2011-01-31 17:36:25, Info                  CBS    NonStart: Checking to ensure startup processing was not required.
2011-01-31 17:36:25, Info                  CSI    00000004 IAdvancedInstallerAwareStore_ResolvePendingTransactions (call 1) (flags = 00000004, progress = NULL, phase = 0, pdwDisposition = @0x107fa30
2011-01-31 17:36:25, Info                  CSI    00000005 Creating NT transaction (seq 1), objectname [6]"(null)"
2011-01-31 17:36:25, Info                  CSI    00000006 Created NT transaction (seq 1) result 0x00000000, handle @0x238
2011-01-31 17:36:25, Info                  CSI    00000007@2011/1/31:16:36:25.651 CSI perf trace:
CSIPERF:TXCOMMIT;34358
2011-01-31 17:36:25, Info                  CBS    NonStart: Success, startup processing not required as expected.
2011-01-31 17:36:25, Info                  CBS    Startup processing thread terminated normally
2011-01-31 17:36:25, Info                  CSI    00000008 CSI Store 2955504 (0x00000000002d18f0) initialized
2011-01-31 17:36:25, Info                  CBS    Session: 30130533_12956583 initialized by client WindowsUpdateAgent.
2011-01-31 17:36:25, Info                  CBS    Failed to internally open package. [HRESULT = 0x800f0805 - CBS_E_INVALID_PACKAGE]
2011-01-31 17:36:25, Info                  CBS    Session: 30130533_13506615 initialized by client WindowsUpdateAgent.
2011-01-31 17:46:27, Info                  CBS    Reboot mark refs incremented to: 1
2011-01-31 17:46:27, Info                  CBS    Scavenge: Starts
2011-01-31 17:46:27, Info                  CSI    00000009@2011/1/31:16:46:27.533 CSI Transaction @0x2900b0 initialized for deployment engine {d16d444c-56d8-11d5-882d-0080c847b195} with flags 00000002 and client id [10]"TI6.0_0:0/"
2011-01-31 17:46:27, Info                  CBS    Scavenge: Begin CSI Store
2011-01-31 17:46:29, Info                  CSI    0000000a Performing 1 operations; 1 are not lock/unlock and follow:
2011-01-31 17:46:29, Info                  CSI    0000000b Store coherency cookie matches last scavenge cookie, skipping scavenge.
2011-01-31 17:46:29, Info                  CSI    0000000c ICSITransaction::Commit calling IStorePendingTransaction::Apply - coldpatching=FALSE applyflags=7
2011-01-31 17:46:29, Info                  CSI    0000000d Creating NT transaction (seq 2), objectname [6]"(null)"
2011-01-31 17:46:29, Info                  CSI    0000000e Created NT transaction (seq 2) result 0x00000000, handle @0x274
2011-01-31 17:46:29, Info                  CSI    0000000f@2011/1/31:16:46:29.561 CSI perf trace:
CSIPERF:TXCOMMIT;51920
2011-01-31 17:46:29, Info                  CBS    Scavenge: Completed, disposition: 0X1
2011-01-31 17:46:29, Info                  CSI    00000010@2011/1/31:16:46:29.561 CSI Transaction @0x2900b0 destroyed
2011-01-31 17:46:29, Info                  CBS    Reboot mark refs: 0
2011-01-31 17:46:29, Info                  CBS    Idle processing thread terminated normally
2011-01-31 17:46:29, Info                  CBS    Ending the TrustedInstaller main loop.
2011-01-31 17:46:29, Info                  CBS    Starting TrustedInstaller finalization.
2011-01-31 17:46:32, Info                  CBS    Ending TrustedInstaller finalization.
Any help please?
Thank you :)
    2011-03-04T19:52:47+00:00
    Thanks Marcellus,
    Unfortunately I had already tried that with no luck.
    2011-09-23T22:03:24+00:00
    Don't feel pregnant. I just found TWENTY variations of explorer.exe in C:\Windows\winsxs\ . I found my way here because I've been having pretty much the same problems. In particular, I can't install a program because if I try the computer goes into 'fibrillation' and 22 examples of explorer.exe show up on Task Manager processes. I must then reboot, and that's that. I know that the two in system32 and sysWOW64 are legit, but the other 20 most certainly are not.
    Somebody,anybody, what do I do next? I find no end of horror stories and warnings about not touching winsxs, but something perverted it, and I must clean up the problem and [hopefully] stop it from happening again.
    Nostalgia time: I never had this stuff in XP, constant headaches in windows 7.
    Dave  KAHUNA  Binko
